Question about Evga 512-P3-N862-AR GeForce 9600 GT GDDR3 PCI Express 2.0 Video Card Retail, PCI Express
No connection to monitor
Ok, here's the problem. I've been using this video card on my gaming rig for about 3 months. Last week I went to turn it on for some WoW raiding, and I get no action on my monitor. Only a message reading "No signal" and then the monitor shuts off. After testing various components, I've narrowed the problem down to the video card. I've tested every cable, monitor, and other video cards in my rig possible. My old 7600 card works in the rig, but the 9600 does not. There was no warning, no slowdown in the days leading up to this problem, or anything that would lead me to believe my card would decide to play dead. Any ideas? Another thing that may be interesting: The problem may have something to do with the DVI ports. My monitor has jacks for DVI and VGA ports, and the 9600 card only has DVI ports, but my 7600 card has DVI and VGA. The DVI port on my 7600 card also does not work. The VGA port works fine, but not the DVI port on the card. I've confirmed this again by testing every component that connects to the card, up to and including using a VGA adapter on the DVI ports of both the 9600 and the 7600, neither of which were functional. Only the VGA port works. Any clues?
  • 2 more comments
  • timebomb53 Nov 05, 2008
    I did use the VGA adapter on the 9600, as well as the 7600, and neither of em worked. It's definitely the ports on the cards. I haven't tested any other cards, but is it possible there's something wrong with my mobo that's causing the DVI ports to mess up? That's the only thing that I can think of, because it just seems bizarre that this problem would happen on both cards at the same time.
  • Yannick Verhoog Nov 06, 2008
    I had exactly the same problem with my 7600GS...
    While i was playing Neverwinter Nights 2, great game ^^, my screen gave the no signal screen and shut down...
    Apparantly the game was a little too much for the 3d card. I had played with lowest graphs but the stupid thing still broke....
    Luckily I am just buying a new pc!
    But all you can do about the problem is getting another video card, and try to cool this one better...
  • roccov376 Feb 21, 2009
    Did you ever solve this? I have almost exactly the same problem. It started when I hooked up a new monitor (yet the system worked with my old 7200GS). I RMA'd the card and the new one didn't work either. EVGA says they tested both cards and found nothing wrong.
    I've replaced the MB, RAM, CPU and now the power supply and still no luck.
    I have been able to get the 7200GS to work through the DVI port simply by turning the monitor off and on to reset it after the initial installation.
    Problem Solver:
  • 6 Answers
I had a similar issue when i upgraded to a new monitor the n later adde a DVI cable. I have a 7600 running through DVI...used to run through VGA. problem was when i got the DVI cable i just swapped out with the old VGA cable. my monitor has a "source" button to select anolog (VGA) or digital (DVI) modes. i had to reboot the PC and everything was fine. no problems since. try looking to see if your monitor has a "source" button. also when swithcing between cables or adding the dvi to vga adaptor turn the system off then plug the adaptor/other cable in then powering back up.
Posted on Feb 11, 2009
  • 167 Answers
I would try the card in another mainboard, if available and watch the refresh rates. hope this is useful. and try other cards.
Posted on Nov 06, 2008
    Problem Solver:
  • 5 Answers
You need a new cable. make sure you get a DVI-D cable. DVI cable come in 5 flavors, but they can only be: analog or digital. they are NOT interchangable. although, DVI-I cables are both analog AND digital.
analog cables have extra pins next to the flat pin.
digital cables only have the flat pin.
refer to the guide on this page: http://www.datapro.net/techinfo/dvi_info.html
Posted on Mar 11, 2009
  • 285 Answers
Well, the pointis that when i replaced the video card with my old one, it worked again, though i have lost the drivers for it, and i dont have a clue what model it is. I thought i had the right driver, and windos says the same, but the screen still is kinda weird. Everything is moving, not loke it's adjusting the resolution, but like at the point between 2 colors, pixels are changing between the one color and the other. It isn't reading realy nice when every word seems to be moving...
I de-installed the old driver (for the newer video card) before installing the 1 for the older, so i think i did everything right, but...well, it doesn't work.
If anyone knows a solution apart from deleting the entire pc and reinstalling from scrap, I'd like to know.
Thanks!,
Yannick
Posted on Nov 07, 2008
  • 30 Answers
Did you try using the VGA adapter on the 9600? If it works then your dvi port on the monitor has crapped out.
Posted on Nov 05, 2008
What would cause the monitor to go black while playing various games.
Being that its so new, i would just send it back for warranty work. Sounds like a video/graphics card going bad.
May 13, 2014 | Dell Alienware Area-51 Gaming Desktop...
Dell 1800fp dead
Each monitor has a different response to "no activity" from the system. So for the monitor, if you get a chance, try your monitor on another machine that you know does function. At work, neighbour, or other.
For the computer, does the it (beep) or POST (Power On Selft Test) when you turn it on, do you see and hear what you would if the monitor was connected?
If it sounds normal, then everything should be fine and luck might have it, your backup monitor is not working either, try another one from the same friend or neighbour above.
If it doesn't POST, you could have a video or other card or ribbon connection loose in the computer. Either you or a friend, or the service center, whichever feels comfortable reseating all the external and internal equipment, bearing in mind static electricity and proper handling measures for the computer.
Nov 26, 2007 | Dell UltraSharp 1800FP 18.1" LCD Flat...
I have a dual display with a Samsung digital LCD flatscreen and LG analog LCD flatscreen running on WinXP with a nVidia GeForce 8400GS video card. The video card is new - the old card (which was hooked up...
