Question about Janome Memory Craft 5700
Janome 5700 handwheel stuck/inside pulley stuck
Handwheel won't turn. when changing fuse noticed handweel was stuck. outside belt turning freely but inside belt/rods are stuck. when machine turned on, indicates up/down needle; when pressed makes loud noise and says"stopped for safety purposes". needle is stuck in drop feed/needle hold.
any suggestions?
thanks!
melanie
  • Anonymous Mar 21, 2014
    the needle will go down and up once, then stop with the above error message
  • Janome Master
  • 1,388 Answers
The error message relates to the motor sensing that it is working unusually hard.........the extra strain will have a physical cause, generally in the hook and bobbin region.......something blocking or slowing things down, so.......
Remove needleplate and bobbin case.
You will probably find an accumulation of lint in and around this area, also possibly in the feeddog channels.
Use a small brush and vacuum with crevice tool to remove the lint and wipe the hookrace with a tissue moistened with methylated (denatured) spirit to remove any dirt deposits.
Also check that the bobbin case is not damaged on the top surface by needle strikes or on the underside rim by the hook gouging as it spins.
If damage is present but mild, you can use very fine emery paper to smooth surface, if more severe, replace the bobbin case. Don't forget to change needles regularly too.
Best of ......
 www.bargainbox.com.au
Posted on Nov 21, 2008
I have a Kenmore 158-3500 sewing machine and cannot get the side plate off near the hand wheel I have removed the clutch wheel but the hand wheel and belt seem to keep the plate from coming off.
The machine has two belts, one from the motor to a transfer pulley and the second from that pulley to the handwheel. You have to loosen the motor mount (one large screw/bolt) to release tension on the transfer pulley which in turn releases tension on the handweel belt. You will have to take the belts off the transfer pulley to slide the handwheel off (assuming you have already removed knob in the center of the handwheel)
Don't forget to lubricate the shaft of the transfer pulley while you have the end cover off. If this runs dry you will have a problem.
Good luck
Bob
Jan 22, 2017 | Kenmore Sewing Machines
Janome JW5622 handwheel keeping getting stuck
how do I use the free motion plate on my janome jw5622??
Jan 26, 2014 | Janome Sewing Machines
Janome MyLock 634D serger won't serge and the handwheel is stuck after I removed a piece of fabric that was stuck by the knife.
if the handwheel won't turn, i'd double check nothing is still stuck. also, make sure you didn't half disengage the blade as they have several positions ( so you can disengage it for rolled hem etc) If you can't find anything I'm sorry to say something may have been damaged when the fabric got caught.
Sep 14, 2010 | Janome MyLock 634D Mechanical Sewing...
I cannot get the feed dogs to come back up on my janome memory 8000 after putting them down to free motion quilt.
Flick the switch to raise the feeddogs then rotate the handwheel one full revolution to re-engage the cam...voila
Mar 25, 2010 | Janome Memory Craft 5700
Hand wheel is stuck
hi there,
well,stuck up hand wheel, is due to mechanical obstruction inside machine,bushing on shafting need to oil,and on handwheel bushing near clutch there is oil port there. since hand wheel are connected to cam shaft with set of gears and pulley is coupled to motor pulley,and other linkage under bobbins,shuttle race etc,broken gears are most common causes of stuck up handwheel,we can consider also the brush carbon,when worn out and damage the rotor commutator brush.if you can open the cover of motor below side of handwheel,you can see the pulley and motor assembly.also on top of machine there an opening to see the top gear assembly,this should be done by service technician.try to bring to nearest service center if still under warranty claim this for lesser maintenance cost.have a nice day,don't forget to rate me.thank's.
Apr 20, 2009 | Sewing Machines
Belt came off
well that is very nice idea you can fix with your self provide talls most commonly use.Set of screw driver,open and socket wrench,pliers etc...Remove the top cover plate by loosening bolt holding the cover and cover besides the handwheel where the motor was installed besure it was unplug from ac source(No power)Check the motor holder that attaching from casing.You can see the motor coupled by the belt.In the motor holder there is a bolt slot adjustment for tensioning belt tighning and loosening.If you want to disconnect the belt and replaced loosen the tension and pull out the belt.Sometime belt are sliping to the pulley it affect
the sewing machine operation,you can tighten from adjusting the tension of the belt.adjust not so tight after adjusting try to run manually first by turning handwheel freely if the motor will run freely with out obtruction no power supply.If your satiesfied try to run with power supply but jag twice first to be sure no problem occured before continous operation.
Mar 07, 2009 | Brother LS-2125 Mechanical Sewing Machine
Handwheel is stuck
NEVER force a newer model machine. Everything inside is plastic and WILL break. Remove the needle, bobbin, bobbin case, and unthread the machine. See if the handwheel turns. If it doesn't, several things could be wrong. The lower end machines won't have belts to come off, they will be fully gear driven. If it is a better machine, it might be a belt problem. Small pieces of thread could be stuck in a gear mesh somewhere. A gear could be broken. It is possible for a gear to break on the first use.
Dec 01, 2007 | Kenmore 11206 / 11306 / 11506 / 11606
Sewing Machines Logo
439 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
