Question about Toshiba MD20FP3 Combo
Toshiba MD20FP3 not turning on
My toshiba just die. Does not have any power. I check the fuse and it's ok. The set it's only 2years old. I try a diffrent outlet and it's not that. Help. Thank you
9 volt reg. supply 5volt to microprocesser on the secondary side.
Posted on Jan 15, 2007
    Sergeant:
  • 337 Answers
Is a good thing the main fuse is not open,your problem is in the power supply ,as I understand you have no indication of power(no lights,No clicks)The 5 volts that power the microprocessor might be missing,this 5 volts usually come from a regulator,this regulator should have 12 volts in one side and the 5 volts in the other,the 12 volts come from the secondary of a transformer and it has its own fusible resistor,if the resistor is open is because the regulator is shorted and it need to be replaced.This is a good place to check.Be careful when checking this parts.If you are not too familiar with tv service seek the assistance of a servicer,it should not be too expensive.
Posted on Oct 03, 2006
Toshiba projection tv 50 inch
Something is preventing the power supply from operating:
Possible causes in order of likelihood:
1) Convergence amps failed overloading the supply (See if you can disconnect them)
2) High Voltage circuit has died. (Right on schedule since your TV is 10 years old)
3) One of the CRTs has shorted
4) The power supply itself has died (Is there a lot of dust covering it?)
See if you can isolate the failure by working down the list.
Hope Ya Fix it!
Jan 07, 2008 | Toshiba 50H72 50" Rear Projection...
Toshiba 46tl963b 2years old turns on blinks 3/4 times loses picture but sound is perfect
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Sep 26, 2015 | Toshiba Televison & Video
Is Toshiba MD20FP3 an analog or digital television?
it is analog with a CRT (cathode ray tube) screen
Feb 13, 2015 | Toshiba Televison & Video
I have a 42'" LCD. IT IS ABOUT 3 AND 1/2years old.
Hi evansw591,
Power on the unit in the dark room then shine with the flashlight directly in the screen, you will barely see the images. This is because your backlight is not functioning. The following reason is the caused.
1. Power supply - missing B+(supply voltage) coming from this board feeding the inverter board. This is caused by faulty transistor, dried/leaky electrolytic capacitor, open fusible resistor.
2. Inverter board - even the B+ is good from the power supply, if the fuse, driver transistor, driver transformer is faulty no output to the backlight resulting to black picture.
3. Busted backlight - even inverter board is good but if this is busted resulting to black picture also.
Diagnosing the fault is technical and if you don't have necessary tools and test instrument and can't fix it yourself, I would advice you to look for an experienced technician to isolate the problem.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Mar 25, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Tv has blinking power lite and no pic, or sound
46inch flat screen Toshiba under 2years old cuts out no picture and
sound goes off and on...
Oct 19, 2009 | Toshiba Televison & Video
Accessing TV Menu withough original remote
No you need the remote ! and even most universals will not do that function for you either!
You can order an orignal replacment remote from www.remotes.com and that will let you access all of the tvs functions!
I hope I was of big help!
Please rate my FREE response!
Thank You!
Jan 17, 2009 | Toshiba MD20FP3 Combo
No Sound on Toshiba Satellite Laptob-2years old
Try upgrading the drivers for the sound card. You should be able to get them from the Toshiba website.
Dec 08, 2008 | Toshiba Satellite A40 Notebook
Toshiba MD20FP3 radomly turns off
a loose contact on the mainboard, if you know how to solder then have patience in soldering what you can see in the mainboard that may be having loose contact.
May 14, 2007 | Toshiba MD20FP3 Combo
Toshiba MD20FP3 Combo does not turn on. Help!
Not unless you have taken the time to learn all the safety issues concerning the HI voltage safety facts, in the repair of electronics? It sounds like your tv has a problem in the sweep/power supply circuits, and since these sets have NO user serviceable parts< its best too leave these types of repairs to a certified electronic technician. Good Luck
Jun 25, 2006 | Toshiba MD20FP3 Combo
Toshiba MD20FP3 Combo Logo
102 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
