Question about Packard Bell Computers & Internet
I've got a Easynote MV51-120 laptop. The screen keeps flashing and going off and on. Sees like a loose connection. How do I gain access to the ribbon cable to allow me to inspect for loose connections etc?
mana666
  • 38 Answers
SOURCE: ilo 42" plasma flashing screen
sync signal problems
check audio vedio cable
>If all things is ok check CRT
Posted on Dec 04, 2007
SOURCE: I am going to replace ribbon cable. How can I connect cable to face?
The Face cover is snapped in, so you need to use a small flat tipped screwdriver  and run it around the black and silver plastic cover, and it should snap off. Take Your Time!
Posted on Mar 26, 2008
SOURCE: Two Maxtor hard drives -
Essential you have one license allowed and it checks the primary HD via its 'utilities function', and only does a general scan of slave. Since you did not mention Norton version nor your OS general assist here. You might consider going into Options and having it scan both HDs, worked for me.
Posted on Jun 22, 2008
jacklee366
  • 541 Answers
SOURCE: Hi, i have a laptop
dose it come on with out the mp3 in
Posted on Nov 17, 2008
  • 244 Answers
SOURCE: I have comcast cable net and D-link WBR 1310
You must configure the Wireless adapter to the right IP, Gateway and DNS values.
Looks like the Network card is configured properly, that is why you connect when wired.
Please don't forget to rate this answer if helps
Posted on Jul 22, 2009
Loose power piont on my easy note laptop mod no new95
If you are talking about the DC jack in the laptop, it will need to be replaced or repaired, the laptop must be dismantled down to the motherboard level to access the plug.
Jun 07, 2012 | Packard Bell Easynote Tm83-rb-018uk Laptop...
Maytag preforma range model # per5710baw. everytime i push the bake or broil it flashes lock. the stovetop still works but will not let me input a temp. keeps flashing locked. how do i unlock it? it...
Hi
Error code F1 means that an error with the keypad has occurred. Usually it happens due to loose ribbon cable on the keypad or the electronic control assembly itself going bad. To resolve this issue first, disconnect the power to unit and then gain access to the back of the clock assembly (Electronic Range Control/ERC). Now unplug the touch pad ribbon connector from the ERC, it would be a flat wire approx. 1 1/2" to 2" wide and make sure that the cable is not broken and nothing is shorted on the keypad. After this is done insert the cable back and then plug the unit back to check. If the error is still there then the electronic control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 25, 2011 | Kitchen Ranges
The screen on my lap top has had 3 very thin lines across the screen but if you tilt it they go now sometimes they screen fades away and i have to move the screen again this is getting worse could it be...
I'm a laptop repair technician, and in my experience the very thin horizontal or vertical lines are usually caused by malfunction in the display panel and the entire screen has to be replaced. If might be worth a shot for you to try and reseat the LCD cable though, but I doubt that it will work.
Sep 23, 2011 | Packard Bell EASYNOTE R1004 COMPATIBLE...
Hp pavilion dv4 screen will not work. everything
Few trouble shoot solution when it comes to these HP Laptop from 08-09.
1). Remove battery and ram. Plug in AC Adapter and insert only ONE RAM into a slot. Boot up and see if this will turn on display (it work on a HP Dv4-1225dx) IF it works then shut down and re insert the two ram and should be good to go :)
2). If your tech savvy remove keyboard and gain access to LCD flex ribbon cable to check if cable is loose (or go on a limb and replace the lcd flex cable ). I would detach it and re attach the ribbon back to motherboard. ( This happen sometimes by chance)
3). Your LCD is shot dead so it will need to be replaced. Current used LCD can range from $40-$50 and new ones with warranty $60-$100. HP is set up for easy LCD removal so shouldn't take more then 30mins to replace, just be careful when handling the ribbon and inverter cables.
GOOD LUCK
(Fix many HP Laptop for friends and family)
Apr 04, 2010 | HP Computers & Internet
White line on screen easynote mv35-202
It looks like that the ribbon cable connected on the logicboard to your screen is the one that is causing the issue. What you should do is to have it checked by the manufacturer (Gateway) if it still has warranty and if it doesn't have you should take it to a nearest service center that would be able to open the computer and check if the ribbon is loose or damage.
Sep 07, 2009 | Packard Bell iMedia SL 9553 (P660401806)...
Toshiba TE2100, Sreen flashes rapidly on and off, If I tap it on the side, it stops flashing, bu intermitently starts again. Seems lide aloose connection in the wiring to screen, as computer will still...
Sounds like you are correct about the loose connection. There is a thin ribbon cable that powers the monitor.
You will have to download instructions for taking your laptop apart, but once you do, simply reseat the ribbon cable. That should fix it! Good Luck.
Apr 07, 2009 | Toshiba TE2100 Notebook
Laptop screen keeps going fuzzy!
The display connector contact on the motherboard is loose. If you can open the casing, you'll see a ribbon cable from the LCD part connecting to the motherboard. The connector is usually rectangular and connects downwards. Try pressing it in firmly.
Mar 30, 2009 | Computers & Internet
Toshiba screen goes blank when it is opened too far
Sounds like a problem with the ribbon for the screen being either having a loose connection or getting nipped. Pretty common on laptops because the ribbon runs along by the hinges on the base and then up to the screen.
Hopefully you will be able to access the ribbon on your model by removing the plastic bezel which lies just above the keyboard. The ribbons I have seen are about 1/2 inch wide and as I said connect on the base and the screen. The connection just pushes in. If its loose at the connection on the base then obviously push the connection fully home. If it's getting nipped then reseat it so that it does not get caught. ***NOTE*** a problem could arise if the ribbon has actually been damaged from being nipped - opening the laptop could cause it more damage and then you could lose the screen until you replace with a new ribbon. These can normally be purchased on places like Ebay and don't cost an arm and a leg.
If this helps, I'd appreciate feedback so other people can use this as a solution. Thanks
Nov 22, 2008 | Toshiba Satellite M65-S9092 Notebook
System does not boot Possible Hard drive issue
Hiya. Why replace the hard drive? When you say your computer failed to boot - are you sure it wasn't booting? Maybe it did boot but your screen remained blank. It sounds more like a screen problem, quite likely the ribbon connection is loose or it could be damaged. Its a very common problem and tilting the screen moves the ribbon a fraction and it then makes the connection. Try switching on and if the screen is totally blank, no message at all, no flashing cursor then its the screen. If you wanted to be 110% sure, easiest way is to connect laptop to an external screen and test it that way. Hope this is helpful.
Apr 19, 2008 | Toshiba Satellite M45-S2692 Notebook
Acer Laptop with Vista and accessing a wireless network
ok i found a problem like this with my acer lap top that had home basic, if you have the green tab at the top of the screen called " acer emporing tecnology go on that the pic of the world and try to find a solution in there! have fun and good luck
Sep 20, 2007 | Acer Aspire 5100 Notebook
Computers & Internet Logo
56 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
