Question about Philips LX700 System
I connected optical source toslink to lx700 and have no sound
I connected optical source toslink to lx700 input and have no sound. When increasing or decreasing lx700 volume sound goes up for a moment and then disappears. Coaxial SPDIF connection works fine. Whether it may be the cable issue or something else? The cable was tested on Yamaha receiver at the shop and worked well.
  • 5 more comments
  • Anonymous Dec 09, 2008
    Exactly the same.... were there somebody to help?
  • Mel7421 Dec 09, 2008
    Hi there
    We do have the same problem.... did you solve your problem already? Would be great to hear the solution :-)
    Thanks
    Mel
  • Anonymous Dec 29, 2008
    I have the same problem, too.
    The default setting is coaxial input,
    I don't know how to change the input to optical. The screen always show "coaxial".
  • paperlung Dec 31, 2008
    Exactly the same. Coax works fine, toslink gives me nothing from either PS3 or satellite tuner. Optical cable works fine.
  • pennylau Jan 07, 2009
    I have make a call to philps service hotline, they will give me a answer later!
    If I know the solution, I will post it later.
  • vinser Feb 17, 2009
    Hi all.
    The issue was settled by replacing damned Tomson cable to brand Philips one!!!
    And before replacing cable check that you have selectet the optical input. Enter a menu by "Programm" button on the front pannel and select "Optical" from "Digital input" option. This is inconvinient because you can't do this by remote control.
    Good luck
  • ananthi_sasi
    ananthi_sasi Jan 05, 2013
    I am also having same problem on LX700. The coaxial cable input works fine...where as Optical Cable input does not. I can see RED light appearing in optical cable...but when i insert to LX700 Philips receiver, i don't see any detection of input sound. please help me to resolve it.
"programm" button on the front panel for 5 seconds,then choose digital input with left or right arrows button,prees "programm" button again,then change coaxial to optical with volume control on the front panel. then just confirm with "programm" button again and quit the menu.
Posted on Jun 07, 2010
  • ananthi_sasi
    ananthi_sasi Jan 06, 2013
    VERY USEFUL AND WORKED GREAT!! I followed these steps and it did not work for a while ...until i power OFF and ON after setting the new setting changes.... THANK YOU SO MUCH for giving these sets that can be done on the receiver itself without REMOTE.(where i have misplaced it).
Here's a link to the User's Manual PDF. Read page 13.
http://www.p4c.philips.com/files/l/lx700_21s/lx700_21s_dfu_eng.pdf
Problem solved!
Posted on Jan 08, 2009
Press the system key on the remote,
find the digital input option,
choose optical,
finish!
Connect tv to surround sound system
Connect a RCA cable from the TV Audio output (red/white)
to the surround sound Audio Input (red White)
If your TV has a "HDMI OUT" and your Surround System has a
"HDMI Input" Then use a HDMI cable instead.
You will need to set the source on your Surround System to
the audio source you use on the surround system(input)
On most it will be TV or Auxiliary.
Sep 30, 2014 | Samsung "UN46D6000 46"" LED ""SMART"" TV "
Connect Apple tv to Philips LX700
OPTION 1 (using remote):
choose optical,
finish!
OPTION2: (Using LX700 button)
"program" button on the front panel for 5 seconds,then press LEFT or RIGHT button to choose DIGITAL INPUT,and Press "program" button again,then change coaxial to optical by rotating VOLUMN control on the front panel. then just confirm by pressing the "program" button again and wait for 5 sec to quit menu. Now switch OFF and switch ON receiver again.
Now make sure the source id DISC IN (ie., digital input ).
Your LX700 should be picking up optical signal!!
It worked for me and i hope it works for you to as well.
-SASi (ssasi2000@gmail.com).
Dec 15, 2012 | Philips LX700 System
Connect with componet cables.
