Question about Supra SW5L30D Front Load Washer / Dryer
Washer won't go from wash cycle to dry
After setting the wash and then dry cycle, the unit doesn't seem to switch from one to the other. It spins the clothes but they still seem very wet and there is also still standing water. I have checked all hose and all are fine. The blows hot air for maybe 10 minutes, then will just go on to next wash cycle, instead of drying for selected time and then turning off. Not sure what to do?
  • chikko Dec 16, 2007
    Is there a half cycle button on 5L50D model i am having a problem turning the dryer on i cant find the button on the machine
  • RLMS Jun 15, 2008
    Just moved into a condo with this washer/dryer. Is there any way to just use the dryer without going thru the entire wash cycle? I read about the half cycle but I don't see that on my machine.
Http://www.edgestar.com/support/wdcombo.htm
Posted on Jun 18, 2008
Use half cycle button
Posted on Aug 13, 2007
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
My Kenmore washer drains after the rinse cycle but won't spin at the end of it's cycle. If I manually set it to the spin cycle, it spins just fine. Desperate!!! The lid switch was just replaced about
Possible there is problem with the timer controller unit. It seems that the stepper motor is not moving to the next cycle until you manually move it to the spin. You can use some contact cleaners on the switch and also carefully try to see if the timer moves within , replacement is a costly issue and must be debated
Nov 20, 2013 | Washing Machines
Lrs8233eq0 won't go through cycle
If the machine spins, the lid switch is OK, it could be the timer
Mar 29, 2013 | Washing Machines
Bosch nexxt essence won't spin
Either a blocked filter or worn carbon brushes
Oct 11, 2017 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Sears 110.23812100 washer leaks when spinning
There is a pause after the pump out that shift the tranmission into spin also if you open the lid the unit will go into spin before it pumps out completely . They have since fixed this issue...The newer models work offf the pressure switch to tell the unit when to go into spin only after the water level switch is open telling the machine there is no water left in the unit
May 28, 2008 | Washing Machines
Supra SW5L30D Front Load Washer / Dryer Logo
257 people viewed this question
Top Supra Washing Machines Experts
Andrew Taylor
Andrew Taylor
Are you a Supra Washing Machine Expert? Answer questions, earn points and help others
