Question about Dell E173FPb 17" TFT LCD Monitor
Flat Screen trouble
My dell Flat Screen E173FPb 17 inch turns on and displays the image but then shuts off only does this once and the light is still green i dont know how to fix this if anyone has any help please inform me
  • stu_g Jan 11, 2008
    I have the same monitor and I had to do a restart due to a upgrade and when the PC powered back on I no longer had my monitor. The green power light is on but the screen is black. I tried it on another PC and it did the same thing.
  • HighHeworth Apr 30, 2009
    When I turn on the power my E173FPb lights up for only one or two seconds and then goes black and the green on-light remains illuminated. If I don't have the video connected I get the dell logo or colored bars bottom left,drifting diagonally for the 1 or 2 seconds.
    I just replaced the inverter board: it didn't make the slightest difference to the problem!
    Problem Solver:
  • 6 Answers
You need to replace switching transistor 2SC5707 in the Power Inverter Board.
This parts is used to fix Some dell and hp lcd monitor.
DELL E172FPb, E173FPb. HP Pavilion F1703, Pavilion F1503. If you can't get this item to work let me know, I can help I have fixed a lot of these monitor with no problem.
Posted on Nov 04, 2008
  • 20 Answers
Shine a light on the surface of the screen. If you can see a faint image of what is supposed to be displayed, then you have backlight problems. If the inverter has been changed then you have a bad lamp causing the inverter to shut down. Fluorescent lamp replacement is a tedious job but can be done.
Posted on Oct 16, 2013
I have this too! :( . i need transistor 2SC5707 but where can i buy this one? anyone help me?
Posted on Apr 10, 2011
I successfully unlocked the osd.my problem now is, even im not press any button it appears automatically.any one who can help me?
Posted on Nov 02, 2008
Http://www.electronicrepairguide.com/dell-e173fpb-lcd-monitor-repair.html
Posted on Oct 26, 2008
"I have a yellow vertical l line that won't go away. Any solutions?"
Fault developed in the LCD screen itself - you'll not repair that. New screen? Probably not worth it... bin it!
Posted on May 28, 2008
Posted on May 03, 2008
Maybe replace inverter board
Posted on Dec 08, 2007
Dell e173fpb on off
Is it just turning itself off after you turn it on? Do you see a power on self test (POST) with the colored bars before it does this? There are a few causes and usually it results in replacing the unit unless you are knowledgeable enough to trouble shoot and service it. I don't recommend this as some people not experienced can electrocute themselves tinkering with the power supply and the various parts. Many displays will shut off if its not getting a signal so if there is nothing hooked up or a bad cable from the video source, then it may be shutting off because of this. Give some further details if you can. Cheers.
Oct 06, 2013 | Dell E173FP 17" LCD Monitor
MY DELL E173FPb FLAT MONITOR WILL NOT COMPLETELY POWER UP IN GOES
Most common failure in this model is shorted transistors in the inverter circuits caused by poor solder connections, see pictures here for guide: http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
Mar 27, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Dell E173FPb 17" TFT LCD Flatpanel
Video cards that can handle two monitors at the same time have cables with two plugs on the monitor end.
If your video cable has two plugs on the monitor end, try the other plug.
Dec 29, 2008 | Dell E173FPb 17" TFT LCD Monitor
Dell E173FPb monitor has gone black with green light (on/off switch) flashing.
http://www.electronicrepairguide.com/dell-e173fpb-lcd-monitor-repair.html
Dec 28, 2008 | Dell E173FPb 17" TFT LCD Monitor
Dell flat screen
REPLACE 2SC5707 IN POWER INVERTER BOARD.
May 01, 2008 | Dell E173FPb 17" TFT LCD Monitor
The screen doesn't display anything and the power button is flashing green
Ok I got the same problem. And this is the way how to examine where the problem is. You have to check that you can see the image on screen by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons (Power on both cpu and monitor), there will be a minor problem. Like me, I can see window image using flashlight and check lamps inside. Some of them were broken. If you cannot see any icon on the screen. I would say that there are some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or dark spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Nov 30, 2007 | Dell E173FPb 17" TFT LCD Monitor
Flat Panel Monitor the power button flash
Nov 29, 2007 | Dell E173FPb 17" TFT LCD Monitor
DELL E173Fpb
On my similar Dell 19 inch LCD Monitor, E196FPf, there are 4 screws on the back, and you need to pry off the plastic bezel from the front. At the bottom of the bezel are 4 small slots where you can start prying carefully with a screwdriver.
Nov 01, 2007 | Dell E173FP 17" LCD Flat Panel Monitor
Dell E173FPb 17" TFT LCD Monitor Logo
728 people viewed this question
Clive
Clive
Alun Cox
