Question about Bose Wave Radio
Hummmmmmmmmmm Its the AWR1 1w Hummmm problem. The hum gets only slightly better if I tune it to another station. I could do better with a three dollar radio. For the price I paid you would think the thing would cure itself. I paid more for it than I can get it for today..... considering inflation I probably paid four times what I originally paid for it.
Are you listening to AM or FM? If you are listening to AM, trying rotating the radio. You may be picking up some type of local AM interference. If it's happening on FM....then I guess there is always a possibility that you may have a defective power supply and what you are hearing is the hum from that.
Posted on Nov 12, 2008
  • jossysagun_1
    jossysagun_1 Jan 15, 2012
    Mine is Phillips Clock radio model no. AJL308/05, if u have can u tell me what i have to do on it?
Switched from cable to satellite via hdmi cable. Now there are scrolling jagged horizontal lines and no audio.
try running the auto tune program in the set as what you describe may be out of tune for the stations
Sep 05, 2015 | Panasonic TH-42PD25U/P 42 in. Plasma EDTV
How to tune to an am station on hf. ?
The AM Shortwave Broadcasts are subject to propagation which means that unlike the regulars stations they normally come in better at night. You can normally find them in the evening between 6 and 9 MHz. (You can research frequencies on the net) You tune them just like any other AM station
Aug 29, 2014 | Radio Communications
Bt freestyle 1025
Clear the cables from any other cables (power cables etc) Try moving the base station slightly, it is most likely interference
Nov 04, 2013 | Lands Phones
Slightly off frequency is it possible to correct
I assume it is digital tuning?
If it is digital tuning the answer is no.
Sometimes reception is better when you purposely mis-tune by one digit lower or higher than the stations call numbers.
If it is under warranty, try exchanging it or just listen to and compare another one or more of the same model to hear if they are all slightly off frequency.
Aug 03, 2013 | Eton E100 SW/FM/AM Radio
The FM stations will drift away after tuned in, the station will stay on for about two to three minutes and them fade away. Any help would be welcome
It is very possible that a critical component in the local oscillator for the FM band has become thermo sensitive. As the temperature changes the component is drifting slightly in spec.
Another type of fault to cause this, is there could be a problem with the voltage regulation of a voltage source that feeds the local oscillator for the FM. As this voltage changes slightly, it would cause the gain of the local oscillator device to change a little, and thus its stabilty would be effected.
The speculation about the thermo problem is more common than a voltage regulation problem.
This would require to be serviced by someone who has the instrumtation and who is experienced in troublshooting this type of circuitry.
Jerry G.
Nov 25, 2011 | Technics SA-EX140 Receiver
How do I preset the tuner for radio stations. I've never had a problem doing this with any other stereo. But what I think should work isn't!
Not very specific. Do you have the manual?
The following is from a VSX-03TXH manual. It ain't pretty but it may help.
I'm posting it in multiple parts due to space contraints.
37
Chapter 6:
Using the tuner
Listening to the radio
The following steps show you how to tune in to FM and
AM radio broadcasts using the automatic (search) and
manual (step) tuning functions. If you already know the
frequency of the station you want, see Tuning directly to a
station below. Once you are tuned to a station you can
memorize the frequency for recall later-see Saving
station presets below for more on how to do this.
1 Press the FM/AM button to select the tuner.
2 Use the FM/AM button to change the band (FM or
AM), if necessary.
Each press switches the band between FM and AM.
3 Tune to a station.
There are three ways to do this:
Automatic tuning
To search for stations in the currently selected band,
press and hold TUNE ?©/?? for about a second. The
receiver will start searching for the next station,
stopping when it has found one. Repeat to search for
other stations.
Manual tuning
To change the frequency one step at a time, press
TUNE ?©/??.
High speed tuning
Press and hold TUNE ?©/?? for high speed tuning.
Release the button at the frequency you want.
Improving FM stereo sound
If the TUNED or STEREO indicators don't light when
tuning to an FM station because the signal is weak, press
the MPX button to switch the receiver into mono
reception mode. This should improve the sound quality
and allow you to enjoy the broadcast.
Using Neural THX
This feature uses Neural Surround™, THX® technology to
achieve optimal surround sound from FM radio.
• While listening to FM radio, press AUTO/DIRECT for
Neural THX listening.
Dec 23, 2010 | Pioneer VSX-07TX Receiver
Toshiba tv 2151tb how do i tune in stations
Toshiba TV 2151TB Tuning
Press remote button adjacent to the picture brightness button.
The symbol of a clock appears.
Press the button again and the >>> symbol appears, this is for course tuning.
Touch the Increase Volume button and auto tuning starts.
When a station is found two green underlines appear.
Type the station number i.e.for 2 type 02, this stores the station.
Touch the Increase volume button again to find the nexr station.
Upto 39 stations can be stored.
Fine tuning of any station is achieved by pressing the tuning button until three blocks sysbol is displayed.
Use the Increase/Decrease Volume buttos to fine tune the station.
Feb 24, 2009 | Toshiba 19A26 19" TV
Wire antena (that came with SS5 system) causes a hum
It is assumed that the hum is coming down the aerial wire it self....The hum should be eliminated
dissappear if you remove the wire from its connector at the rear of the receiver.
If this is the case then reconnect the aerial and try to find a radio station to listen to..
When you find a station you will find the hum dissappears as follows:
When there is no station detected the receiver tweaks up its sensitivity via the Automatic Gain Control, (AGC) and when this happens any thing that is detected on the aerial is reproduced at the speakers and in your case its just a hum.
I have heard this event lots of times and mostly its scrackles or scratchs or other weird sounds which come down the aerial while the AGC is flat out at maximum..
The radio station transmits a sound "carrier" and within this carrier there is the music content.
The receiver detects the "carrier" when you tune to the radio station, and then it sets its receive
level to the setting made by the volume control and then lovely music is presented at the speakers..
So in fact your receiver is working as it should be ,.,,, no worries mate....
Now if the hum is still there when the music is there then you have a fault, but as you havent mentiond this aspect your receiver is in my view quite "normal".
Cheers For Now
From YUBEUT..
Sep 19, 2008 | Nakamichi SoundSpace 5 Shelf System
Connection and Reception
I would suggest to try another phone. I am considering that the phone line is okay. It is possible that there is a fault in the power supply inside of the base station. I have seen the supply section in the base station go defective causing hum, and or complete failure of the phone.
If the power supply is at fault, the failure can be a voltage regulator, or some bad capacitors, or something along that line.
Jerry G.
Apr 12, 2008 | Panasonic KXTG2344 Cordless Phone
Setting my preferred stations
you need to select your station then press the preset button then 1 thru 0 to store the station. repeat for the rest of yoiure stations you want to store.
Jan 08, 2008 | Audiovox XCS9 XM Radio Receiver
Bose Wave Radio Logo
321 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
