Question about Electronics - Others
Pen drive My Transcend 2gb pen drive is not showing as drive in system but in taskbar it is showing green icon. Also in device manager usb mass storage is showing with yellow mark.
  • 737 Answers
Hi.
If you delete it in device manager and re-detect it, does it change? If you can see it in the taskbar, can you use the eject device icon to eject it, then remove and re-insert the drive?
Finally, try it on someone elses computer and see what result you get.
Mark
Posted on Nov 05, 2008
How do I down load photo's from my Samsung 2 phone please
First make sure you have the correct USB drivers for your phone installed on your pc. Go to device manager and see if your phone or mass storage device is listed. If not, download the drivers here, http://www.samsung.com/us/support/downloads. Make sure debugging on your phone is enabled. Please refer to the following:
  1. To set the Samsung Galaxy S2 to USB Mass Storage (MSC) mode, go into "Settings > Applications > Development" and enable "USB debugging".
  2. Then drag the status bar down and tap on "USB connected".
  3. The "USB connected" screen with the large green Android icon will appear. Tap on "Connect USB storage".
A confirmation dialog box will appear. Tap "OK". The green Android icon will turn orange, indicating that the phone is now in USB Mass Storage mode and should now appear as USB disk drives in "Devices with Removable Storage" and be assigned drive letters.
Samsung Galaxy S2 (Android 4.0)
  1. To set the Samsung Galaxy S2 to USB Mass Storage (MSC) mode, go into "Settings > More... > USB utilities" and tap on "Connect Storage to PC".
  2. Then plug the USB cable into the device and connect to your computer.
  4. A confirmation dialog box will appear. Tap "OK". The green Android icon will turn orange, indicating that the phone is now in USB Mass Storage mode and should now appear as USB disk drives in "Devices with Removable Storage" and be assigned drive letters.
Samsung Galaxy S2 (Android 2.3)
Jan 09, 2015 | Samsung Cell Phones
My Transcend v30 pendrive is not working i had checked it in other computers but it was not working
Sometimes when a flashmemory stick or USB external hard drive fails because it was not removed fromthe USB port properly. If the device is removed byjust pulling it out of the USB port, it can cause the flash device to fail, youmust click on the Safely Remove Hardware icon on the Task Bar and select thedevice you wish to remove and only do so when instructed to do so When the flash memoryUSB hard drive device appears to malfunction it maybe possible to restoreit by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - AdministrativeTools - Computer Management - Disk Management. Then right click on Disk 1removable drive and click Format. After the flash drive has been formatted itwill indicate that it is Healthy.
Apr 23, 2011 | Transcend (589307) Media
How do i remove write protection from my kingston datatraveler G2 2GB? thank you for your assistance
click start control panel administrive tools computer management disk management right click on your drive select properties then security select take full control in windows 7
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
don
Feb 24, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My transcend 2GB pen drive is detect only in linux only
First, try the cord and the I POD on another machine. If that all works, then it's the machine. If that's the case, try this:
Unplug ALL USB devices.
Open Device Manager.
View, Show Hidden Devices.
Uninstall all devices under USB Controllers.
Uninstall all devices under Storage Volumes. Say no to any reboot prompts until you are finished. Also, if a Storage Volume doesn't uninstall, ignore it and move to the next one.
If you have a yellow ? with unknown devices, uninstall all of the entries there as well.
When this is done, reboot TWICE.
Reconnect the USB devices and see if they're recognized properly.
Please rate me if this solution works for you
Thanks......Have a great time
Jul 06, 2010 | Transcend (589307) Media
PEN DRIVE NOT OPEN
what problem you are facing with your pen drive? are any error message you are getting when you try to open your pen drive? please send us your problem in details.
Apr 13, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Sony microvault 2 gb pen drive- can not copy file- I/o device err
My 2gb sony microvault is asking me to format. It is teeling me that it is write protected. How do I format it
Apr 16, 2009 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
Mass storage device not working
transend pendrive not recognized
Feb 28, 2008 | Electronics - Others
Transcend pen drive 2GB not getting detected
Sir: Transcend pen drive 2GB not getting detected Can you suggest anything?
Feb 27, 2008 | Transcend (589307) Media
Electronics - Others Logo
70 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
