Question about LG Washing Machines
Hi I have an LG washing machine WM-16331FDK and am getting error code UE. I have misplaced manual and don't know what this means. I have unblocked filter and am now doing a wash at 95 degrees to clear sludge. It spins and drains to a small etent but won't spin at speed. Thank you Karen
Error code UE means unbalanced load. This can be caused by not enough washing in the drum. I just added more washing and it worked!
Posted on Nov 05, 2008
How do I rectify the UE code , I have finoished my wash but it is still showing up
Hi.
US means unbalanced error. Try balancing the unit as explained on the owners manual. Try redistributing the load. Check the floor. If that does not work try following the instructions in the diagrams for the specific code available on the LG support website. Here the link.
Regards.
Ginko
Sep 06, 2011 | LG WM-2077C Front Load Washer
LG wash machin have error code "EU"
There is no such error code. The closest error code would be UE which means that it's a unbalanced load error. If you have a light load, or you are washing a large bedsheet or bedspread, that will cause it to not spin properly because the machine cannot balance the load. The best thing I can recommend is adding about 4 to 5 large bath towels so the weight can be distributed more evenly.
Good luck
Jun 12, 2011 | LG WM-2277HW Front Load Washer
My Lg washer is showing a code UE and then PF what can I do to fix this problem.
UE means that the load is unbalanced in my LG. The code PE means that the water sensor is malfunctioning and needs replacing.
Feb 13, 2010 | LG WM-2277HW Front Load Washer
LG front load washer coded UE. what does that mean?
UE means unbalanced error. when you see this, it means the clothes are unevenly distributed in washer, it's basically unbalanced.
Dec 03, 2009 | LG WM-2077C Front Load Washer
Error code UE will not spin fast except on quick wash, or if i push SPIN SPEED and SOIL LEVEL at the same time
UE could mean user error, or if the washer senses an unbalanced drum 3 times in a row which might cause it to not spin at high speed. It could also be a control board problem. Sorry i couldnt help more
Mar 13, 2009 | LG WM-2032H Front Load Washer
Washer
the error code, UE means that there is an imbalance error. Either the load is too small, the appliance is tilted, laundrey is gathered to one side, or non distributable things have been put into the machine.
Jul 26, 2008 | LG WM-2277HW Front Load Washer
Code error ue lg washing machine
ue is (imbalanced error) cause. the load is to small,washer is tilted, laundry is gathered to one side, non distributed things are put into the washer
Jun 20, 2008 | LG WM-2077C Front Load Washer
LG WM 14316FD washing machine
An UE Error Code is indicative of a “Unbalanced Error”. This indicates that the drum is not spinning in a smooth rotation. It may be necessary to rearrange the load in the drum. I found this answer on the lg web site.
Dec 01, 2007 | LG Washing Machines
Ue error code on the display
For "ue" an unbalanced load is sensed three times, re-adjust your load in the machine.
For e1, it could be a water sensor problem. Check to see if the inlet valve is okay and not clogged, water shd be in good pressure. If this is okay, open up behind after taking the plug off the wall. There is a thin tube coming from the switch area to the outlet pump area; disconnect this from the top carefully and blow into it, it should be free; if it is clogged you will hav a water level problem. Unblock and refit carefully.
Sep 23, 2007 | LG WM1814CW Front Load Washer
"CD" ERROR ON LG WM-3677HW Front Load All-in-One Washer / Dryer
CD means cool down, press the pause start button, the door lock will open. It is an anti crease cycle. It mentions it in the owners manual, but it is hidden deep in the drying section.
Sgt 48
Sep 01, 2007 | LG WM-3677HW Front Load Washer / Dryer
Washing Machines Logo
378 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
