Question about Washburn Amplifiers: 25 WATT Guitar Amplifier - Bad Dog - BD25R Car Audio Amplifier
Guitar Problem I Think.
My amp doesnt output any sound when you plug the lead into both the guitar and amp. If you listen to the amp though, you can hear that it is working fine.
I know its not the amp or lead because i used a diffrent lead and amp to check if it was and still, no sound came through.
Can anyone tell me what is wrong with the guitar if you know?
Thanks
Rachael.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 11 Answers
With the cable (lead) plugged into to the amp with the volume turned up, unplug the cable from the guitar end and hold the plug with your hand and touch the plug tip with your thumb. If it makes a pretty loud buzzing or humming sound this means the cable is good. Then at that point you need to get the electronics looked at for defects. If there is no hum than you can assume that the cable is defective and needs replacing.
Posted on Mar 09, 2015
  • 51 Answers
It is the guitar. The most common problem with electric guitars is that the nut on the guitar output jack gets loose and the jack will turn in the mount, causing the wire to break. It will have to be re-soldered. Guitar Center usually has someone who can do that.
Posted on Nov 25, 2008
    Problem Solver:
  • 14 Answers
First check your guitar to amp cord.
The pickup, audio jack, or pickup selection switch may be defective.
Posted on Nov 05, 2008
Wiring output from the bass to the amp is not getting a signal or is not making any sound..how would i repair this?
you'll need to determine if its the amp or guitar. SO! plug a different guitar into the amp ( to make sure it does in fact work ). if it does you have a guitar problem. if it doesnt then an amp. Also be sure to check things like the cable as well. if it's the guitar then more than likely you can take the back plate off and find a broken wire. depending on location of broke wire determines where it connects back to. try these actions and post back on here for any further help. Please Rate! THanks!
Sep 05, 2011 | Traben Array 4 Electric Bass Guitar -...
I plugged my guitar into the amp one day only to get no sound from the guitar. The amp is working - I plugged a different guitar in and it worked - but the guitar seems unresponsive.
If the guitar is active and the battery is dead you will not get any sound. If the output jack or some of the controlls have been twisted and may have broken the connections on the inside.
Feb 11, 2011 | Washburn Electric Guitars Modelno X11B
My warlock makes this horrible noise as i plug in the cord. I don' have ANY idea why. I've been messing around with it and still nothing has worked out. It makes the sound as if my amp is turned all the...
If the noise is a pop or click, that's normal. Any other sound could be caused by too long a cord, which will produce noise while on the floor.
If it's not the cord, then you most likely have something wrong with the wiring inside the guitar. Have a luthier (guitar builder and technician) look at it, and s/he should be able to fix the problem.
Hope that helps!
Nov 21, 2010 | B.C. Rich Nt Warlock Electric Guitar
Just bought a yamaha rgx 211. When I plug it in there is only noise like a wire is hooked up wrong.
Try taking the guitar back to the store where you got it. Recreate the sound. If it is a faulty connection they will know what to do about it.
Nov 14, 2010 | Yamaha Electric Guitar
I PLUGGED THE GUITAR INTO THE GUITAR INPUT AND PLUGGED ANOTHER JACK INTO THE SEND UNIT TO MY AMPLIFIER BUT CAN'T HEAR ANY SOUND EVEN THOUGH I GET A READING THAT SHOWS SOUND IS HAPPENING. THE OL LIGHT IS...
try this: plug a stereo headphone into send & check if you get something on one side of the headphones (should be left side) if yes check the cable you use, it's possible that a mono plug (as used for guitars) is disabling the send output, using a stereo plug & adaptors may work (especially if you get the sound in the right side of you headphones check also the manual you may find a description how to connect/insert a guitar effect when recording or live mix
Nov 12, 2010 | Tascam Dp-02cf Digital 8-track Recorder
How do i plug my eletric guitar into an amp
Connect a 1/4" instrument cable from the guitar's 1/4" jack to the amp's 1/4" input.
Oct 02, 2009 | Dean Guitars Dean Ml79 Electric Guitar
When plug in guitar to amp, there is either no
Try a different guitar and cord. If still problem, give the amp a bump without guitar plugged in. If amp makes noise, there is an intermittent internal connection,
Paul
Jun 07, 2009 | Roland MMP-2 2-Channel Amplifier
Wii Guitar Hero - No Guitar Sound
if the audio works for regular tv
check to see if the av cable is in properly
or if the red and white leads are plugged in
a470eb6.jpgRed and White leads
21fdb44.gifScart
Dec 17, 2008 | Nintendo Guitar Hero Wireless Guitar - Wii...
Just get clean tone through NI Rig Kontrol 2
you need an asio driver for your rig kontrol.. you are probably set to use DirectX drivers, which will give you latency of 50ms and waaaayy beyond... By contrast, ASIO drivers will give you sub-10ms latency... Most people can play at around 7ms, but im picky, and no more than 5ms will do for me..
Go download the drivers from NI site, and try those.. if that doesnt work, there is ASIO4ALL... google and read.,. this will help ya
keep playin
DJYoshaBYD
Sep 29, 2008 | Native Instruments GUITAR RIG
I've just got a tascam dp01cf recorder and i'm having trouble with it, its abit hard to understand what to plugs in were, i'm using a electric guitar,a yamaha magicstomp effect pedal and a amp. also i'm...
You have a couple of options with your guitar input. You can either plug your guitar directly into the right (Hi-Z) input and use the Tascam's onboard effects with it instead of your effect pedal.
You can put your pedal in the chain between your guitar and the (Hi-Z) input. So guitar into pedal is, pedal out into Tascam Hi-z in. (Still doesn't use the amp).
Or my preferred method for recording guitar would be to mic the amp. In that case you'd just input a microphone (placed about 8-12 inches from your amp) and record your guitar that way. The mic would be plugged into either one of the Tascams two mic inputs to record the amps speaker output while your guitar, pedal and amp would just be hooked up in the normal way.
Please note: Never plug the output from an amp into any of the Tascams inputs. Those inputs are line-level and the speaker output level which comes out of an amp out would damage your Tascam.
To get a backing song into a track in your Tascam, you'll have to first, using a PC, get the song into a 16 bit mono Wav file format. Then you'll have to use the USB import function to copy that wav file onto your Tascam onto the CF media cards fat partition. From the you'll be able to import it into the Tascam choosing which track it will import into.
Cheers,
BD
Apr 17, 2008 | Tascam 2488 Portastudio Multitrack...
Washburn Amplifiers: 25 WATT Guitar Amplifier - Bad Dog - BD25R Car Audio Amplifier Logo
350 people viewed this question
Top Washburn Car Audio & Video Experts
xxxxxx xxx
Are you a Washburn Car Audio and Video Expert? Answer questions, earn points and help others