Hi
I'm not sure what you mean by VGI. I will assume you mean VGA (Analogue - D Shaped with 15 pinholes).
When pixels or line of lixels fail on a monitor, they usually fail in spots or in a vertical lines due to the design of the matrix.
Since both monitors are sharing a single cable and the graphics card is a new one, the fault automatically isolates itself to either the monitor or its VGA connector.
Check that none of the pins in the end that connects to the faulty monitor are bent and/or touching one another and shorting.
Then try changing the resolution of the graphics card itself and test the monitor's performance at various settings to see if the resolution seeting is straining against the limits of the monitors range.
Right click on open space in the desktop > properties > settings > click and hold the slider scale step by step, up and down the scaled to test the monitor > apply > ok > test for a reasonable period > reset.
Also test the monitor with a single VGA cable to another computer (even a laptop, using the Fn key + external monitor function key).
Thses tests should tell you if the monitor is failing.
I hope this helps.
Aug 24, 2011 | Computers & Internet
My hp dv5215us laptop monitor broke several months ago. I've been using the computer with an external monitor plugged in to the vga port, but I turned it on today and the external monitor isn't...
Hardware failure of the motherboard - most likely something went wrong with the northbridge.
The repair will cost way more than it's worth, this laptop is effectively dead, time for a new one
Jul 20, 2011 | HP Pavilion dv5215us Notebook
My HP W1907 monitor works fine until I try to play The Sims 3 game. I play for several minutes or hours and the monitor shows the message that it is going to sleep and the light on the monitor goes...
Hi there. I had the same problem months ago when I try to play high end games like Sims 3 my monitor goes into power saving mode. I tried to check every possible causes of the problem. It could be that your computer is overheating try to clean your computer and check if your fans still works. Second it could me your power supply malfunctioning, maybe it does not meet the required power to make your game work. Last cause is your video card malfunctioning, what I did is to just buy a new video card and it works.
If you do not have spare power supply or video card you can go to a computer repair shop for them to check the possible problem that causes it to go into power saving mode. It can also save you money before you can buy a new one.
Hope this helps, Have a good day!
Oct 03, 2010 | HP w1907 LCD Monitor
On the right side, color line showed up last week from top to bottom, more lines showed up every day and now form a strip. Is this a hardware or software problem?
You can check by yourself if the problem is brought by a video card. Disconnect your present video card from the motherboard. It is the hardware where vga cable from the monitor is connected to on the back of your computer. Replace it with your back up video card. (a pci or agp graphics card will do) connect the vga cable and restart your computer. If you don't have a back up video card, find in the computer a built in video card, enable this on the cmos'bios setup) connect the vga cable thru this and turn on your computer. If the lines went out then it is the video card that needs replacement. If the lines still occur despite the procedure, I suggest you bring your unit to a credible technician unless you have the skills to open your lcd monitor and find the problem in it by yourself.
Jun 22, 2010 | Acer 22" X223w LCD Monitor
PC Monitor and Game problem
Sounds like your dedicate video card bit the dust and you're back using the onboard video, which would absolutely be the reason why things got choppy-- it can handle the demands put on it by the games.
A new dedicated video card would fix the problems.
Jul 11, 2009 | Dell Computers & Internet
I have an HPa6700y I purchased about three months ago.  At the time of purchase I installed a high-end graphics card myself (ASUS EAH4870 DK/1G Radeon HD) and it had been running beautifully until...
usually there are 2 problems: 1. a vga card overheat when running 3 games the vga card heats up. try using an case fan or adn a vga fan. 2. the game uses a high refresh rate in this case tri to set a default refresh rate from the vga driver. hope this helps
Jun 14, 2009 | Computers & Internet
Monitor falls asleep during/after startup
control panel
click power settings
set the monitor to never sleep or dim
same on all windows.
the monitor is totally programmable
why not tell OS?
windows 10?
or google
why does my windows 10 monitor go to sleep
10,000,000 hits
endless.
the defaults under windows, are always wrong,
it's to keep the FEDs happy with there Energy Star bs.
im on laptop now far far from USA
set it all to not use sleep etccetra.
Feb 28, 2017 | HP Computers & Internet
No display at post
There are a few things that can cause no display on the monitor.
That single beep means POST = Power On Self Test. Post has tested everything on you're board to be good.
The cable between video card & monitor may be bad or not connected correctly (Swap out the cable as last resort).
2. You're monitor is defective, try swapping it with known working monitor.
3. You're video card is not functioning.
Lastly, when you reset the system cmos/bios everything went back to default. This means you're bios is now using the onboard PCI video graphics. Remove you're radeon 9600 video card. Try booting the system. You should see display again. The only way to test you're radeon would be to boot to the bios & set bios to boot using the AGP radeon. You need to change Init Display First to AGP & not PCI. If you loose video than you know you're AGP card is bad. Reset the cmos/bios before adding another AGP card or you will not get display. This setting is on pg 3-5. Integrated Peripherals. If you need you're manual you can download it from this link: http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=NF7-S2G&fMTYPE=Socket+A
Good Luck!
Mike
Jun 06, 2008 | Power Color RADEON 9600 (128 MB) Graphic...
Evga 512-P3-N862-AR GeForce 9600 GT GDDR3 PCI Express 2.0 Video Card Retail,  PCI Express Logo
355 people viewed this question
Top Evga Computers & Internet Experts
Tony
David
David
Mike
Are you an Evga Computer and Internet Expert? Answer questions, earn points and help others
