Question about Samsung SCH A950 Logitech Bluetooth Over the Ear Headset with AC Adaptor Headset
Internal Screen When the phone is powered up, the internal screen is lit up but it does not display anything on it. The external screen works and all functions on the phone work. I have been told that the connection between the main body of the cell phone and the screen could be loose but I do not know how to open the phone to look or to resolve.
  • 61 Answers
You may have to take it into a computer technician if you want to open it!
Posted on Nov 10, 2017
bomark2002
  • 160 Answers
SOURCE: No Sound on TV??
I would borrow a set of external speakers to see if I could get sound from the sound circuit at all, if not, then it sounds like the repair shop.
Posted on Oct 21, 2007
Bajanguru
  • 7752 Answers
SOURCE: White Screen No Work
have the LCD/screen replace...take it to a mobile tech and have that done.
Posted on Jan 01, 2008
  • 14 Answers
SOURCE: display not coming
it sounds like your cable ribbon has got a hairline crack in it just replace that and it should be fine m8.
the usual symtoms are the screen just goes white if not no display at all !
Posted on Nov 19, 2008
Santhosh_7
  • 233 Answers
SOURCE: Dell Latitude D600 display problem
I recommend you to update your video drivers.
Please visit the below link for more information:
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&dl=false&l=en&s=gen&docid=47B421B3EDBD05B4E040A68F5A28777D&doclang=en&cs=
Posted on Jun 29, 2009
  • 87 Answers
SOURCE: Display problem
If formatting your phone doesnt help there are three possible problems in order of priority (1) your screen is gone and needs replaced (2) your ribbon cable is gone and needs replaced (3) phone needs flashed, I have repaired the first two above on many samsungs with this fault! Not an easy job! Hope this helps.
Posted on Jul 14, 2009
My samsung cell phone is a R740cthe it trurs on an shows samasung on the screen then gos blank an screen stays lit up but shows nothing it was working one moment not the next ?
THIS WOULD PROBABLY BE AN INTERNAL PROBLEM YOU PROBABLY CANNOT FIX.SOME TYPE OF INTERNAL CONNECTION OR GROUND.YOU PROBABLY WILL NOT BE ABLE TO DO ANYTHING UNLESS IT IS UNDER WARRANTY
Jul 14, 2014 | Samsung Cell Phones
My Dell Latitude D630 has a blank screen.
Check your hardware light on the exterior of your computer and see if it is lit and blinking. If it is, you have an operating system, but just can't see it. That tells me it may be several things:
1. The LCD cutoff switch is in the off position
2. Toggle (Fn) the display to the internal settings of the LCD panel. It may be set to display an external monitor only
3. Plug in an external monitor. If it doesn't display on the external, after pressing the Fn key you have a failed video adapter. If it does display on the external it is most likely a back light or inverter failure.
Apr 05, 2012 | Dell Latitude D630 Notebook
No display
The following applies to Acer Laptops...
If the power indicator is lit but nothing appears on the screen - The computer's power management system automatically blanks the screen to save power. Press any key to turn the display on.
If pressing any key does not turn the display back on, check the following....
1. The brightness level might be too low. Press Fn and the right cursor key to increase brightness level
2. Display device might be set to an external monitor. Press Fn and F5 to toggle to the internal display
3. Backlight might be turned off. Press Fn and F6 to turn on the backlight.
4. If the Sleep indicator is lit, the computer is in Sleep mode. Press & release power button to resume.
May 09, 2011 | Acer Aspire One PC Notebook
Power is on but no signal output to the screen
The following applies to Acer Laptops. You did not specify the brand of laptop you had. If your laptop is not Acer, the specific keys mentioned may be different and you should adjust accordingly.
Apr 04, 2011 | Computers & Internet
When I power up my laptop the screen does not show anything. It is just white screen no windows log or bios when the computer is booting. I can connect an external monitor to the laptop and the see that it...
You've got a loose connection between the laptop and the internal screen. Take the computer to a qualified technician, tell him/her the symptoms, especially the part about the external monitor working fine, and pay the technician to fix it.
Oct 27, 2009 | Acer Aspire 4315 Notebook
Blank display
when i turn on the phone both internal screen and external screen is blank please help me
Sep 16, 2008 | Motorola Mobility i850 Cellular Phone
Aspire 5102 WLMi display replacement
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 10, 2008 | Computers & Internet
External Display Screen
you just need to get the external LCD replaced...not to worry most lcds on the v3 you can take out the external lcd without replacing the entire lcd....so take it to a repair center close to you.
Dec 20, 2007 | Motorola Mobility RAZR V3
Front display is blank
this is a tech fault which will require a tech to deeal with it hands on
Dec 09, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Internal screen is white
NO YOUR DISPLAY IS DAMAGED YOU HAVE TO CHANGE UR PHONS DISPLAY AND IT WILL WORK EVEN CHANGING THE DISPLAY IF IT DONT WORK CHECK THE DISPLAY CONNECTOR.
Nov 23, 2007 | Motorola Mobility E815
Samsung SCH A950 Logitech Bluetooth Over the Ear Headset with AC Adaptor Headset Logo
32 people viewed this question
Top Samsung Radio Communications Experts
Bobby G
Bobby G
Damen Wong
Damen Wong
Jerry Greenberg
Jerry Greenberg
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
