Question about Panasonic PT-AE900U Multimedia Projector
Panasonic PT-AE900u no image
Your suggestion of unplugging the projector and waiting 4 hours, as well as removing the batteries from the remote unfortunately did not work. Anything else I can try?
  • benvpr Nov 04, 2008
    The projector is about two years old. The bulb has less than 800 hours on it. Really the bulb is fine and the environment is very good as I have it in a seperate home theater room. I did clean the filter. The only thing I can think of is that the day the projector went bad was a very humid day. Maybe this has something to do with it. But the projector clearly shows a green light indicating the bulb is fine. I'm going to sent it in for repairs at this point unless you can think of anything else. Thanks for your help.
    Brigadier General:
  • 3,614 Answers
May i know now what is the age of your projector. have you done replacing the lamp of the unit before.
Lamp life varies by manufacturer and projector type. Lamp life also depends on the projector's environment: air flow, clean air, and also on the level of usage. Check the user's manual or specification pages for your projector to determine the exact lamp life.
Posted on Nov 04, 2008
My Panasonic PT LC76U has horizontal pixelated lines. See image at this link http://abigproduction.us/_images/panasonic.jpg
you need to check:
the Vga cables if the image shown is that from a computer
firstly check if the Panasonic logo comes ok in the beginning
if ok then try connecting a laptop directly thru a short patch cable to the computer port of the projector[i am assuming that the projector has been installed to the ceiling]
if this works ok , then the projector is fine!
you need to figure out the problem with the vga cabling and switchers if any of them are used!
Dec 30, 2012 | Panasonic PT-AE900U Multimedia Projector
Do you have a diagram for where the iris is on the Panasonic PT-AE900U projector? we are trying to repair a grumleing sound
http://www.scribd.com/doc/44911427/AE900-servicemanual Check that link. Page 22 on the document details how to remove the Iris unit, including a picture diagram on how to remove the unit. Hope this helps.
Mar 06, 2011 | Panasonic PT-AE900U Multimedia Projector
Our projector (Panasonic PT AE900U) is still working but the picture seems very dark all of a sudden. we are wondering if this means we need to replace the bulb and if so, what do we replace it with.
You need a new lamp. Cost is around $350. The following site shows replacement:
http://www.shopvsc.com/Replacement-Lamps-for-Panasonic-Projectors-s/284.htm?searching=Y&sort=7&cat=284&show=50&page=1&f-PT-AE900=109462
Oct 16, 2010 | Panasonic (ETLAE900) Projector Lamp for...
I have a Panasonic pt-ae900u projector that doesn't project an image. The lamp fires up but no light makes it past the LCD panels, no video or menu graphics, nothing...help would be appreciated
I have the exact same issue with my projector and was wondering if anybody has an idea what the problem/solution could be? Have checked all internal connections, wiring, etc. but nothing is physically wrong with it. Powers on and off with no issues; bulb is working but no light out of the lens. Please help!
Oct 14, 2010 | Panasonic PT-AE900U Multimedia Projector
Panasonic PT-AE900U Projector Lamp stops working (intermittent)
since it has worked 1200 hours or even more since u have been resetting the counter! just change the lamp, resetting the counter does not make the lamp work or not work , it is only a reminder for the user to change the bulb when it should be & that u have some balance hours left to procure a new lamp!
if the brightness is adequate, then it is a ballast problem & not lamp problem!
buy a new lamp as u will anyway need to , fit it & it may solve ur problems permanently!
Jan 27, 2009 | Panasonic PT-AE900U Multimedia Projector
Panasonic pt ae900 wont fire up
First , start over and unplug it. Wait a few minutes. Turn on AV system that is connected to it but not video or dvd player. With remote, point at is corectly and push power 1 sec or as soon as you see green light come on. Be quick.
If this fails you can wait 4 hours and repeat. OR try only projector with out any feed.
Let me know if this worked.
Dec 14, 2008 | Panasonic PT-AE900U Multimedia Projector
No image, lamp light blincking red
I have a 3 yr old AE900U dont know exact hours but prob at least 2000 hrs. about every other start up, the projector would flash little box; (replace lamp now). now a month later lamp wont come on. So this is prob the normal way a lamp will die. anything else might be another problem.
Jul 23, 2008 | Panasonic PT-AE900U Multimedia Projector
Panasonic PT-AE900U displays black and white only
sounds like bad cables, or wrong setting on projector you may have it set to compoent instead of composite,, you don't tell how you are hooking it up. (what type of cables you are using)
Oct 25, 2007 | Panasonic PT-AE900U Multimedia Projector
Panasonic PT-AE900U Multimedia Projector Logo
214 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
