Back to:
Tags:
Tatung CLT-L50 15 in. Flat Panel LCD Monitor
How to open up the casing on this monitor.
posted by Polymoog on Oct 03, 2006
I am a service engineer - I believe the Tatung L50 monitor I have has an internal power problem (no display at all, and no backlight).
There appears to be no easy way to open it up - Aside from four screwtwist holes at the bottom to (apparently) remove the front casing.
From looking at it, there appears no way at all to remove the stand from the back of the unit.
Could someone with knowledge of this monitor tell me how I can open it up, please?
Thanks
Chris
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Nov 29, 2006
Thanks for Trying (70)
jboyd8
Rank:Apprentice Apprentice
Rating: 70%, 1 votes
It is not initially obvious how to access this insides of the monitor
Unusually, access is only available through the front of the screen. The stand cannot be removed on this model.
You need to pry a screw driver (or two) through the four holes located at the rear base of the monitor and remove the front panel surround. The LCD panel and all electronics can be lifted out after removing four screws.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on How to open up the casing on this monitor.:
I don't want to Accept this solution
Can you Help with these Monitors problems?
Monitors
I am trying follow the steps below, I can't turn the...
Monitors
I took my car in for an oil change about five weeks ago...
Monitors
hello sir I have purchased a samsung monitor last year.but...
Tatung CLT-L50 15 in. Flat Panel LCD...
Tatung L50 15 in. Flat lcd has horizontal lines running...
I have a Tatung L50 LCD monitor and need the cords to go...
Loading problems.
Repair Service
Find Monitor Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
