Question about Sony STR-DE485 Receiver
REQUIRING A PART NO LONGER AVAILABLE IN NZ
I purchased my STR_DE485 receiver 5yrs ago. Recently I turned it on, but got no sound trying all functions. I took it to our local Sony Service Tech who traced fault to IC201 function select IC. I have tried sourcing the part from NZ but to no avail. Is this part still available anywhere else? They said they would fit it if I could find it. Also bearing in mind, (I don't know if this is relevant) our power is 230-240 wtts. Natts
  • nsg10 Nov 07, 2008
    I have had no luck with your suggestion Parts Store USA. They don't do shipment outside USA and won't accept a Bank Draft or Telegraphic transfer. Any other suggestion please. Thanks
  • 10,594 Answers
You need IC201 " 8-759-827-92 " IC M61511FP for your Sony STR-DE485 and this parts is available in Parts Store USA
Good luck.
Posted on Nov 04, 2008
  • 1 more comment
  • Shahid Electronics
    Shahid Electronics Nov 07, 2008
    Well, I live in Pakistan and let you know if I can arrange this part for you.
    If you have any friend or relative in USA, he / she can send required part to you. It is just a suggestion.
    Shahid Electronics Nov 08, 2008
    I checked my resources and subject part has been reached to Supply End status. very sorry.
I have a sony STR-DE945, and no sound was put out unless you pushed in the power button slightly. Now no sound comes out no matter what. Was going to replace the circuit board part no. 1-676-999-1 but part...
unfortunately, electronics go obsolete very quickly, and the cost to repair a specific unit is so close to that of purchasing a new replacement that very few places stock parts or do repairs these days.
Unless electronics repair is a passion or hobby of yours, you will spend much time and effort trying to get parts, time trying to replace the defective parts (a waste of time and money if you aren't absolutely certain which parts are bad).
Since the complete board is no longer available, troubleshoot to the compnent level and replace the individual items on the defective board, or just get a new receiver.
Aug 11, 2014 | Sony STR-DE945 Receiver
Connecting a turntable to Sony STR K502P
Use RCA Cables from the TT to the Aux in on the Receiver. You may need to use a pre-amp inline from TT to Receiver.
http://www.bhphotovideo.com/ has a few.
Mar 17, 2014 | Sony STR-DE485 Receiver
No sound protect mode
Protect on a sony usually means a short in the amp section. Would have to go in for repairs.
Jan 24, 2013 | Sony STR-DE485 Receiver
I have set up a BOSE Accustimass System with my STR de485 receiver. How do I adjust the treble/bass?
hi,
if u are using bose speaker system then remember one thing. go to speaker setup and select all the speakers as large not small. then only u will get a good tone. bose speakers will handle the output power of ur amplifier.
u can only adjust the bass and treble of ur frond Channel speakers. for that
select multi channel surround sound and the increase and decrease the bass and treble
ok
Dec 31, 2010 | Sony STR-DE485 Receiver
I have a sony str-de485 reciver im trying to get digital sound it is only playing in prologic. im trying to hook up my xbox 360 the digital option is activated on the xbox i have a fiberoptic cable...
please make sure that the connections are firm. Then check if the input mode is set to auto in. Also try to change the sound field on the receiver and try. If the issue perform reset by turning OFF the receiver and press n hold the MODE button along with the power button till S.F clear appears on the receiver and try. You can also try to disconnect and reconnect the power cord from wall outlet for 2 minutes and try.
Sep 20, 2009 | Sony STR-DE485 Receiver
CAN I CONNECT A TURNTABLE TO THIS RECEIVER? STR DE485
You can try connecting it to the cd or tape inputs on the back of the receiver. It should work in either of those connectors.
Aug 13, 2009 | Sony STR-DE485 Receiver
PROTECT DISPLAYED ON RECEIVER
This generally means you've got a short somewhere, and the received is trying to protect itself.
My suggestion is to disconnect all of your speakers at both ends, and reconnect them.
Most times this happens because a speaker wire is lose, and the positive and negative connections are touching each other, causing it to short out.
Mar 24, 2009 | Sony STR-DE485 Receiver
Sp.off
ON the str-de485 the sp.off lights up when the headphone jack is enabled, do you have the headphones inserted?
Feb 13, 2009 | Sony STR-DE485 Receiver
Sony STR DE485 (Audio Video Reciever)
Your problem must be caused by the right channel (rear, front whatever..)side feeding resistor on the power supply.
May 05, 2007 | Sony STR-DE485 Receiver
Sony STR-DE485 Receiver Logo
71 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
