Question about Lands Phones
Telstra 7100. we had a power cut and now the phone just flashes with base 1 ....no dialing tone ect help
  • sharmeenz Dec 30, 2008
    i recently got this telstra 7100 from the goodguys and the power wa off and now the phones just flash base 1 on all the three units , its now a long holiday and i cant fix the p problem please help
Disconnect the phone line leaving the power supply still plugged in. Next page the handset from the base unit hold and press button until it bleeps (remove the handset from the base unit first). press menu and scroll down to register.... press menu .....scroll down to select base... press menu then press 1. This should reset the phone. Failing that you can ring customer services the number will be on the bottom of the base unit.
Regards Sheena.
Posted on Nov 05, 2008
My phone doesn't have dial tone. Each time I dial a number and try to call,it wont work. I call my phone but it wont ring. I need help on this. What happen to the phone? Or what should I do?
If you have another phone connect it to the wall outlet to see if you get a dial tone. This will indicate if your base unit is faulty.
Check the power adapter to the base unit, make sure it is getting mains power.
If the base unit has dual phone lines and if line 1 is only connected and the line 2 has beed selected then you cannot get a dial tone. In the chase press the line 1 to get a dial tone.
If your base unit has only one line then check the phone line at the wall socket make sure it is plugged in tight, also check the the connection at the base unit.
If this does not work then ring the phone company and get the to test your phone line, you may have a faulty line to your home.
Feb 03, 2012 | AT&T E2116 2.4 GHz Cordless Phone
Hi, I have a Panasonic Cordless phone with 2 bases. I have moved one from upstairs to the phone jacket downstairs. Our third phone worked fine until I switched two of them around. Now only the plugged...
You could plug your non-cordless phone into suspicious phone jack to see if you have dial tone-if you dont have dial tone, the line maynot be connected and you should open the jack to see if there is more than 1 cable attached. If there is more than 1 cable attached and you dont have dial tone at other end of cable the cable might be cut or shorted somewhere inbetween. You can test continuity by tying 2 wires together and test with a multimeter on resistance to see if it is open circuit or maybe even short circuit. To test for short circuit, untie the cables and you should not get a reading. If you do have dial tone when you plug in non-cordless phone the distance might be to far for receiver to pick it up(ie..greater than 10 metres). I hope this has been helpful.
Aug 26, 2011 | Panasonic Lands Phones
I have 2 problems. 1. The orange message light will not stop flashing no matter what I do. 2. Some how the system was switched from touch tone to dial tone. I can't seem to that switched either.
Resetting the voice message waiting indicator
When you receive a new voice mail message, the new message LED on the top of the handset flashes. In the event your message waiting light gets out of sync with your phone company's
voice messaging system, you can manually reset it back to the "No messages waiting" state.
1. Press and hold FiND on the base for five seconds.
Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
2. A beep sounds and the message alert tone is reset.
Changing the dial mode
Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most base networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you will need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, please follow the steps below to modify your phone's settings:
1. Press MENU/SELECT.
2. Select the Global Setup menu, and then the Dial Mode submenu.
3. Scroll to highlight Pulse.
4. Press MENU/SELECT. You will hear a confirmation tone.
If you ever need to change the dial mode back to tone dialing, follow the same procedure, but select Tone in step 3.
Finally for future ease of use, here is a link to the user manual were I copied the above information from:
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1580-3om.pdf
Jul 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
My telstra 8100 cordless phone keeps showing the word searchingnow i cant do anything with the phone.hope someone can help. Cheers
Place the telstra 8100 handset in the charger. Call any number while the handset is in the charger and it should dial out - you can hear the dial tone now. Take the handset out of the charger and you should be able to call normally.
cheers Matt
May 16, 2010 | Cell Phones
FLASHING BASE 1 - PHONE'S LOCKED
Unplug the batteries for 30-45 seconds. Reinstall, and attempt to re-register the handsets to the base.
Jan 26, 2009 | Siemens Gigaset 4200 Cordless Expansion...
BT Freestyle 2200 I am having problems obtaining a dialing tone on both of my handsets. When I press the green button for a line out it just beeps 3 times and cuts off. There is charge in both the...
hi just want to help others as desciption aint complete above
Registering a BT Freestyle 2200 handset
1. If there is a handset in the base remove it whilst you are registering the new handset.
2. Press and hold the PAGE button on the base for about 10 seconds until you hear a beep and the In Use light starts flashing.
3. On the handset to be registered, press and hold redial & CALLSd buttons together until display shows 65-.
4. Enter the base number. If this is a new handset then the base number is 1, the display shows 65-1 then PIN. which is normally 0000
5. Enter and registration starts. When the handset beeps and returns to standby registration is complete.
Nov 08, 2006 | British Telecom Freestyle 2200 Trio...
Lands Phones Logo
806 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
