Hi pitch noise from the back near the top of L.c.d flat screen had to send two back and now have a sharps set which makes a noise now and again is it a normal issue
    Sergeant:
  • 291 Answers
You could have a electricial short or a oscilating transformer ( a transformer that is viabrating ) that it is coming from the top could mean that is high voltage. Do you have a lot of dust in the house ? that attracks high voltage.
Posted on Nov 07, 2008
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Televison & Video
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
Dec 13, 2015 | Televison & Video
55"sharp aquos led flat sreen and its making a
Can it be heard with sound off and describe the sound a bit, buzz or high pitched sound? Not unusual for the front screen unit to make a slight buzz but I gather this is loud.
Dec 13, 2012 | Televison & Video
Samsung dlp tv HLP5663W makes loud noise
Yes, the set uses a color wheel and the lamp faces it.
The wheel turns at over 8,000 rpm and is well known for this problem=bearings in the tiny motor go bad.
The high pitched or fan like noise (classic description) is this part.
Sooner or later the wheel (plastic colored segments) will shatter and set will shut down lamp and not operate---set monitors the speed of the wheel so if it slows down or stops it knows.
The part is readily available on the internet (Google the model number with "color wheel").
This can be a do it yourself repair and You Tube has video instructions for replacing the wheel by model number.
There are two common pitfalls to avoid which the instructions that come with the replacement part usually do not mention---if you decide to do this repair let me know and I will explain.
SD TECH
May 26, 2012 | Televison & Video
There's an intermittent high pitched noise from sharp aquos lc32 le600e
Sounds like a transformer or choke that has loose windings and they are resonating, you can pull the back and put small amounts of silicone on those components or replace the power board
Dec 19, 2017 | Televison & Video
What causes a scratching noise coming from a 52'
Most likely if buzz or high pitched whine it is coming from a coil or transformer on the power supply board inside the set.
Mar 13, 2012 | Sharp Televison & Video
Sanyo 46' flat screen tv - has issues like all of a sudden it will make a high pitched noise and then the TV goes out - the picture freezes and then the screen goes black
our Sanyo Flat screen tv freezes, makes a loud noise, then turns off then back on automatically. It does it more frequently while watching an exciting part of a movie
Jan 10, 2010 | Sanyo DP46849 46 in. HDTV
High pitch frequency noise coming from rear of TV and is very annoying to listen too. It is a constant noise and is more apparent when there is more black color on screen.
High pitch sound on LC-42D62 is reproduced by switching transformers on power supply board. To correct this problem, you will need to remove power supply unit from the TV, spray all transformers with SILICONE CONFORMAL COATING. Let it dry for 12Hrs. Then install power supply unit back.
Dec 31, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Buzzing noise from rear of 26inch sony flat screen
cheak back light settings turn it all way up if down to low it will buzz in video options
Oct 15, 2008 | Sony KDL-26U2000 26 in. LCD Television
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
