Question about Pioneer SD-533HD5 53" Rear Projection HDTV
Seeing double on our Pioneer SD-533HD5
Help, we are seeing double on our TV. The bottom portion of the set now has "dome" shaped purple area that appears to be pushing the colors up causing everything to appear as a carbon copy just above itself. We have tried changing the settings on color, picture, etc., but nothing seems to be helping.
  • jones2300 Nov 30, 2007
    I have the exact same "purple dome" and "carbon copy" problem you have mentioned. How expense will this be to repair? Any info. will be greatly appreciated!
  • Moody9304 Dec 08, 2007
    I went to plug in our video gamin systems and when i came back the tv had auto powered itself off when we went to turn it back on there was a purple dome with double vision of everything on it? is there anything we can do to fix it without replacing any parts?
  • 64 Answers
The convergence IC's need to be replaced. look for stk letters and some numbers on them. If You are familiar with electronics repair try replacing them but be careful there is high voltage in the set even after unpluging it from the wall. Post back
Posted on Nov 13, 2006
    Problem Solver:
  • 10 Answers
IBelieve the convergance ic,s are bad ,replace all or you will be back
Posted on Oct 03, 2006
What does it mean when I have double vision on all channels and dvd on my pioneer sd-533 hd5 big screen floor model?
follow this steps and fix it. God bless you
Configuration Problems
Improperly configuring TV setting can cause problems. Verify the TV settings are set correctly. First, brightness and contrast should not be set to high or to low because this can cause poor picture images. Second, adjust the color on the TV when the picture displays colors poorly. Third, if you are having sound issues then check to make sure the volume is not muted or turn down all the way.
Nov 04, 2013 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer SD-533HD5 53 in. Rear Projection HDTV Television - Need Manual ....
ManualsLib has the manual for the SD-533HD5 here: https://www.manualslib.com/manual/384249/Pioneer-Sd-643hd5.html . (The manual covers two models.) Once you modify the picture parameters (starting from STD, REF THEATER, GAME), these are stored as the User mode. If you press Menu when done changing the parameters, that input should maintain the User settings for the last setting until you change the Picture type. If you modified the parameters for STD and then return to that input and change the Picture to GAME, any modifications to the GAME picture parameters will become the new User Mode. See page 50 of the manual for the details: https://www.manualslib.com/manual/384249/Pioneer-Sd-643hd5.html?page=50#manual .
I hope this helps.
May 27, 2017 | Pioneer SD-533HD5 53" Rear Projection HDTV
Cannot use convergence on remote for Pioneer SD-532HD5Pioneer SD-532HD5Pioneer SD-532HD5Pioneer SD-533HD5 53 in. Rear...
Ur convergence it dead.Must know how to solders.Tries these Websites.Tv Repair World.com,Tvrepairkits.com to buy a convergence kit.
Dec 29, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
I have a pioneersd-533hd5 there is a purple shadow under display letters and sems out of focus
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
  • Screen looks 3D
    Colors don't line up
    One or more colors can't be adjusted when using the convergence menu.
    Screen is bowed or warped.
    No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 27, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
My television has a green tint to the picture...help
go into the tv picture settings and there should be an option for colors and try turning the green down, sorry its not an exact solution but i dont own one so just trying to help
Dec 30, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Red convergence bowing
Replace both of your STKs if they are STK392-110s upgrade to STK392-180s these are the convergence ic big black ics 2 of them. Electronix Parts 1-800-223-3205
Dec 15, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Help tv is showing double text at bottom and bowing colors
Convergence ICs are bad and need to b replaced there are two of them theyost about 10.00 each.
Jan 12, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Vertical lines on screen
this is the convergence gone bad. that is what was blowing the fuse. this is the board on the far left. there are two stk`s on this board. stk392-110.
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 05, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer SD-533HD5 53" Rear Projection HDTV Logo
141 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
