Question about RCA P52930BL 52" Rear Projection Television
When TV warms up, the sound is scratchy and the image turns snowy, but everything works fine with the DVD player even when warm. the TV works fine when you just turn it on it just happens when it warms up and is using the tuner to receive the image even if I use the tuner in my VHS. RCA P52930BL 52 in. Rear Projection Television
    Sergeant:
  • 337 Answers
You have already diagnosed the tuner as the problem,the first thing to check is the conections at the tuner specially the ground conections,the shell of the tuner is the ground and it conects to the chassis by being solder to it,if all conections check ok look for overheated areas.After that is taken care you still have the possibility of having a bad tuner.If you are familiar with tv service this information will help but if you are not too familiar be safe and call for assistance from a servicer.
Posted on Oct 03, 2006
SOURCE:
I recently purchased a KDL-40W5100 LCD Digital Color TV. I gives a great picture, but when I turn on my Panasonic DVD connected to it I get a blue snowy picture (it worked fine on the old TV)Can you help?
This may be due to a setting on the dvd player itself. What kind of tv did you have previously? Also what kind of connection are you using to hook up the dvd player to the tv? Lastly, if you have the model number for the dvd player it will help if/when you need further assistance.
Thank you,
Lee
Dec 11, 2009 | Televison & Video
Screen keeps blinking red
check the menu and see it it hase the same issue if sone one of the main boards are bad.
May 27, 2008 | Philips 42PF9630A 42 in. Plasma Television
Tunner? Picture whites out
Is this when you are watching a DVD, or Tape, or when watching TV using the Combo's tuner? The effect you describe is caused by the video signal losing its DC level.
Hope Ya Fix it.
Jan 08, 2008 | JVC DR-MV1SUS DVD Recorder / VCR Combo
Snowy screen just pops up
Bad tuner in tv....might be possible to solder bad connect in
tuner...........T.
Dec 14, 2007 | Hitachi 43FDX01B TV
Hitachi screen goes snowy and sound is totally distorted
Sounds like bad solder connect in tv tuner....can usually be
repaired or replaced.......................T.
Nov 30, 2007 | Hitachi 43FDX01B TV
Snowy Picture, Toshiba 42HP84 plasma tv
Similar problem with my Toshiba. I was told it was the power supply and that it would cost about $900 to replace parts and labor
Nov 21, 2007 | Toshiba 42HP84 42 in. Plasma HDTV
MDVD-6838 and Panasonic Plasma TV incompatibilty
1 click SETUP(left just below the four arrow w/ enter button in the middle)
2 click DISPLAY
set tv system to AUTO
tv image to 16:9 WIDESCREEN
video setup (depend on the connection)
s video or RGB
Nov 08, 2007 | Wanlida Group MDVD-6838 DVD Player
1996 RCA Color TV model G27720tn
If you are on cable, first run the cable wire from the wall directly to the TV, eliminating any cable box and/or VCR. If channel 2 is snowy but the rest (especially 3-6) are clear, it is most certainly a cable problem and not a TV problem. The TV uses the exact same circuits for channel 2 to 6 (VHF-LOW) so if the tuner was bad and 2 was snowy, 3, 4, 5 and 6 would be snowy too. Bring a second TV into that room, disconnect the cable wire from the RCA and connect it to the second TV. Is channel 2 on the second TV as snowy as it was on the RCA?
Aug 18, 2007 | RCA 24V511T 24" TV
yes it could ba the cable itself even, but i suspect more the tuner circuit or tuner itself may have bad solder connections. Here is another test for you to try, plug another dvd or vcr, or xbox etc. into the back, using one odf the inputs. See if this works like the built in dvd. if so it will be more likely bad connections in the tuner or surrounding circuit. good luck.
Dec 17, 2006 | RCA HD52W56 52" Rear Projection HDTV
Televison & Video Logo
75 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
