Question about Toshiba LCD TFT Monitor
Toshiba TFT LCD with refrence number of LTM12C289
Toshiba TFT LCD with refrence number of LTM12C289 is giving whit picture and no data recived from the computer at all
No picture Display when turned on lots of Colour lines, could this be the inverter board problem. the model is Sony TFT LCD Color Computer Display SDM-X72 Serial Number 4530624 Manufactured April...
This is not an inverter problem. The inverter only powers the fluorescent lamps in the back of the LCD panel.
It is probably a fault in the LCD data decoder circuit or a failing connector between the decoder circuit board and the glass LCD panel. If you took it in to a shop, they would probably charge you a full hour's labor minimum - compare that with the price of a new LCD monitor.
Dec 14, 2010 | Sony SDM-HS73P 17" LCD Monitor
I have a HCT 32" TFT LCD HD TV, model number HLD
Your back light is probably out - it may have a bad inverter. Shine a flashlight on the screen and see if you can detect any color or images. If so, then the back light is out. Inspect the inverter for any bulging capacitors. They must be flat on top - if they bulge at the top, then that capacitor is bad.
Dec 12, 2010 | Samsung Televison & Video
CAN WE USE TOSHIBA SATELLITE M35X-S161 AFTER REMOVAL OF ITS TFT ( DISPLAY ) IF YES HOW TO REMOVE TFT ( DISPLAY ) KINDLY ANSWER ?
You don't need to remove the LCD display even if it is not working, provided the video card is OK to use the Toshiba without its display.
Just connect a monitor to the video port on the Toshiba, then power up the monitot then boot up the Toshiba. The video data should automatically switch to the external monitor.
Nov 04, 2010 | Toshiba Computers & Internet
Need LCD screen for Toshiba Satellite A15-S127 15
You can try getting it here: http://lcdscreen.com/ but you should open it up and get the model number and maker of the LCD panel to make sure you are ordering the right one
Mar 18, 2010 | Toshiba 15.0" TFT Laptop LCD Screen
No sound toshiba tecra m3
The Toshiba M3 laptop has an Intel Pentium M 2. 13 GHz processer and 512 MB (DDR2 SDRAM) of memory (although it can support up to 2048 MB). The 36cm XGA TFT LCD screen supports a maximum resolution of 1024 x 768. The internal hard drive can store 80 GB of data. The weight of the laptop is around 2300g and the Lithium ion battery lasts for around 3. 2 hours from a full charge. This laptop has a NVIDIA GeForce Go 6200 PCI Express graphics and has Headphones, Sound card and Speaker(s) audio outputs.
Dec 03, 2009 | Toshiba Tecra M3 Notebook
If i am using outdoor antenna do i need digital converter box on toshiba regza or can i adjust settings?
if your still reciving a picture then your all set...you might want to run channel scan again there have been alot of new chennels added over the air
Sep 18, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
HOW TO REPLACE MOTHER BOARD TOSHIBA ???
if you would go to www.motherboardinstallation.com there is a whole bunch of refrences there that will be able to help you out there ok? best wishes mike
Aug 23, 2008 | Toshiba (K000002020) Motherboard
No display
just remove the ram form the back side of laptop and clean it with pencil eraser and fix it.
Jul 30, 2008 | Toshiba LCD TFT Monitor
Computers & Internet Logo
85 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
