Question about RCA D52W19 52" Rear Projection Television
Bowed in at top and bottom and colors are separated
The colors are separated, you see 3 separt colors, and the top and bottom of the screen is bowed in.
Jandrioti@aol.com
We had the same problem, thought it was convergence. Turned out the mirrors inside fell- they are attached to the top of the cabinet with adhesive. Fortunately it was brand new and Circuit Cuty exchanged it.
Posted on Nov 13, 2008
    Genius:
  • 1,030 Answers
You have a convergence issue. First question in customer menu under setup do you have the convergence optioin? IF you DO NOT then chances are you have the fl231 problem. check under my profile in the tips and trick section. IF you do have the option try autoconvergence. if this fails(goes red screen then you might have a convergence power supply problem.
Posted on Nov 07, 2008
Help with RCA projection TV P46812BL (chasis ptk195AA)
You have probably blown one of the convergence ICs. Effectively the easiest thing to do is replacing the whole convergence board, so that no soldering is involved.
Here you can buy a replacement convergence board, just select your model.
Let me know if you need further help.
Sep 13, 2008 | RCA P52930BL 52" Rear Projection...
Picture bowed & Colors separted
Conversions are out....RCA>>>>>>>>>>>>>check
fuse by the flyback transformer
May 19, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Screen is bowed on top and bottom. What could be our problem? Picture, letters & words blurry.
go to hatch screen adjust all colrs to make white color boxes , also adjusts linear lines
Dec 31, 2009 | RCA Televison & Video
Colors have separated. and top and bottom af pictures are bowed. i have a sony kp-46s55. its about nini years old and it was free. currently the colors are separated and the top and bottom of the pict
nbad convergence ic , this need to be done by a profecional tv tech , because need to check for the pico fuse and resistor around the area
May 08, 2009 | Televison & Video
Double Vision & Bowed Screen
Chances are that the convergence amps are bad.
If those are mounted on a separate board, replacing the board would be the easiest thing to do. Running the magic focus or touching up the convergence in the customer menu may be required.
May 04, 2009 | Samsung HCN653W 65" Rear Projection...
Pt-47wx49e convergence problem
I just replaced the 2 convergance chips, but it did not seem to fix the problem. I then tested all the resistors that feed the convergence chips anf there was a 2.2 ohm fusable blown. IT was R7050 on mine. That seemed to fix it so that I could adjust all the colors through the convergence 2 screen. There seems to be a slight bow near the bottom when you look at the c2 screen, but not noticable when you are watching a picture. Since I got this broken, I am not sure how perfect it should be.
If anyone can send me the service manual, I would appretiate it. Thanks.
Oct 10, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Warped Picture, Separated colors
Each color (red,green & blue) has an amplifier IC (STK-).
When there is a convergence issue,the first step is change both
IC's for reliability. Then check for open fuses devices,usually
pico fuses.Then re-check convergence alignment.......T.
Feb 07, 2007 | Philips 60PP9352 60" Rear Projection...
Bow at top and bottom of the screen
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 10, 2007 | Samsung HCM5525W 55" Rear Projection...
RCA D52W19 52" Rear Projection Television Logo
73 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
