Problem with controller time display no working properly
I am having problems with the above in that the clock is loosing time no matter how many times I reset it and I now have to put my heating onto constant everytime I want it on, will I have to buy a new time controller? is the rechargable battery replaceable? do I need to replace the unit? how easy is it to replace with compatable new controller? The heating controller is about 20 years old? Any help grately appreciated.
    Problem Solver:
  • 8 Answers
Is there a model number I might be able to help you
Posted on Nov 05, 2008
Analog clock don't work
I am not familiar with Mondeos, but usually analog clock works all the time.... no matter if ignition is on and off..... ignition usually just turn on and off backlight of clock.... so I would check for fuse or some loose connection leading to clock..... check if you have power for that clock with ampermeter
Feb 16, 2016 | 2007 Ford Mondeo 2.0
HOW TIME ADJUST TIME ON PIONEER DEH335OUB
This is for the DEH-6800MP
Press function repeatedly until "clock" appears in the display.
Pressing will select hours or minuets segments on the display
Hour - minute
As you select segments of the clock, they will blink.
Press up or down buttons to change hours or minutes as selected above.
If that doesno't work, this should
Turn on your car ignition. Turn your car stereo "OFF".
  • 2 Press and hold the "MULTI-CONTROL" button (looks like a round dial) for a few seconds until the display pop up. Rotate the "MULTI-CONTROL" button until it says "CLOCK." If you have an older model without a "MULTI-CONTROL" button, press and hold the "FUNCTION" or "AUDIO" button until the display pops up, then immediately release the button. Press the "FUNCTION" or "AUDIO" button again until the display reads "CLOCK."
  • 3 Push the "MULTI-CONTROL" button upward and downward to adjust the hours and minutes. For older models, first press the "UP" and "DOWN" buttons to adjust the hours. Use the "LEFT" and "RIGHT" arrows to move to the minutes, then press the "UP" and "DOWN" buttons to adjust the minutes.
  • 4 Press the "ESCAPE" or "SOURCE" button to exit.
  • In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
    If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
    May 30, 2011 | Car Audio & Video
    Red light above radio dial is flickering; radio/clock/cd /dvd/playerdo not turn on or if the radio trurns on- it turns off in a matter of seconds
    could be loose plug to radio ,loose fuse loose antenna If you are gettin power to the radio plug all the time with the key on it's the radio, you can pick one up cheap out of a wreck
    Feb 26, 2011 | 2005 Chevrolet Uplander
    My bosch oven - HBA 13B250B is not displaying the clock real time any more. The oven still works. I can't find my instruction manual. Any ideas how to reset the clock
    To change time on your Bosch oven, please do the following:
    1. Press the clock icon (above the MINUS (-) button repeatedly until the clock icon on the display illuminates.
    Please note: There are 4 illuminated icons on the display above the time. There are 3 which have clocks on them. You need to make sure the 4th icon (on the far right) is illuminated on the display.
    2. Use the "+" and "-" buttons to set the clock to the correct time.
    Once you have set the correct time, the oven will return the displaying the time and the illuminated clock icon will disappear. You do not need to press anything to confirm the time is set.
    If you are still having difficulty, please post back for further assistance.
    Regards,
    BElectric
    Dec 31, 2010 | Bosch Ovens
    Clock has gone blank after a week of flickering on and off
    It sounds like the LCD portion of your clock is going bad; I have observed this in the past. A new clock is in order; there are no repairs that can be made to the clock; it is a sealed unit.
    Sep 17, 2009 | 2003 Toyota Corolla
    Need to set clock
    1) Press the center of the multi-control button (big round knob) once to display the settings mode which appears on the digital display of the stereo unit.
    2) Turn the multi-control to until the display shows clock settings.
    3) Press the control ONCE to enter this menu.
    4) The display wish show the 'Hours' flashing - turn the control to adjust this setting to the correct hour and press the control once to select.
    5) The "Minutes" will not be flashing - turn the control to adjust this setting to the correct minute (time) and press the control once to select.
    6) Locate the "band/esc" button on the bottom left corner of the stereo face and press once to select and exit the settings.
    The clock should now be set. NOTE: There are a LOT of different models of Pioneer car stereos and they will not all have the same menus. The above steps should work on the newer systems.
    Sep 05, 2009 | Pioneer Car Audio & Video
    Digital clock display read out is EXTREMELY dim even after adjusting brightness and contrast controls
    Hello Jinx55,
    the problem is the display unit itself or the cable that goes from the display to the electronic (Most likely the dispaly itself).
    The display will need to be replaced. You can contact Miele directly at
    (800) 843-7231
    May 19, 2009 | Miele Coffee System
    JVC KD-G200 cd player
    I would suggest checking the accessory (red wire), the yellow is a constant feed from the battery, which will allow the clock to be displayed no matter what. The accessory wire is what is used to turn on the cd player. You may need to restrip the red wire and check the lead going to the red wire with a test light to make sure it is getting a voltage light.
    Mar 03, 2008 | JVC KD-G200 CD Player
    Want a clock setting on my display window
    According to the manual, in STANDBY MODE, push the control knob towards FM or AM and select CLK ADJ. Press the control knob for at least 1 second, the clock display blinks. Adjust the hours by pushing the control knob towards FM or AM, and the minutes by pushing the control knob right or left. Exit CLK ADJ mode by pressing the MENU button. Hope this helped.
    Feb 07, 2008 | Kenwood KDC-MP235 CD Player
    Daylight savings time again
    Appparently the problem could be with your location, or just that there may be a delay before time correction until the old date - check again the link to amazon i posted before - there are a couple of new reviews that discusss the daylight saving issue, also - The US clock says; "I have a radio controlled clock that receives NIST time. Will the new rules affect me? Your radio controlled clock should automatically implement the new DST rules. The WWVB broadcast contains information that tells your clock whether DST or ST is currently in effect. NIST always sends this information to agree with the current DST rules, so your clock should change automatically on the day of the change, just as it has in previous years. If the time is wrong after the DST change, make sure that your clock has recently received the time signal. Many radio controlled clocks have a synchronization indicator that will tell you if your clock has recently synchronized. If the clock isn't receiving the signal, click here for some tips on improving reception. If it has received the signal recently, check to make sure that the clock's time zone setting is set properly. Also, if you live in an area where DST is not observed (Arizona, for example), you need to disable the automatic DST function on your clock. I have a non-radio controlled clock that used to automatically correct itself for DST. Will it still work? The only way to find out is to wait and see, or to contact the manufacturer of the clock. There are a large number of non-radio controlled clocks, marketed under names like "AUTOSET" or "SMARTSET" that have internal firmware that automatically changes the time by one hour on the transition days to and from DST. These clocks do not connect to a NIST time service, and some of them will no longer work properly due to the DST rule change. For example, clocks manufactured prior to the rule change will probably not switch to DST in March, but will wait until April in accordance with the old rule. If you have a clock like this that fails due to the new rules, your only recourse is to adjust the clock manually, or to contact the manufacturer and ask for an upgrade or a replacement. If you need to contact manufacturer check http://www.emersonscott.com/ezsetamclocr.html Hope this helps:)
    Mar 11, 2007 | H.H. Scott SCR120 Clock Radio
    Computers & Internet Logo
    David Payne
    David Payne
