Question about Mitsubishi SL4SU ColorView Multimedia Projector
2 red lights on projector. have changed the bulb but red lights are there and projector won't turn on.
Reset the Bulb life. Every time bulb changed need to reset it to bring it back to 0 hour.
Posted on Dec 02, 2008
  • chris Sep 21, 2011
    how do u reset the life send reply to ChristianWaldram@msn.com
dhiman
  • 115 Answers
SOURCE: projector problem - Epson EMP-S1H Multimedia Projector,
try to reset lamp by using menu, up, down and enter buttons. also reset the filter and try again.
Viren
Posted on Nov 27, 2007
Sinista
  • 6 Answers
SOURCE: Tech support for Sharp PG-B10S
Reset The Lamp Timer.
While simultaneously holding down (+ . >) and AUTO SYNC on the projector, Press ( I ) ON and ( - . < ) on the projector.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
NOTE..... Make sure only to reset the lamp timer only when replacing the lamp. If you reset the lamp timer and continue to use the same lamp, this may cause the lamp tp become damaged or explode...
Sinista
Posted on Jul 10, 2008
SOURCE: Bulb failures
I experienced the same thing, only to discover it was the ballast that powers the lamp. I believe INFOCUS repairs for $390.00 per the technician that I spoke with on the phone at INFOCUS.
Posted on Jul 19, 2008
cammykins
  • 149 Answers
SOURCE: Infocus screenplay 4805 projector
Did you reset the hours on your system once you inserted a new light bulb? Otherwise the pj might be a bit confused if you do not reset that with each bulb. The suggested life expectancy for the lamps is around 3000-6000hrs for a DLP lamp pj.
Have you also cleaned out the filter? It is a GREAT idea to do that every year otherwise it could potentially over heat. Most of the time you can have some one come out, bring it to a service center, or ship it to the manufacturer to be cleaned, then they mail it back to you.
Let me know how things go. You can always contact the manufacturer to direct you on how to reset the hours. They do offer a life time support.
Best of luck!!
Posted on Oct 27, 2008
SOURCE: Optoma hd65 projector new bulb wont turn on...cant reset timer!
I think it's a lamp driver issue from what I've seen others have gone through. I also read that if you go through the sequence of unplugging, plug back in, wait 20 seconds and try to turn on, multiple times, it will finally kick on and work. I just got mine to turn back on by doing this and waiting through the fan cycling without the light turning on. After the 4th sequence the light flickered. After the 7th sequence it finally turned on and is working. Now I can watch the Super Bowl and will look into replacing soon.
Posted on Feb 06, 2011
Changed bulb for epson brightlink 455wi but its still blinking red
Is it just one light blinking red or all 3 blinking red? Be sure to 'reset' the bulb hours. Try another bulb. If it is all 3 lights blinking red then you are sol.
Mar 10, 2014 | Epson BRIGHTLINK 450WI Projector
My epson emp-74 won't show...the red light keeps on flashing
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
We supply original projector parts: lamp, bulb, Lcd
panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and
competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Dec 06, 2012 | Epson (V13H010L32) Projector Lamp for...
My optavision hd 9500 projector's light doesnt come on, have changed bulb still won't work.
My optavision hd 9500 projector's light doesnt come on, have changed bulb still won't work. what do i do
Oct 28, 2012 | Office Equipment & Supplies
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
I am replacing the bulb on my sharp xv-z2000 projector. i replaced it fine but the power light and the bulb light both stay red and i cant even turn the projector on. how do you reset the projector?
Two red lights indicate a problem with the lamp circuitry, i.e. the ballast. This requires a service center to change out a circuit board. Given the cost, it might be time to look for a new projector.
Dec 04, 2010 | Sharp XV-Z2000 Multimedia Projector
Hitachi ED-X8250 - Turns off after 15 mins LAMP and POWER = RED
reset the lamp and filter timers. turn the projector off then back on.
Mar 29, 2010 | Hitachi ED-X8250 Multimedia Projector
Blinking red light
replce lamp ballast board of your projector...
Oct 06, 2009 | Epson EMP 7500 Multimedia Projector
Toshiba tlp651u projector
The small 3x3 cm blower might not run.
Nov 30, 2007 | Toshiba G 7 Multimedia Projector
Mitsubishi SL4SU ColorView Multimedia Projector Logo
925 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
