Porter Cable C2002 150 Psi 6 Gal Compressor Logo
Anonymous Posted on Mar 16, 2012
How to replace porter cable air compressor drain valve
  • Anonymous Mar 16, 2012
    The drain valve leaks and won't reseal. How do I remove it and put in a new valve?
Vlad Cell
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 55 Answers
  • Posted on Oct 19, 2017
Vlad Cell
Expert
Level 2:
Cheetah:
Answers
55
Questions
0
Helped
26007
Points
109
Install an Controller with automatic Digital control of drainage time - will save you money.
Check for Compressor Conroller
5 Related Answers
Anonymous
  • 256 Answers
  • Posted on May 31, 2009
SOURCE: Drain valve on air compressor won't open or close
I would use an ajustable wrenck to try and open the valve. Being at the bottom and in the water, this is a common occurrence. to replace the valve, there is a Hex nut outer fitting (part of the valve) that you have to remove right by the valve "T" handle. Put a wrench on this and remove the complete valve. It too will be very hard to remove. When you install the new valve, use some anti-seize compound to make future removal easier.
Anonymous
  • 59 Answers
  • Posted on May 25, 2009
SOURCE: Drain valve in Porter Cable air compressor
this valve works backwards, you screw it out to stop airflow. If that doesn't work, replace the valve.
David
webxcreation
webxcreation
  • 4 Answers
  • Posted on Jul 02, 2009
SOURCE: Porter cable pancake unit blows air after shut off.
tap on the check valve with a metal object. Its sticking open. The check valve is the brass fitting on top of the tank. When the valve sticks open it emits air from the area of the engine. If that doesn't work (which I would be surprised it doesn't), you'll need to purchase a new check valve. Good Luck!
mxc2
Marc Powers
  • 146 Answers
  • Posted on Oct 24, 2010
SOURCE: The drain plug on my Porter Cable pancake
Yes...the drain valve on the bottom of the tank is just a standard 1/4 Drain Pedcock that you can purchase at most hardware store.
You can also find these in the hardware section of Lowes or Home Depot where they sell the Air Compressors.
Gibson Scarborough
  • 4 Answers
  • Posted on Jun 07, 2009
SOURCE: Extra fitting on my Porter Cable?
The porter cable compressor is equipped with a pressure relief valve. Mine has a ring attached to it. When you pull out on the valve, it releases all the pressure stored in the tank. Try pushing that valve back in, or if faulty replace it.
2answers
I have a duel tank porter cable air compressor Will not build pressure past 50psi. when i open the drain valve light coat of moisture mixed with oil sprayed out. whats wrong?Thanks
Moisture and oil in small amount is normal with oil type compressors, a by product. If there is no air leak between the pump and tank, suspect worn piston rings, worn out faulty valves, loose pump head.
Can I replace the tank drain on my Porter Cable 150PSI 6Gal pancake compressor with a ball valve?
As long as it will physically fit and the rating is above 150psi -Yes.
I say above 150psi because if the compressor pumps to 150psi, a 150psi valve is on the hairy edge of it's max limit.
Drain valve leaks air -- no pressure in tank
Replace drain valve, its a 5.99$ at your local home depot, or hardware store. Cheers
I have a porter cable c2002 type 4 compressor with a leaky drain valve \r\nmy question is does the 1/4 inch valve come out. there is somekind of strange metal flange with wings that appears crimped around...
It is a simple drain valve with NPT (pipe) thread. Most likely either 1/8" or 1/4" NPT threads. Any drain valve with the same thread size should work fine. You may also find one at an auto parts store as they are used on automotive radiators too.
13helpful
The drain plug on my Porter Cable pancake compressor leaks so badly that it no longer build pressure. The compressor is just a little over 1 year old and I have always drained the compressor after each...
How to open drain valve on c2002?
Turn the knob to the left to loosen the tank drain valve.
If the valve will not turn you may need remove and replace the valve. This is just a standard 1/4 female pipe thread and you can purchase a drain valve at most local hardware stores.
Air Leak From Pump Head on Porter Cable C2001 Pancake Compressor
The real question is where exactly is the leak coming from. Compressors have a pressure release valve designed to let the pressure off of the compressor motor so it can start when there is pressure in the tank. This valve is often the culprit and fairly easy to replace. You can order it direct from porter-cable online. Just in case double check the drain petcock sometimes these get worn and won't close completely and can easily be over looked when trouble shooting.
1helpful
Won't build pressure air compressor
most probably the one way valve in the heads unless the drain tap is opened
5helpful
2answers
David
Top Porter Cable Air Tools & Compressors Experts
Jay Finke
Jay Finke
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
