Question about Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive
WD My Passport 160 GB Hard Drive
I have just bought one of these drives. It works fine with my notebook(XP) at work, home with my PC (Vista) works too but it's thinking too much. I have to plug it than wait for about a minute just to open My Computer, than another minute to open my directories. When I first installed the drive to PC it didn't work at all. But in the morning I started PC with WD plugged it worked perfect. When I plug the WD while PC working makes more problems. Also there were other flash disks which did the same problem, working too slow and too slow copy rates. I thought that's a problem of front panel USB, other USB ports doesn't accept WD at all. Don't know what to do. I'm just starting my PC plugged with WD and only copying files and unplugg it. If it's plugged I cant even open My Computer in time. My mother board is ASRock. Also having problems with my front panel microphone and headphones, they are not working.
  • ceyhuntansu Nov 10, 2008
    i have first checked all my drivers and even updated which not necessary for WD. All my drivers look up to date. I still have the same problem. Not working when I connect the device while my PC working. Perfect when I start my PC while WD is connected (well I still need to wait a little bit until it recognizes what a WD device)
    thanks anyway, I'll keep trying. It more looks like a problem with my PC but I cant understand what it is exactly...
It sounds like you need to update the driver s for your your devices,
Did you format the drive/s before loading info on to the drive???me,
XP works well and Vista should tooo.....so I beleive your devices may need updating thanks
Let me know how it goes that before you rate Me thanks
I have just finished installing a WD250GB
Cheers Misterdj
Posted on Nov 08, 2008
The USB cable you are using is USb 1.1 and it will not give enough electricity to your WD.Or you may have disabled your USB ports by accident.The fornt ports of your computer won't give enough electricity to your WD again. See if your WD is vibrating.
Posted on Apr 05, 2009
Need driver & software
The Driver and software are built in, Stored on the WD it's self..
all you need to do is plug it in. It is a plug and play device.
WD Passport is not supported on XP or Vista 64bit
Xp and Vista do not put enough power to the usb ports to fire up the drive.
there is a cable you can get from WD that plugs into 2 USB ports to solve this issue.
Jul 02, 2011 | Western Digital WD Passport 250GB Portable...
I tried to format my 500gb WD passport essential with exfat using windows 7 for my mediastar pvr . Now neither pvr or windows 7 can see the harddrive
Windows 7 does _NOT_ support 'exfat' drives, as you have found out.
You can "format" the drive, to use 'FAT32' or 'NTFS' file-systems.
Dec 27, 2010 | Western Digital My Passport Essential...
Not detected in xp
hi
go to WD site and get drivers for XP downlod and run that then try hopw fully it will work
May 25, 2010 | Western Digital My Passport Essential...
MY PASSPORT ESSENTIAL WD1600ME-00 is not recognized by plug-and-play in either of my HP Desktop Windows computers (One with XP, one with VISTA). Power light comes on when attached to any USB port. Device...
You run MS Windows Update to download and install the latest OS updates. Your WD external HDD should be detected after OS update.
For non updates system, try to connect WD to the USB Port where it worked before. If you have 4 USB ports for instance, try to connect it to these ports one try at a time. Windows XP might have assigned one USB port for your device before when it was working just fine.
Feb 02, 2010 | Western Digital WD Passport 250GB Portable...
How to format WD Passport 1TB to FAT32 I have used WD external 500GB passport drive with my samsung 1080p9 dvd player successfully WD 1TB passport drive is not recognised by dvd player
Plug the drive into your PC.
Right Click on My Computer (or Computer in Vista/Windows 7) and select Manage.
Click on Disk Management.
Right Click the Volume in question and select Format. Select FAT32 in the options.
Dec 24, 2009 | Western Digital My Book Essential Edition...
WD320GB hard drive not working
Are you using a double power USB cable, which normally comes with W/D hard drives?
Also if the light on hard drive blinks the drive is not getting enough power from the USB port.
All the best!
Aug 11, 2009 | Western Digital WD Passport 250GB Portable...
Getting an old Dell Dimension to recognize a WD Passport
In the end, I assigned a different drive letter to the device and it worked.
There's a lot of info out there on how to assign a letter. Here's one link:
http://lifehacker.com/software/windows/change-windows-drive-letters-167525.php
Feb 17, 2009 | Western Digital WD Passport 250GB Portable...
320GB WD passport essential works with XP os but not with vista
both of my vista machines worked perfectly... i am not using the software that came on the drive. as a mass storage device it works perfectly.
Jan 29, 2009 | Western Digital Passport WDXML800UE...
WD Passport Elite 320 - won't install autobackup launcher
I just spoke to WD support...here is how to solve your problem:( I had the same problem and it works great now)
1. Connect your WD ext. drive.
2. Click open Computer.
3. Double click open the WD blue icon.
4. Double click open WD_Windows Tools.
5. Double click open WD drive manager.
6. Double click open the Setup icon for Vista 64 (the other icon
is for x86 windows)
run the setup and it will take care of your problem. enjoy!
Dec 01, 2008 | Western Digital Passport WDXML800UE...
Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive Logo
812 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