The only digital audio input for this TV will be via the HDMI input. Of course, even with HDMI in, you're only going to get a simple stereo output from the TV. You can use the analog L & R audio inputs for a very similar sound from the TV speakers.
The digital multi-channel audio (Dolby Digital, THX, 5.1, 7.1, etc) encoded in the program should be connected to a suitable multi-channel amplifier with either a TOSLINK (optical), RF (coaxial) or HDMI cable for theatre-like sound. This can be done by (a) cabling from the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) directly to a multi-channel amp and speakers, or (b) from the HDMI output of these devices (DVD, BluRay Disk, Set Top TV Tuner, etc.) into one or both of the TV's HDMI inputs. This will provide only stereo sound output from the TV speakers. You should connect the TV's TOSLINK optical "Digital Output" jack with an optical cable to the amplifier's TOSLINK optical input jack to obtain theatre sound.
To listen to the program shown, you would select the amplifier input assciated with the optical, RF or HDMI input that is connected to the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) if connected directly. If the TV HDMI input(s) are used, they are output to the TV optical output and should be connected to the amplifier optical input. The amp input associated with the optical input should be selected to hear the program with theatre-like sound.
Dec 13, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
Cant get opticle sound to work
From what source? Is IT operating correctly.
You must assign the optical input to the source before you can use it.
More in a minute...
Mar 07, 2011 | Philips LX700 System
How can I hook up my Bose cinemate on my Philips HD tv when no there is no Audio out and I want to use it for my dvd player, cable box, and video systems?
You don't need to send audio TO a TV. I's a TV, not a source of anything. Many of us use monitors (no TV speakers). The Bose speakers are presumably superior to the TV speakers so whatever the TV is watching (cable/sat/dvd) shuld have its own audio.
Page 11.
If your TV does not have any audio output jacks, you can connect the CineMate™ speaker
system to the audio output jacks of another source, such as a DVD player or cable/satellite
box. However, you will hear sound only from the connected source through your CineMate
speakers.
http://www.retrevo.com/support/Bose-Cinemate-Speaker-Systems-manual/id/526dj591/t/2/
Dec 25, 2010 | Bose Cinemate Digital Home Theater System...
Dual 2.5 GHz PowerPC G5 sound output
This is just how it works. The headphone jack on Macs is dual-purpose. If you plug in a mini-Toslink cable (like you have) it automatically sends the sound through that & increases the computer's volume to maximum. When you unplug the Toslink, the laser will still shine for a brief moment (but then it does go off). So, there is no way to keep the Toslink plugged-in AND utilize the built-in audio at the same time.
Mar 27, 2009 | Apple Power Mac G5 Desktop
Volume when on tuner is very different than when on DTV
Under the input menu, there is a volume trim function which allow you to increase or decrease the volume level of each input. It is designed so that the volume of different components can be matched to prevent a blast of sound when changing to a lounder output. You can increase the alevel of the dtv input, and decrease the level of the tuner. Tuner volumes are usually high.
Jan 24, 2009 | Yamaha RX-V1400 Receiver
Different sound levels dvd and cable hdtv yamaha htr-6130
Well, first of all, the method you are using is the lowest quality. You should upgrade to a toslink(digital optical cable) or a digital RCA cable. The toslink is the best all around. But it is normal for some devices to have higher sound output than others.
Jan 08, 2009 | Yamaha RX-V461 AV Receiver
Receiver to ps3 optical - no sound
Check the settings on your PS3, I have my PS3 connected the this system using optical (by way of an AV switch) and have no issues.
Feb 21, 2008 | Philips LX700 System
Hooking up home theater
Run a regular RCA type audio cable from your TV audio out to your Home Theatre audio in. That is what I have done recently with my Samsung LCD and Home Theater. You then have to put your Home Theater on Aux 1 or Aux 2 to get the sound from TV. Ensure your TV's volume is off.
Kurtis
Nov 04, 2007 | Audio Players & Recorders
Philips LX700 System Logo
1,130 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
