Question about SanDisk Sansa m250 MP3 Player
Mp3 player cannot be charged
I have a sansa fuse 4GB model.i tried charging it by plugging in computer but it wont charge.Please suggest a solution
  • Anonymous Nov 18, 2008
    The device is not charging (Sansa - Fuze) when connected to the laptop.
    In the device manager the device shows an exclamation mark on the device.
    Kindly suggest.
    Problem Solver:
  • 18 Answers
First, post your question under the right product.
Posted on Nov 13, 2008
My mp3 player wont charge but will turn on when pouted in
connect the Sansa (via the player's USB cord) to different USB ports on the computer until the Sansa starts to charge. A weak or non-working USB port won't charge the Sansa.
  • Reset the Sansa MP3 player. Slide the player's "Power" switch all the way up to the "On" position. Hold the switch in that position for 20 seconds. The Sansa resets. Try to charge the player.
  • Install the latest firmware onto the Sansa MP3 player. Download the Sansa Firmware Updated (link in References), and then click the link in Resources for the specific model of Sansa you own to learn how to update the player's firmware.
  • May 01, 2012 | Kitchen Appliances - Others
    My fuse wont charge at all. i bought a new charger and still get no charge
    Make sure that the USB cable is properly plugged in and use the original cable that came with your player.
    Computer in Hibernation mode
    Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player.
    USB Port 2.0
    Make sure the player is connected to a USB 2.0 port (1.1 occasionally causes charging problems).
    USB Port location
    Try plugging into different USB ports (i.e. USB port in the back of the computer); occasionally the front USB ports have limited power to charge up the device.
    Battery
    Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
    Latest firmware
    Depending on what Sansa player you have, make sure it's up to date with the latest Firmware.
    AC charger (optional)
    AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port. These accessories are available at SanDisk web site.
    Dec 04, 2010 | SanDisk Sansa Fuse MP3 Player
    HI, MY NAME IS ANGELA. I PURCHSED A SANSA MODEL
    The Sansa charges via the USB cable. Fully charged, it should be good for 12-15 hours of playing. Be aware that not all computer USB ports put out enough current to charge external devices. If your computer doesn't charge the Sansa, try a different computer. You can also charge the Sansa using other USB charges, such as you'll see for charging cell phones from a wall outlet or a car cigarette lighter.
    Jul 23, 2010 | SanDisk Sansa e250 MP3 Player
    Wont turn on unless plugged into computer
    Hi it very much sounds like the on board batttery is not charged up, (not charging) hence when you plug into the PC it gets it supply from the USB 5Volts and plays as normal
    Apr 15, 2010 | SanDisk Sansa Clip MP3 Player
    SanDisk Sansa e260 (4 GB) MP3 Player MP3 and Digital Media i have a e260 sansa mp3. when i plug it into my Answer i have a e260 sansa mp3. when i plug it into my computer it wont charge what should i do
    There is a trick to charging the battery in these small mp3 players. It wont charge if it is turned on, and it won't charges if it's turned off. Here what to do...
    1. plug the payer into your USB port. or wall charger
    2. switch thje palyer on using the mechanical switch (on the side)
    3. turn it off by either holding down the play button, or selecting "System" from the menu
    4. The screen will go black and the battery will begin charging.
    Jan 30, 2010 | SanDisk Sansa e260 MP3 Player
    Sansa e250 wont charge when plugged into the computer.
    Sounds like the internal battery needs to be replaced.
    Hope this helps. Good Luck!
    Aug 07, 2009 | SanDisk Sansa e250 MP3 Player
    Sansa fuze of 4gb wont charge
    Hi
    I have sansa clip which i believe behave the same it never says charging it always says connected but that does not mean it is not charging .
    leave your sansa connected for a while and then see if the battery meter has changed .
    hope it helps
    Enjoy
    Jul 17, 2009 | SanDisk Sansa Fuze MP3 Player
    My computer does not detect my mp3 player sansa 4.0 gb
    What i would recommend you to do is to uninstall the device and reinstall it back...to uninstall it...assuming that you are running windows xp...click on start, right click on my computer and go to properties..you should have your system properties open then click under hardware then device manager...look for the sansa device..it usually located under portable device..if its not showing there i would recommend you to look for under disk drives and see if its there..right click on the device and click on uninstall...after you unintall it unplug your device from the computer....Then follow this link below to download the porting kit...http://www.microsoft.com/downloads/details.aspx?FamilyId=A2E73160-E862-4F19-BB26-C0CAFE798955&displaylang=en .Then check the mode of yuor device to make sure it sunder MTP not msc...To check the mode go under menu, settings and choose usb mode...After you check the mode open up your windows media player click on tools, options and click under privacy...clear the history and caches...after you finish you can plug the device on the back of the computer not the front then windows should recongnize it and it should work properly..if that doesnt solve the problems upgrade your windows media player to 11 even though you have done that already..and try to reconnect your device..make sure you have it connected on the back USB>>>
    And if that doesnt work try to obtain the driver for your sandisk device go to http://www.sandisk.com/DriverDownload/index.asp and find the driver for your device..and then connecct the device on the back of your computer...it should work properly..if you are still having any problems..let me know..i would be more than happy to assist you..
    Please rate accordingly
    Thank you
    Mar 10, 2009 | SanDisk Sansa Fuze MP3 Player
    SanDisk, 2 GB Sansa mp3 player won't charge
    You MAY have a power glich. In which case, hold the power/menu botton down for 20 seconds or more, then connect it to the computer.It's best if you use a USB input that's NOT part of a Multi-USB base, as those DO cause power gliches.
    Oct 17, 2008 | SanDisk Sansa e260 MP3 Player
    Sansa Fuze not working anymore
    My friend give me a sansa mp3 player BB0703UBB. When i charge it in my PC and i forgot to unplug sansa mp3 player BB0703UBB after half hour i plug it. But the power is not working. i cannot open and play it anymore. I try to insert it on my PC but then it says unknown device. HELP!
    Jul 17, 2008 | Audio Players & Recorders
    SanDisk Sansa m250 MP3 Player Logo
    Top SanDisk Audio Players & Recorders Experts
    Gyula Lacz
    Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
