Question about Powerware PowerRite Plus UPS System
Powerware 9330 15kVA UPS
We've got a 9330 UPS that's giving us a no bypass error. We're using this UPS to step down power (to US voltage) and provide battery backup. It's working well, but it's giving us 60Hz on the output but our mains are 50Hz, it sees 50Hz and is wired for 50Hz at the back, but it's giving us 60Hz out. Do you know to change the output to 50Hz?
Thanks,
Quasi
    New Friend:
  • 25 Answers
Did you fix this problem?
Posted on Jul 11, 2009
Powerware 9390 UPS error configuration and circuit breaker battery check
9390 Requires a UVR type battery breaker. Unfortunately a configuration error will require a service visit from a technician. The proprietary service software will have to be used to reset this.
Apr 14, 2015 | Powerware 9390 UPS System
I recently got installed Exide home UPS at my home. It normally works fine. It fails occasionally when we try to use an electric iron, when the MAINS POWER IS ON. I understand that we cannot use elect
The problem is probably not input voltage. Most UPS's will step up or down voltage to give, in your case, 220v. Depends on which outlet you connect to. Irons are resistance heaters, and as such will draw a significant amount of power. e.g. most consumer USP's will warn NOT to connect a laser printer to the battery back up outlet, but rather non-backed up outlets. Better yet, IMHO, connect it directly to a primary connection (i.e. a wall outlet).
Consumer or end user UPS's are aimed at providing enough power to allow you to save work. I can't think of a reason to need a battery backup for an Iron. I'd use the UPS for your computer, monitor, phone system is you use VOIP, or low draw wall warts.
Oct 08, 2014 | Computers & Internet
Can't go into bypass mode
what is the bypass voltage is it within the windows if not, UPS is ok no problem
Apr 05, 2014 | Powerware 9330 UPS System
Inverter fault
This unit will require you to Brain dead the whole UPS.
To see if it is actually a condition that exists with the hardware or if it was just a lock condition.
Steps:
1)Power down unit completely
2)Unplug all batteries
3)Unplug from wall
4)Leave unplugged for about 5 minutes or so WITH NO POWER AT ALL.
5)Plug batteries back in
6)Plug back into wall
7) Turn unit back on
Log into console of UPS and see if the condition returns.
If it does not return your good to go.
If the error returns. You have to replace the WHOLE battery pack.
APC has told me their units are typically good for 4-6 years, after that their units cannot hold the same tolerances as they did when they were brand new.
Hope this helps.
Oct 30, 2012 | APC SURT8000XLT-1TF3 Smart-UPS RT 8000VA -...
When switched the bypass to normal position, voltage failed through the unit; however the QB3 position gives output voltage
You didnt start the UPS correctly because the static switch was not on. The Static Switch has to be on to get a clean transfer of power. Check your static switch
Sep 14, 2011 | MGE Galaxy 3000 UPS System
I WOULD LIKE TO BUY A NEWPowerware 9330-40kva UPS UNIT, COPLETE WITH BATTERIES .how much would that cost?
It's unlikely that you will be able to get a new one. The 9330 was discontinued many years ago though Eaton continues to service these models and provide replacement parts/batteries. I suggest that you call 800-356-5794 to see if Eaton has a partner that has any complete systems still in stock or in service inventory. The new UPS units are the 9355 and the 9390: www.eaton.com/9355 and www.eaton.com/9390 These new units are more compact, are more energy efficient and incorporate more advanced technology for monitoring and communication.
Mar 11, 2011 | Powerware 9330 40 (A40401110031112) UPS...
I have a Powerware 9330 100kVA UPS. The configured password is unknown by me. I want to reset the password and want to know the default password so I can configure the system. Can anyone help me with this...
Powerware was purchased by Eaton and they continue to provide support for all Powerware products. In the U.S. call Toll Free: 1 800 843 9433 (International: +1 919 871 1800) or
e-mail: LargeUPSTS@Eaton.com. They can help you out with the password. The 9330 manuals and documentation are located here: http://powerquality.eaton.com/Products-services/legacy/9330-info.asp
Oct 06, 2010 | Powerware 9330 40 (A40401110031112) UPS...
Powerware 9120 BUS Unbalanced error display
I've had this same issue what it boils down to is that the Power IN is not being distributed properly across the Power Outlets.
Step 1. unplug everything from the unit and power the ups down. If the alarm clears itself the UPS is mostly likely fine. if it doesn't not clear send it in for repair
Step 2. If step 1 cleared the alarm try distributing the decives across the outlets differently.
There are two inverters so two output if everything is plugged into one side (ie a power bar with 10 things plugged into it) and nothing on the other side this could cause the alarm.
hope this helps
Dec 11, 2009 | Computers & Internet
Powerware 9330
your problem could be related to a dispay board or possible CSB board.
Sep 24, 2008 | Powerware Invensys 9330 Model 40 UPS...
Powerware PowerRite Plus UPS System Logo
199 people viewed this question
Top Powerware Computers & Internet Experts
Vassilis Chamaidis
Level 1 Expert
Jax Planet
Jax Planet
Are you a Powerware Computer and Internet Expert? Answer questions, earn points and help others
