Question about ASUS WL-330G 802.11g/b (wl330g) Wireless Access Point
Reset my wireless asus wl-330g ip
Hello, how can i reset my wireless asus wl-330g ip, how long i should press it, and may it be risky for long time?, i tried to press it for 30 sec but nothing happend, thank you
  • alaanet Nov 06, 2008
    Thank you very much you've been helpful
Reset device by holding the reset button for 10 seconds. Then turn off for 10 seconds and plug Ethernet cable into PC and turn on.
Posted on Sep 27, 2012
    Scholar:
  • 53 Answers
Due to the different modes that the unit can operate in I suggest that you take a look at the user manual. The index for the numerous manuals is at the following link;
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=WL-330g
it seems that the magic number is 5 seconds, but it depends on what type of reset you want!
Posted on Nov 05, 2008
I use the Asus WL-330ge as a network adapter for my HP Printer. This worked perfectly until I switched internet providers. I changed the IP on my printer to the same subnet as my new wireless router...
Let me state how I think you have this setup
Printer is Ethernet ---------- Ethernet (WL-330GE wireless adapter)
WL-330GE adapter >>>>>> Wireless >>>>>> New Router
eth_adapter_mode-d2r1efs5ntrf2rjwzg4ldeyi-5-0.jpg Diagram and mode is from
https://www.asus.com/Networking/WL330gE/HelpDesk_Manual/
ASUS WL-330gE user's manual in English
So I think you need to use Ethernet Adapter Mode !
The computer shown would be your printer
As you are using wireless you need to set up the wireless ssid and the wpa or wep encryption to match the new router I am guessing .
in section 4.3 advanced settings in the above manual link from ASUS.
Also the access point has an ip address by default as 192.168.0.1 255.255.255.0 you would have to most likely have 176.16.1.2 and the new router as 176.16.1.1 and the same subnet mask what ever it is maybe it is 255.255.255.0 then make the printer 176.16.1.5 subnet 255.255.255.0 or whatever subnet you use.
Make sure you log into the new router and alter the DHCP server to assign leases from 176.16.1.10 to 176.16.1.254 with same subnet mask.
Mar 31, 2017 | ASUS WL-330G 802.11g/b (wl330g) Wireless...
Hello, I am Gabi from Germany, I can't reach your browser 192.168.1.220 neither 192.168.178.220. I wanted the asus WL-330 gE as repeater and can't configurate it without browser. Thanx for...
Are you sure that is your WL-330's ip address? If you are, I suggest you reset it then try to configure it again. You can reset it through the reset pin hole. Press and hold it for 15-20 sec. Then try accessing the setup page again using the default.
Hope it works for you.
Jul 30, 2011 | ASUS WL-330GE 802.11b/g Wireless Access...
Miss password and user name
To reset the device to factory defaults, hold down the button on the device for 5 seconds. You can then setup the device the same way you did when you first got it.
Apr 30, 2011 | ASUS WL-330G 802.11g/b (wl330g) Wireless...
How i can protect my asus wireless wl-330g with password?
In the set up menu it should have the area to set it up. The longer and stranger the password the harder it is to break.
NO words, NO 1234 type numbers, etc,.
It should be random numbers and letters with capitals mixed in with them.
Another way would be to say a sentence ,say like," the cow jumps over the moon", take the first (or second or what ever) letter of each word,,,, tcjotm,,,,, something like this and add some numbers, just make it so only YOU know what it is and you should be able to remember it that way.
Jan 05, 2011 | ASUS WL-330g (90I2B2E02IAZ) 802.11b...
Access point configuration
Access is easy to configure, you just need to understand basic setup you need to do and just have to find the same options on the configuration page of any wireless access point.
Things to setup.
1. Local IP Address ( You will get default 192.168.1.1 according to your device guide, still you can set different (not recommended, if not expert) )
2. Setup WAN IP-This could be dial up connection (PPPOE) or Internet IP Address provided by your internet provider.
3. Setup Wireless access point SSID, this is what you will find when you scan for wireless connection available
4. Setup security settings. You can setup WPA or WAP to protect security. Just need to select and assign key/password which you will be asked while connecting SSID
Follow the link for exact information on how to setup your Access Point
http://www.tomsguide.com/us/asus-wl-wl330,review-233-3.html
http://support.asus.com/faq/asus-faq.aspx?no=E8D3A5FD-995C-D299-0AE3-FBF28AA04DA6&SLanguage=en-us
http://www.ddp.ru/upload/images/PDF/WL_HDD25.pdf
Hope this helps
Jun 02, 2010 | ASUS WL-330G 802.11g/b (wl330g) Wireless...
Wont turn on asus wireless ap wl-330g
check the power adapter may be thats gone faulty
Jan 16, 2010 | ASUS WL-330G 802.11g/b (wl330g) Wireless...
FN + F2 did not function in my ASUS laptop.
Restart> press F2 on boot = BIOS
Wireless device > ENABLE
Mar 14, 2009 | ASUS WL-330G 802.11g/b (wl330g) Wireless...
Connection problem
Firmwares are designed for each particular product. 330gE firmware will be invalid for 330g. Maybe ASUS is coming up with a new one. have you tried checking lately? It is usually published thru the net. If it's already a recognized issue for the product. manufacturer will be posting one in no time.
Oct 09, 2007 | ASUS WL-330G 802.11g/b (wl330g) Wireless...
Limited or No Connectivity
Yes, the wireless adapter can be fixed, by replacing the motherboard.
Jun 09, 2007 | ASUS WL-330G 802.11g/b (wl330g) Wireless...
ASUS WL-330G 802.11g/b (wl330g) Wireless Access Point Logo
1,743 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
