Question about Lexmark X4270 All-In-One InkJet Printer
Error 1200 Got this all in one for xmas. month later unable to remove error 1200. replaced ink worked for about a month or two, then error 1200 again cleaned ink heads remove nonexistance paper jams removed possible dust since unable to use do to error 1200. september replaced usb.still getting error 1200 self test/self clean/ worked for about a week now in oct error 1200 again. now what?
  • charlie1961 Dec 06, 2007
    my machine report error #1200, i have no idea abuot it, could yuo hep me
  • Anonymous Aug 28, 2008
    unable to get rid of the error 1200
Lexmark X4270 Error 1200 Fix - Click here for document link
1. Unplug printer from wall and remove power supply.
2. Unplug any phone lines or USB cords connected.
3. Remove printer attachments, paper trays and phone.
Figure 1 - Printer paper holder and completed print tray
4. Lift the front cover of the printer and remove the white rubber bar by pulling the blue lever on right towards you.
Figure 2 – Top view of printer showing the white rubber feed bar with purple attachment
5. Remove the screws underneath the front cover (6 screws), back of printer (2 screws), and bottom of printer (1). View the images below to find where to remove the screws.
Figure 3 - Top view of printer showing which screws to remove.
5. Cont…
Figure 5 - Bottom view of printer. Image on left is cover to screw. Gently remove ribbon cable to reveal the gold screw beneath
6. Flip the front cover open and gently lift the top of the printer cover. Keep front cover open.
7. Remove the ink cartridges out of their carriage.
Figure 6 - Displays ink cartridge carriage with ink cartridges removed.
Caution: Electrical hazard. Keep hand and metal pieces clear of board or any other electrical wires or parts.
NOTICE: The ink cartridges are all the way to one end. If the X4270 is plugged in, the cartridge carrier is stuck and doesn’t move. After further investigation a noticeable small black plastic lever is preventing the ink cartridges from moving. Photo below shows lever up and down (cartridges already moved in image below).
Figure 7 - Shows inside of X4270 and the lever that causes error #1200. Image on left displays lever up. Image on right displays lever down.
8. Push lever down clockwise so it is flush with plastic wall. Refer to image on right in Figure 6.
9. Lift the front cover open (if not already open) and plug in the X4270. Cartridges should move to center as if preparing for replacement.
10. Unplug the X4270 and remove power supply.
11. Remove bottom assembly carefully.
Figure 8 - Displays bottom assembly with lever and spring
Note: The cause of this problem is the spring slides out of place over time, probably because of ink shed on one end of its loop and loop attachment.
Figure 9 - Displays loop attachment
12. Place spring in loop attachment and use hot tip of heated tool to melt top of loop attachment to prevent further errors. Melt top of loop attachment similar of that to a mushroom top.
Figure 10 - Displays fix for jammed carriage.
13. Reattach the lever to the bottom assembly and slide back into place inside the X4270.
14. Plug in and check if operational.
15. Reassemble X4270 using steps 3-7.
Posted on Feb 27, 2010
  • maureenel79 May 16, 2011
    AWESOME! Thanks for the link to photos. It made all the difference. I am definitely a novice but your text and pictures got me through the process and now my printer is working. Had trouble getting the phone off. I missed any info about the screw on the bottom of printer under the slide thingy. It snapped off but won't be a problem. Thanks again for taking the time to post!!!
In my printer's case, the cartrige carriage was stuck in the park location. I tried tugging on the belt, but the carriage was locked on the right side. I took the grey cover off and discovered that the carriage was locked by a locking lever which normally is pulled down out of the way by a small spring, which I saw laying on the bottom of the black plastic base. The spring had come loose from a tab or pin molded in the plastic. The wiper assembly can be removed by sliding it to where the tabs can exit the slot. one could reattach the spring to the lever and put it back together. I chose to experiment with removing the lever and spring. Apparently, this lever isnt really critical because the printer worked just fine. keep in mind that any time one goes to this extent, one may not get the printer back together to working order. I was at the point where I was going to fix it or chuck it. I may find out in the future what the purpose of the lever was for. Anyway, I invested an hour in dissassembly and reassembly, and I have a working printer/fax for now.
Posted on Mar 03, 2009
Soltuion 4 is simplest and it worked! just turn of and on again the power to remove the warning.Cheers
Posted on Apr 26, 2010
Taking out the ink cartridges and installing them back in did the trick.
However, I did it the long way because initially the belt I thought I was tugging on turned out to be the encoder strip, tugged too hard and out it came. End up having to take the printer grey housing off and re-installing the strip. Everything's fine now.
Posted on Aug 02, 2008
    Novelist:
  • 114 Answers
Lexmark has a decent Tech Support site, and suggests several things to try to resolve the error 1200 in this article. http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:439:0:0&emeaframe=&docid=ENUS23485
Posted on Oct 03, 2006
HP 1200 Business Inkjet, dutifully prints BLANK info page from printer button.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Feb 19, 2013 | HP Inkjet 1200dn Printer
Hi! I installed new ink cartridges almost a month ago and that same day I had no problem printing. 1 week later it was printing extremely faded. Thought it was a fluke, but tried again tonight and it's...
