How to format LW40 EXPRESS - Computers & Internet
    Guru:
  • 1,463 Answers
Hello dpinner
you may this forum helpfull also LG LW40 Express Touch Pad - Notebook Forums and Laptop Discussion
i will look for a manual for the problem you have.
riz.
Posted on Nov 04, 2008
Cannot load .cda files
Ahh... I see. Few things do. Do you know what formats are supported? The best way I know of offhand to get audio from a CD into a more usable format is to "rip" them to your PC using either windows media player or iTunes. Which (if either) are you more familiar with and/or which do you have?
Mar 31, 2014 | express-scripts.com
I cannot download lw40 audio driver
you can download all driver for your laptop form there http://www.notebook-driver.com/lg/lg-notebook-lw40-driver/. and you can only download only sound driver. Right click on the Realtek.zip file and save it on your hard driver after download extract it and then you can install it.
Ihope this information will be helpful.
Jun 21, 2011 | Computers & Internet
LG LW40 will not detect samsung HM 160HC hard drive
The hard drive you are using is either broken or corrupt. Purchase a new hard drive. Unfortunatly the data cannot be recovered.
Jun 17, 2009 | Gateway M350Xb PC Notebook
The driver for ethernet controller and sound drive s not getting installed, how to get these drives installed
check out here
http://notebook.driversdown.com/notebook-drivers/LG-LW40-notebook-Marvell-Ethernet-Controller-driver_118588.shtml
Jun 09, 2009 | MSI 845 PRO Motherboard
Final Cut Express 2 won't Panasonic PV-GS320 minidv camcorder
hi,because final cut express only support .dv,mpeg-4 and .mov formats.
so you can convert your video files to .mp4.
you can use the third party software convert your video files to .mp4 format.
you can use Mod to Final Cut Express Converter.
http://www.fceconverter.com/mod-to-final-cut-express/
Jan 30, 2009 | Panasonic PV-GS320 Camcorder
LG LW40 tryi
YA I NEED YOUR LAPTOP CONFIGURATION
Apr 01, 2008 | Computers & Internet
Importing video from Xl1 canon into my Mac
you must use the third party software convert your video files format to final cut express support formats.such as dv,mp4,mov
if your video files is .tod format,you can use tod to final cut express converter.
http://www.fceconverter.com/tod-to-final-cut-express/
if it's .mod files format, you can use mod to final cut express converter
Mar 27, 2008 | Sony Handycam DCR-TRV18 Mini DV Digital...
Get Final Cut Pro 5.04 to communicate with my XH A1
Many HDV cameras and decks are able to play and record DV as well as the higher-resolution HDV format. Additionally, many of these HDV devices will attempt to automatically change their settings to match the format of the tape that it's playing. Here are some tips for using these types of devices with Final Cut Pro / Final Cut Express.
Tip: Make explicit settings on your HDV device. Instead of using an "Auto" setting, make your own settings on your HDV device to keep the communication going between it and Final Cut Pro / Final Cut Express. This also helps Final Cut Pro / Final Cut Express keep things running smoothly with HDV devices that handle both DV-NTSC and DV-PAL.
For example, say you're using an HDV deck to capture footage from a tape that was recorded as DV-NTSC. Before capturing in Final Cut Pro / Final Cut Express, make sure that you set the deck to DV mode specifically—don't rely on Auto mode. With some devices, you may need to disconnect it from FireWire to change the mode.
For a common capture workflow, this sequence of steps can provide the best results:
  1. Quit Final Cut Pro / Final Cut Express if it's open.
  2. Insert your tape into your HDV deck or camcorder.
  3. Use the device's menus to set it to match the format that's recorded on the tape.
  4. Connect your HDV device to your computer with a FireWire cable.
  5. Open Final Cut Pro / Final Cut Express.
  6. Choose an Easy Setup for DV or HDV (whichever matches the format recorded on your tape).
  7. Proceed to Log and Capture.
Tip: Quit Final Cut Pro / Final Cut Express before changing modes. It's generally a good idea to quit Final Cut Pro / Final Cut Express before you change the mode on your device from DV to HDV, or from HDV to DV, and then re-open the application again.
Tip: Use an Easy Setup to play back non-default HDV format footage on your HDV device. You can use Final Cut Pro / Final Cut Express to make your HDV device play back footage in its non-default HDV format. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as 1080i50. Or perhaps you have a 1808i50 HDV device and you want to play back footage that was recorded as 1080i60. To do this, follow these steps:
  1. Connect your camera to your computer.
  2. In Final Cut Pro / Final Cut Express, choose an HDV preset Easy Setup that matches the format of the tape's footage (you don't need to restart Final Cut Pro / Final Cut Express).
  3. Your device's LCD display should automatically display a switch to 60 or 50, indicating the type of media that's being played.
Playing back non-default DV format footage on your HDV device You can also use your HDV device to play back footage in its non-default DV format too. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as DV-PAL. Or maybe you have a 1080i50 HDV device and want to play back footage that was recorded as DV-NTSC. If so, follow these steps:
  1. Make sure that your device is in DV/DVCAM mode.
  2. Put your device into Play/Pause mode, then open the Log and Capture window in Final Cut Pro / Final Cut Express.
  3. Make sure that your device's LCD (or other readout screen) displays the same format as your tape or Final Cut Pro / Final Cut Express will misinterpret what type of device you have.
Tip: Avoid recording both HDV and DV formats on the same tape. Use separate tapes whenever you want to record in a different format. If you need to record over existing footage in a different format (for example, you have a tape with DV-PAL on it, but you want to record over it with HDV 1080i50), it's a good idea to black and code the tape, or completely record over the old footage with contiguous recording in the new format. If the tape contains even a second of, say, DV in the middle of an HDV tape (or vice versa), it could cause unexpected results later when you try to capture video from that tape.
For more information, see HD and Broadcast Formats and the Final Cut Pro / Final Cut Express User Manual, available under the Final Cut Pro / Final Cut Express Help menu
Dec 04, 2007 | Canon XH A1 Mini DV Digital Camcorder
Enabling my headphones on my laptop
Just goto control panel and under sound system properties change the output sound device to headphones . Fixya :)
Aug 26, 2007 | Apple iPhone 3G
Computers & Internet Logo
115 people viewed this question
David Payne
David Payne
