Question about Microwave Ovens
Hi there - need to open up my Samsung M7145 microwave to change the oven lamp which has blown. Any idea on how to get access?
    Champion:
  • 224 Answers
Hello ,
remove lamp form inside microwave oven . put new lamp , this very easy to remove, oven stop cover open also very easy . this lamp easy to get any electrical shops.
Posted on Nov 06, 2008
How do I change the light bulb?
It is hard task.
  • You will need special tools, e.g. Torx screwdriver (star) and other
  • Be careful. Oven must be disconnected from mains.
  • The disassembling is complicated and procedure consist of more steps.
  • Microwave oven lamps bulbs are very special. They often do not have usual lamp cap. See Microwave Oven Lamp Bulb with Base
  • Watch this video as example what will your task:
Microwave Oven Lamp Replacement Samsung T170 Light Bulb UK
Some oven lamp types:
Home Office Light Bulbs Microwave Bulbs
Jan 28, 2016 | Microwave Ovens
How do I change the lamp in my Kenwood Simplicity microwave?
The lamp is accessed by removing the outer cover of the microwave oven. Hazardous voltages are exposed by removing the cover. Remove the lamp and install the replacement.
Feb 15, 2015 | Kenwood Microwave Ovens
The bulb has blown on my microwave, can it be changed
Replacement of the lamp should be carried out by a qualified appliance repair service.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
But here is a basic method if you are mechanically minded and have electrical safety knowledge.
The lamp is sat in a housing and its position is adjacent to the vent holes that it shines through.
If you feel confident, disconnect it from the mains power, remove anything in the cavity.
Remove the microwave cover. Purchasing a new replacement lamp will be useful as it will give you an idea of what it looks like. Locate the dead lamp remove the lamp and fit the new one. Replace the covers. Plug it back in and try the lamp by opening the door.
Hope this helps.
Mar 26, 2011 | DeLonghi Microwave Ovens
HOW TO CHANGE OVEN LIGHT
Hope this helps.
Feb 17, 2011 | Samsung 80092 Microwave Oven
I have microwave oven model no EM-C8787B and light bulb has blown and am trying to detect it I take it i will have to take outer cover of can u help it would be most appreciated
Hope this helps.
Feb 14, 2011 | Sanyo Microwave Ovens
I can not find a model number on my microwave but I know it is 800 watts/convection. Can you please tell me how to change the light bulb - I have removed the glass covering but cannot see how to access...
I would browse the manufacturers web site until you find your mode.
The bulbs are normally accessed from either an inspection cover in close proximity to the lamp or by removing the outer cover.
Hope that helps
Dec 23, 2010 | Neff H7871 Convection/Microwave Oven
Microwave not heating!!!!! Probably Magnetron malfunction. New replacement Magnetron cost, fuse blown out and cost of internal oven lamp?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Oct 25, 2010 | Sharp Microwave Oven Microwave Oven
How do I replace the light bulb ? \r\nI try to open in rear but saw 3 warning lables, plug I don't have tool to remove those screws. What can I do ? Please help thanks ian
There is no mention of lamp replacement in the manual. You should be able to access the lamp IF you unplug the oven and let is sit for 30 minutes or longer before removing the screws. Since there is no info on the lamp, it may be of a type that is not user replaceable (simple push in or screw in type), or is not readily available.
You may end up having to contact Samsung (number is in the manual) to obtain the lamp - or they may not wish to sell to the consumer - which would require a service man perform the work. You'll also need to buy the tool to remove the screws, too. Maybe you can live without the light.. or get it fixed or replaced entirely. A service call may cost more than it's worth.
Sep 14, 2010 | Samsung MW1080STA Microwave Oven
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
MICROWAVE BULB
Hi There!
Most microwave ovens today requires you to remove the cover to replace a lamp. Normally situated next to the Magnetron. Check the inside cavity for tiny holes where the light is suppose to shine through. This will indicate where the lamp is situated. Remember to unplug from mains before opening the unit and try not to touch the High Voltage components. They may still be charged. Good Luck, JUS004
Feb 26, 2008 | Microwave Ovens
Microwave Ovens Logo
111 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
