Question about Gateway Media Center 610XL (610XLMDIA) PC Desktop
Disassembly of gateway 610XL
Does anyone know how to disassemble the monitor part of this machine?
I tried the screws on the back and I have even gone as far as disassembling the part with the power supply. Any pictures or help would be appreciated.
Take cover off top of base.- pry off
remove two screws that hold speaker unit, it will tilt out, disconnect cables and remove speaker.
two screws on back of base and then take off back cover.remove sheild cover.
disconnect all cables. 4 screws hold power supply in.
rca connector board has little black button holding it on. pry up and then remove board to access connecters behind.
pull all cables out towards you.
remove 6 screws that hold base to back of screen, pull up tape under where cables go thru hole.
remove base from screen.
take out screws on back of screen. carefully pry all around case to seperate.
remove back, and then sheild. there are a few screws that hold it on.
If your screen was black, then the two inverter boards could be the problem. there is one in the upper left corner and one in the lower left corner. you can by them on internet. match the partnumber, there are 2 diffent ones.
Posted on Nov 09, 2008
Loose pully on back of motor axle shaft and pully tentioner . Need to take casing off, but don't know where to start disassembly to do so. Anyone got any diagrams or books todo so? Thanks lone.eag1e@y
the top just above the door should be spring fastened or are there screws in the back cover
mine i just pop the top and locate the front face screws to remove the front
Feb 10, 2013 | Dryers
Tip
How to disassemble the Gateway XHD3000 30" LCD monitor
Basic disassembly information for the Gateway XHD3000 monitor<br />Provided by bammbammfran<br />Board repairs available<br />I recommend taking notes as you go or pictures and making which screws go to where since there are several different ones.<br /><br /><img src="bammbammfran_0.JPG" /><br /> <img src="bammbammfran_1.JPG" /><br /><img src="bammbammfran_2.JPG" /><br /><img src="bammbammfran_3.JPG" /><br /><img src="bammbammfran_4.JPG" /><br /><img src="bammbammfran_5.JPG" /><br /><img src="bammbammfran_6.JPG" /><br /><img src="bammbammfran_7.JPG" /><br /><img src="bammbammfran_8.JPG" /><br /><img src="bammbammfran_9.JPG" /><br /><img src="bammbammfran_10.JPG" /><br /><img src="bammbammfran_11.JPG" /><br /><img src="bammbammfran_12.JPG" /><br /><img src="bammbammfran_13.JPG" /><br />For further information contact <br />bammbamm@ptd.net
on Nov 14, 2010 | Gateway XHD3000 LCD TV
How do i get the back cover off to get to the power supply? I have all the screws and the pedestal removed.
jmeyerle, Try viewing a few "lcd monitor disassembly" video clips and some "lcd monitor repair" clips at YOUTUBE first!! "PARTING" the REAR " COVER" from the front "BEZEL" hardest thing to do!!!! Don't use any sharp cutting instruments or you may incur costly trip to local hospital "ER" for 3 to 30 sutures. Protect the glass lcd panel at all times to prevent cracking it!!!! Start at "bottom" edge of case. 12fixlouie
Sep 16, 2010 | Gateway FPD1960 19" Flat Panel LCD Monitor
Replace DC power plug on Gateway CX210X laptop
Ok I just did this on my Gateway it is a different model though. I am not sure where you are stuck so I will start from the beginning. Remove all the screws from the back, then remove all the components (hard drive, cd rom, network card, battery etc.) beneath these components are more screws remove them. I do not know if you have removed your keyboard if not there are screws attatching it to the motherboard on the bottom remove those mine had three in various places like by the network card and dvd rom. If you are unsure consuly gateways website there are instructions for removing your keyboard. Beneath the keyboard there are more screws you will need to remove the monitor adapter in the rear unplug it from the motherboard and beneath it there are more screws. When you think you have removed them all gently pull on the motherboard from every side if it moves freely on eachside you are ready to dislodge it from the casing. If there is a location that is still firmly in place inspect that area from the top and bottom you should be able to locate the remaining screw.
The mother board does not slip out once all screw are removed it is lodged firmly in the case especially by the fan vent you have to coax it out.
Dec 12, 2009 | Gateway CX210X Notebook
Need help to disassemble for power adapter repair.
Here 'tis: http://support.gateway.com/s/manlib/Notebooks/Solo9150/8503827/8503827/03827C1.htm
Apr 16, 2009 | Computers & Internet
How do I change the video card in my 610XL PC?
After the side of the case is opened and the computer unpluged and the video to the monitor unplugged, if it has a card already installed , remove the screw holding the card down then pull the old card straight up out of the card slot. Align the new card that you purchased , pushing it straight down into the slot. Install the hold down screw. Reinstall the side . Install the software after hooking  the computer and monitor up.   If you don;t jknow which type of card ,down load a manual and maybe even further instructions from the weblink I provided.
Below it the Gateway support center for your model. All you have to do is to put in your 22 digit serial number.
http://support.gateway.com/support/drivers/dlcenter.asp
Feb 16, 2009 | Gateway Media Center 610XL (610XLMDIA) PC...
Monitor won't turn on?
I would double check you power connection to the monitor, if that's good. I would say that your monitor has gone bad on you. If it's still under warranty by chance take it back, if not you will need to get a replacement monitor.
I hope this helps,
Thanks for using FixYa,
Eric
Jan 24, 2009 | Gateway Media Center 610XL (610XLMDIA) PC...
Disassembly of Gateway 610
Found this - should help you
cosmetic screw covers that cover nothing
"remove this panel so you can remove that panel so you can slide the
carriage holder and unscrew the fenortnor rods."
"Flex the case in the middle and the undercarriage will drop out."
"Slide the front cover a couple inches left and remove screws, then
turn it around and lift the cover one inch to remove third screw."
Dec 31, 2008 | Gateway Media Center 610XL PC Desktop
How do I install a power supply in a gateway 610xl computer?
REMOVE THE CASE AND UNPLUG ALL.THERE SHOULD BE 4 SCREWS HOLDING IT IN PLACE REMOVE THEM.REINSTALL NEW IN REVERSE.RICHARDM69
Nov 26, 2008 | Gateway Media Center 610XL PC Desktop
Gateway 610XL Disassembly
take cover off top of base.- pry off
Nov 05, 2008 | Gateway Media Center 610XL PC Desktop
Gateway Media Center 610XL (610XLMDIA) PC Desktop Logo
418 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