Hello!
We all as a canon printer consumer is needed to use Pro dot ink to refill. Please remove your cartridge and clean up the cartridge head tightly by soft/toilet paper and replace again. If it doesn't work clean it again and again... thanks
Sep 13, 2011 | Canon PIXMA MP160 All-In-One Printer
Error message reads "unable to
It means that the printer is unable to clean the print head number(s) 46. The print head is located under the ink cartridges. Remove the cartridges, and you should see a plastic piece with a hole in it to put your finger under and snap open. This allows you to see the print heads. The print heads look like a sponge type dabber on top of a plastic case. Grab a hold of the print head and pull it out. Look for ink that has spilled behind it or on any of the brass colored computer connections. use warm water and a lint free cloth to scrub it off. Press the print head sponge with your finger and make sure that ink primes and fills the head then put the printer back together and try a test page. If you stll get the error then you need to contact brother for a print head replacement.
Jun 29, 2011 | Brother MFC-465CN InkJet Printer
Hi I have Brother dcp 350 printer. I have the error 46 unable to print/clean i cant get the printer back to normal functions. I have change the inks (all) and I am still get the same error message 46....
The messages unable to print, unable to clean, unable 36, error 46 and error 32 are all print head errors.
1. Remove all the ink cartridges from the machine
2. Clean the contacts on the cartridges as well as inside the machine itself with a small amount of warm water or alcohol on a cotton swab until no ink comes off on the swab.
Note: if any of the other cartridges are low, empty, leaking or bulging replace them
3. Then turn off the machine and unplug it for 70 seconds
4. Plug it back it and wait for the insert cartridges message
5. Insert the cartridges and check to see if the problem is still there. If it is it means the print head has failed and in order to fix this the print head inside the printer needs to be replaced. The print head is the part of the printer that puts ink from the cartridges onto the page
Unfortunately this can sometimes cost more to replace then the machine itself.
Apr 18, 2011 | Brother DCP-350C InkJet Printer
No printing, poor pringint. Clean heads does not help. What can I do?
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Mar 02, 2011 | HP Officejet Pro K5400n - - colour -...
My hp dj9000s printer is switched off since 6 month, now I switch on it shown error message for Lc, Lm ink cartridge. (cartridge is ok I replace with new one but error is same)
If an inkjet printer has not been used for some time and several print head deep cleaning has been done and it still does not print properly then the nozzles in the print head are blocked.
Inkjet printers need to be used frequently to prevent nozzles blocking with dried ink.
You need to replace the print head to get the printer functioning again.
But these print heads are expensive to replace, it may be better to buy a better and a later model printer for not much more costs.
Feb 25, 2011 | HP DesignJet 9000 InkJet Printer
Hp laser jet 1200 catrige error
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can
also be poor ink cartridge contacts
Feb 18, 2011 | HP LaserJet 1200 Printer
Canon pixma ip8500, on third print head in about 4 years. will not print yellow despite repeated head cleaning cycles, now waste ink absorber is full. need instructions for emptying/replacing said...
the waste ink absorber cannot be replaced mate. you have to buy new printer.the waste ink absorber is the sponge part where head cleans all its ink. its a common problem in cannon.
Oct 01, 2010 | Canon PIXMA iP8500 InkJet Photo Printer
After being abroad for 3 months i can home to find printer not printing correctly i replaced the 5 ink cartridges but only 2 working Black and cyan
The ink has dried in the print head. If the print head comes out, remove it and apply rubbing alcohol or water with a paper towel to the nozels to disolve the ink. Once the ink seems to be fluid, replace the print head and ink cartridges, do a head cleaning and try printing again.
If the print head cannot be removed, get a childs medicine syringe, draw in some rubbing alcohol. Remove the non printing carts and apply a couple of small drops of alcohol to each ink port on the print head. apply some more drops to the ink port of the carts and replace and try a head cleaning and print.
If this does not work, continue to ask for help. The aim is to save the print head, not buy a new printer.
May 29, 2009 | Brother DCP 115C All-In-One InkJet Printer
MFC 210c Unable to Print Use Troubleshouting and routine maintenance chapter in Users Manual
My color has not worked well in the past few months. Now I get the message Unable to Print, Use Troubleshooting and rountine maintenance chapter in user's manual. I've tried everything it told me. I've removed all ink cartridges and left them upright (they are ALL brand new) and cleaned all the ink ports. I've cleaned the machine several times. It's told me there's no ink cartrige, I've replaced them, turned the machine off and on, unlplugged, etc. Then go to print and I get the same message again and it won't print. The machine is almost 2 years old and has worked fine until about 6 months ago when the magenta stopped working all together. Now this. Any help? Thanks.
Nov 05, 2008 | Brother MFC 210C All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
3,407 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
