Question about Refrigerators
I have an LG Fridge freezer model ref GR642QVP. The digital temperature display at the front keeps beeping randomly, and the actual temperature goes up and down constantly whilst beeping taking place - ie from 3 to 0 back up to 2 then down again etc. intermittently occuring problem, but occuring more frequently of late. many thanks. 07725 035510 ms barker.
    Problem Solver:
  • 19 Answers
May have an earth problem, have a refrigeration technician check the earth terminal in the back of power point and back of refrigerator, also check the connections of plugs to the printed circuit board (PCB) in the fridge.
Posted on Nov 13, 2008
I found out the outlet is the probelm because is not grounded this type of ref needs ground due to the main board at the back
Posted on Nov 07, 2008
  • Jenfrance Feb 28, 2014
    when you say ground - do you mean earthed ? i have the same problem and its driving us crazy
    when you say needs ground what do you mean. we have the same problem and its driving us crazy. is yours fixed now ?
The temp says 14 and 8 but should be -21 and 3? Can anyone help
Controlling the Freezer temperature
The freezer temperature can be set between -14°C (8°F) and -25?C (-14°F) to suit your particular needs. Press the freezer button repeatedly until the desired temperature is shown in the temperature display. Keep in mind that foods like ice cream may melt at -16?C (4°F). The temperature display will move sequentially from -14°C (8°F) and -25?C (-14°F). When the display reaches -14?C (8°F), it will begin again at -25?C (-14°F). Five seconds after the new temperature is set the display will again show the actual current
freezer temperature. However, this number will change as the Freezer adjusts to the new temperature. The top and bottom guards in the freezer of this model are the two star sections, so the
temperature in two star sections are slightly higher than other freezer compartment.
Controlling the Fridge temperature
The refrigerator temperature can be set between 7?C (45°F) and 1?C (34°F) to suit your particular needs. Press the fridge button repeatedly until the desired temperature is shown in the
temperature display. The temperature control process for the Fridge works just like the Freezer process. Press the fridge button to set your desired temperature. After a few seconds, the Fridge will
begin tracking towards the newly set temperature. This will be reflected in the digital display. The temperature of the freezer or the refrigerator may rise from opening the doors too frequently, or if a large amount of warm or hot food is placed in either side. This may cause the digital display to blink. Once the freezer and refrigerator return to their normal set temperatures the blinking will stop.
If the blinking continues, you may need to "reset" the refrigerator. Try unplugging the appliance, wait about 10 minutes and then plug back in.
The refrigerator does not work at all or it does not chill sufficiently.
• Check that the power plug is properly connected.
• Is the temperature control on the display panel set to the correct
temperature? Try setting it to a lower temperature.
• Is the refrigerator in direct sunlight or located too near a heat source?
• Is the back of the refrigerator too close to the wall and therefore keeping air from circulating?
Jul 19, 2015 | Samsung RSA1UTMG American-Style Manhattan...
Got fridge freezer but no instructions. Alarm keeps going off. Front panel contriols
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :
Apr 10, 2015 | Refrigerators
How do you fix icing sensor error (ER IS) on an LG lfx25974st Fridge?
My lg fridge keeps beeping saying the freezer temperature is fluctuating
Jan 20, 2015 | LG Refrigerators
My frost free fridge freezer is working but flashing de on the front. I'd like to know what it means
Error codes are brand (and often model) specific. "de" likely indicates something in the defrost process, especially on G.E. Check for ice build-up in the freezer cooling coil. The control board would be suspect, but must be checked to confirm the precise fault.
Oct 20, 2014 | Refrigerators
I have a german LG Intellowasher 7KG and I do not know where to put the detergent, bleach, softener, there are 3 compartments and I do not know what the symbol mean in front of them
I have a LG refrigerator freezer side by side about 6 years old I fet a reading on the digital display FRZ -Er REF -Cr when I unplug the thing and replug it the display is back to normal after a few seconds it gives me the error readings fridge and freezer keep cold but ice and water dispenser doesn,t work HELP
Aug 16, 2011 | Washing Machines
My samsung ref rs2555sl stopped cooling. The temperature display for both freezer and fridge on the front keeps flashing. What do I need to do?
Most of the time if you unplug it from the power source for about 10-15 minutes will reset fridge computer and when you plug it back everything get back to normal.
Oct 02, 2009 | Samsung RS2578BB Side by Side Refrigerator
Refrigerators Logo
561 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
