Hi I have an Maraantz PM -50 trying to use it as a pre amp for my son;s DJ all of a sudden the right channel has stop other than a hum, left is fine is it worth getting fix ??
  • 1,512 Answers
If it is the pre out that the hum is coming from, it will probably just have dry solder joints to the RCA connection to that channel. Easy fix, but you will have to pull the entire bottom chassis of the amp to get to them. That particular model does not have a removable bottom. No biggy, just take all the screws out of the back, bottom and around the front escutcheon as well. Leave the transformer attached to the bottom though and just lift the PCB clear to get to the sockets across the back. If you have any questions about it, just ask away :)
You may even be able to get in there enough to resolder the rear connectors by removing the entire back panel even. I remember fixing heaps of these amps. They blew outputs regularly.
regards
robotek
Posted on Nov 04, 2008
Trying hifi news test record for new at150mlx and get stopped in the first track. hear voiece from left but when it comes time for the riight side voice, i hear it faintly on the left speaker streo plays...
Sounds like it could be a connection problem. Hear's a simple test. Disconnect the leads to the cartridge (make a note of which wires connects with the cartridge). With your amp switched on. Touch with your finger (one at a time) each wire. You should hear a decent buzz on two of the wires - one wire for the right, one for the left. If you don't hear a buzz or it's weak, then there's nothing wrong with the cartridge, but either the cable between the amp and turntable is faulty or the amp's pre-amp has a fault. You can eliminate the pre-amp by switching the leads over. If the fault now goes to the other channel, it's the lead. But if it stays on the same channel, it's the pre-amp that's faulty.
If both channels buzz fine, then you either have faulty cartridge or a bad connection to the cartridge with the wire to it.
Dec 18, 2013 | Audio Technica AT-PL120 Turntable
NAD C320. Only one channel sounds. Problem with the volume control?
Did you try to switch the loudspeakers? Before changing anything always lover the volume and switch off the amplifier.
Assuming you tested already different inputs, you can be sure no cable from signal source is out or defect. (or did you nit check that first?).
When the amp is switched off, disconnect the speakers and switch left to right and right to the left output.. If the other speaker is quiet now, you are sure it is in the amp. Still his can be anything.
You can check the connections between the pre and main amplifier on the back side. When you have an extra set of interlink cables, perhaps you can cross the in and output there too. Take care every time you change something, lower the voltage and switch off the amplifier. Sudden clicks when switching on or changing anything can damage the amp and or the speakers.
Perhaps when you checked this you can locate where the problem is? Speaker, speaker cable, power amp, pre amp, (only a part of the pre amp.
Nov 12, 2013 | NAD C320 2-Channel Amplifier
B&K AVP2000 left channel not working
Yes amps buzz when something gets near them - say a pen or probe and if you know what it is safe to touch a finger! Fortunatly for you the left channel is the same as the right. So if you believe it's the pre-amp work backwards from the where the power amp connects to the pre-amp, going through the pre-amp stage by stage - prodding the parts. Remember a buzz in the right a buzz in the left! No buzz in the left but one in the right fault found!
Ignore the power supply it's nothing to do with that as it's common to both channels.
Dec 30, 2012 | Audio Players & Recorders
No sound from left channel.
hi
first of all you can check either amp or pre is defect. for this change wiring left to right and right to left (pre to amp wiring). if still left channel has no sound the problemmaker is the amp. would be helpfull for further assistance if i know the model number.
regards
Feb 09, 2011 | NAD Audio Players & Recorders
I believe I have lost the left channel on my GII. Is that a common difficulty? How can I verify that is the problem? I've had this unit for 7 years. Right channel continues to pump out sound and...
No just the cartridge perhaps! First disconect the wires to the cartridge. With the amp on. Touch the end of the wires one at a time (don't worry you won't get a shock). On two of the wires you should hear a hum on each channel (one for left one for right). The left channel should hum. If it doesn't it's not the cartridge, but either a faulty lead or the left phono pre-amp is faulty on your amp. Test the amp by putting the right in the left channel.
If the left hums the cartridge is faulty.
Jul 24, 2010 | Gemini SA-600 II Turntable
Yamaha m70 amp and c70 pre-amp right speaker stopped working
First, lets's determine if it's the amp or the preamp...
Swap the Left and Right channel cables between preamp and the amp with each other.
Did it stay on the right? = amp problem.
Now on the left? Preamp or source.
Plug any Line Level device (CD?) directly into the amp inputs. Work now? Preamp problem.
ALL sources? Preamp - toggle all controls, especially a Tape Monitor to possibly wipe of any built-up oxides in them.
May 31, 2010 | Audio Players & Recorders
I have a MPA 201 2 channel amplifier that just stopped putting out power, power light is still on, any suggestions?
You need to determine if the power is getting to the audio amp section. For instance with the volume full up is it humming etc?
As a 'rule' it's unlikely that both left and right channels will fail at the same time (unless you have done something silly with the amp) you are looking for something that is common to both channels. Which is why the power section is first suspect. The exception to the rule (above) is where amps use say an IC power amp for both channels. You will find this IC on the big heat sink. Check whatever is on that anyway for damage or burning.
The only other area could be the pre-amp part. Again this could be a single IC controling both channels, so it's failure could cause a loss of sound. By the way if you can hear music/sound coming through when you put it up to full volume the pre-amp will be generaly good.
Nov 16, 2009 | Jamo MPA201 2-Channel Amplifier
No sound comes out of the left pre outs
It sounds like the preamp wire that carries the left channel signal between the HU and the 2ch amp has an issue. Here's two quick things to check.
  1. Check that both ends of the left preamp cable between the deck and 2ch amp is not loose or disconnected.
  2. Swap the left and right preamp connections at the amp. If the issue stays with the left channel, the issue is with the amp. If the issue moves to the right channel, the issue is with the preamp cable or the HU's preamp output.
Let me know what you find out!
Mar 13, 2008 | JVC KW-AVX800 CD Player
No right channel output
Feed the amp with the left channel preamp to the right channel input on amp and check output. If you get output from amp then pre amp nedds to be checked out if still no output then amp is suspect. Randy
Feb 16, 2007 | Bryston BP-25 Amplifier
22 people viewed this question
 Grubhead
Grubhead
