Cars & Trucks Logo
steve Posted on Mar 15, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Problems starting in hot weather
Hard to start in hot weather.no problems starting in cold weather
Josh Canaday
Level 3:
Master:
  • Master 444 Answers
  • Posted on Mar 15, 2012
Josh Canaday
Master
Level 3:
Master:
Answers
444
Questions
Helped
138057
Points
1365
Remove gas cap in hot weather and see if it starts better. if it does its an emissions/purge issue
4 Related Answers
honeymokey
honeymokey
  • 3113 Answers
  • Posted on Feb 18, 2010
SOURCE: In cold weather, car floods when trying to start
ncc-1701-d do not listen to this guy. This car is fuel injected. NO CARBURETOR! it's a throttle body! Do not mash pedal at all when starting car anytime. Engine light on? May be a problem with the Idle air control valve or the map sensor check the vacuum hose that goes to the map sensor. Check for vacuum leaks also. Check the three way connector on the hose from the cruise servo to vac. source. reply. 3800 or 3.8 these are two different motors.
Anonymous
  • 367 Answers
  • Posted on Jan 16, 2009
SOURCE: cold weather starts
Your going to need a new battery. This is the simplest fix for the issue. I would also recommend a block heater. Certain models of these basically get mounted inline with your coolant hoses and they constantly heat and circulate your antifreeze so your car is instantly warm when you start it. They do have to be plugged into an electrical outlet but they are worth it in very cold weather.
Just don't forget to unplug them before you leave with the car :)
But for now sounds like the only thing you really need is a new battery. As much as i hate to say it walmart has some pretty good deals on batteries and they usually don't charge to put them in. Worth it especially when its cold.
honeymokey
honeymokey
  • 3113 Answers
  • Posted on Aug 20, 2009
SOURCE: vapor lock and starting problems
Never heard of that on a buick FI. When it gets hot does it cut off and restart later? More info.
alicantecoli
Colin Stickland
  • 22516 Answers
  • Posted on Dec 08, 2009
SOURCE: 51,000 act miles getting hard to start in cold
check the plug gap 25th
Cool mornings it doesn't want to start ,i have to turn the key to start and let it off several times and it will eventually start after that it starts fine all day and starts fine on warm days
How to Start a Car in Freezing Cold Winter Weather
www.wikihow.com > ... > Cars > Car Maintenance and Repair
wikiHowFreezing cold weather can take a toll on car batteries. ... It's much more difficult to start a cold car with a mostly-empty tank, so do yourself a favor and gas up ...
Why is it so hard to start a car in the winter? - HowStuffWorks
auto.howstuffworks.com/car-driving-safety/.../start-car-in-winter.htm
To start a car in winter, your engine has to work extra hard. Learn the top 3 reasons your car is hard to start in cold winter weather.
Debunking 5 Cold-Weather Car Myths - Popular Mechanics
1helpful
I have a 1995 Buick Park Avenue. Just recently it is hard to start what would cause this?
These are the some reasons why a car have problem in starting.
1. bad spark plug
2. bad wires
3. bad rotor
4. bad distributor cap
5. bad ignition coil
6. fuel pump could be malfunctioning
7. fuel filter could be clog
8. fuel accumulator could be faulty already
9. faulty fuel pump relay
10. fuel in the tank could be dirty
11. weak battery
12. dirty or corroded battery terminals
13. bad starter
14. loose wiring connection between battery, starter and alternator
Have these things check with your car, it could be one of this is your car's problem. Hope this might help!
http://www.clarks-garage.com/shop-manual/ts-01.htm
Car Won Start Copyright AA1CarYOU TRY TO START YOUR CAR BUT IT WON...
Hot and Cold When your Engine is Hard to Start
In order to surpass this problem and to prevent it as much as possible, learn how to solve it by knowing why it happens.
When a hot engine is hard to start, most of the causes are fuel related problems. Fuel cannot circulate well due to the way in which vapor blocks it. As a result, the engine would not start as easily as it should. In worse cases, it would not start at all. This happens if the engine is extremely hot.
Until after a while the engine was shut off, it would keep on acquiring temperature. The biggest amount of water vapor would be spreading around during this process. It therefore means that during this period, there are higher chances of its obstruction to the engine. So when you are driving in hot weather and you have just turned off the car and you experience difficulty in stating the engine, do not panic. Just wait for a couple of minutes and then start it back.
Because the fuel remains inside the injectors by being under a very intense pressure, engines that are fuel injected do not experience and suffer this problem as much as others do. In this case, fuel injected engines would not become so easily moved by vapors as compared to other engines. From this fact, it can be further deduced that auto mobiles may have different problems in starting their engines.
Another reason of a difficulty in starting a vehicle is the coinciding of the engine's hot temperature to a hot season like the summer. In this scenario, refiners alter from a fuel blend to another. Due to the process where in hot weather causes fuel to evaporate faster, gasoline refiners sometimes alter from a higher hot blooded fuel to a lower one when summer approaches. The fuel could evaporate too much that it would create too much vapor and would eventually inflict the engine. This instance happens when refiners alter back to a higher hot blooded fuel while the engine is still exposed to high temperatures of the summer season.
Now you know why hot engines are hard to start and what to do with it. What about if a cold engine is hard to start?
Difficulty in starting a cold engine is really a problem especially to those living in cold areas. This is experienced due to several reasons, and one of which can be based on the cold effect on liquids evaporation. Less gasoline is evaporated when the engine is cold. This causes the fuel to be more burdensome to burn due to the fact that it is burnt when it is evaporated.
Oil becomes much thicker in cold areas than in hot ones. This is another reason why cold engines are hard to start. Like any other fluids, oil alters its characteristics when it is heated or when it is in a very hot weather. Often times, this causes the oil to have problems at the time it circulates in the engine of the vehicle.
Other car parts that contribute to this problem are the batteries. Under a cold weather, the car batteries sometimes experience problems that consequently affect the engine of the car. When being cold, batteries loose their agility. This is because they do their jobs due to chemical reactions. And when they loose their agility, of course it means that they do not function well. Under these circumstances, the energy of the car is affected and so the engine start is also affected.
Another problem could be the air intake. Like in the case of your Dodge car, the Dodge cold air intake, it might not be functioning well that affects the performance of your engine.
If these problems happen together at the same time, they imply a huge problem in starting the engine.
Spray ether into the engine. Use one that would evaporate quickly and help the engine start. Do this to overcome the problem on the lack of gasoline evaporation. Aside from this, you can also use thin synthetic oils in order to prevent very thick oil that would not circulate well. You if can maintain the car from being isolated from cold, better!
Why will my 2002 dodge intrepid start perfectly in cold weather, but not in hot weather, or as the temperature rises during the day? Priscilla TravisBefore it would only start in cold weather, and not
Could be the neutral safely switch is still not adjusted properly. With your foot on the brake and the transmission in neutral, move the shifter a little bit in either direction while holding the key in the start position. If the starter engages, the switch needs to be adjusted.
1helpful
2006 nissan navara wont start in cold weather
Its cold start issues:----
Go through the list of help links mentioned below:----
Click the link :----
Cold start problem and vehicle shudder around 2500 to 3500 rpms
http://repairhelpcenter.blogspot.com/2012/10/cold-start-problem-and-vehicle-shudder.html
Low idle when cold out side?
http://repairhelpcenter.blogspot.com/2011/12/low-idle-when-cold-out-side.html
Ford explorer 4.0 will not idle when cold?
http://technoanswers.blogspot.in/2012/02/ford-explorer-40-will-not-idle-when.html
Automatic transmission shift lever hard to move on cold mornings?
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
Car won't start when cold?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-when-cold.html
These will help.
Thanks.
1999 Malibu hard start in hot weather, after it starts runs great lots of power. starts when cold in cooler weather.V6 3.1 engine. have gas at rail. changed spark plugs and wires, IAT and ECT sensors also...
this is most likely a fuel vapor issue.
fuel boils in the fuel rail causing a hard start after a 'hot soak'.
the fix is to replace the fuel pressure regulator and the pcm. good- day !!
2answers
Rolls royce 1978 shadow. hard starting problem
remove air ducts, put some fuel drops in intake trhottle , and try to start engine , maybe have fuel pump is worn
1997 dodge ram wont start hot, starts fine in the cold but in hot weather needs the throttle pumped and sometimes even that wont do it
What is the condition of the starter ? Is this an engine hard to turn over problem when hot ? If so, the starter might be grounding out, this happens only when the casing is hot.
BMW 325, hard to start in hot weather.
before you try to start her again in hot weather, open your fuel filler cap, listen for any pressure release, close the cap, and try to start, if this works,then its just heat expansion in the fuel tank, replace the filler cap if this is the case
97 Mercury Cougar hard starting in cold weather
No ,this vehicle doesn't have a cold start injector . Plus the fuel filter wouldn't have anything to do with it either , cold or hot would act the same . I would have it checked with scan data , do you know what that is ? Could be coolant temp sensor , mass air flow sensor .
048 Engine Hard to Start or No Start Scan Data for Starting Problems
Testing an not guessing is the way to a proper fix !
How are thing's in Kent washington ? I lived in Vancouver ,WA. for 12 yrs. , worked at Kendall chevy an bill copps cadillac . Live in east coast now .
Top Buick Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Buick Expert? Answer questions, earn points and help others
