I need to setup the bios setup utility because i have change a few and now it will not start up
  • 849 Answers
Press dell, f1, f2 or f10 according to your pc bios to enter in setup utility
Posted on Nov 04, 2008
NEC laptop stuck in Phoenix BIOS Setup Utility
While in the BIOS setup utility, go through the tabs/menus looking for BOOT sequence. Configure the laptop to boot from CD-Drive before any other drive. Have the installation CD in drive.Save the changes made to the BIOS configuration, and exit the BIOS. Reboot.
If the installation medium itself does not have a problem, you should be able to boot from it and have the opportunity to install the operating system.
Jan 29, 2014 | NEC Computers & Internet
Bios utility
BIOS Setup utility?
Dell laptop?
Lot of information here.......let me see if I can sift through it.........
Post the model number in a Comment.
The model number can be found on the Bottom of the laptop.
As soon as you turn your laptop on, watch for the Dell logo screen.
WATCH the bottom of the screen.
What key does it state to press, to - enter BIOS Setup?
Write it down.
If Windows loads let it load, and run a few minutes. Then turn the laptop off normally.
THIS time AS SOON AS you press the Power On button, start tapping on that BIOS Setup key.
Tap in 2 second intervals.
You may hear beeps. Those are Stuck Key Error Code beeps, and it is you that is doing it. Ignore them.
This will get you into the BIOS Setup utility.
If Windows doesn't load, press the CTRL key, and ALT key, and DELete key, AT THE SAME TIME.
This will restart your laptop, and start tapping on that enter BIOS Setup key.
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 15, 2013 | Dell Studio Computers & Internet
I want to change language of my ibm netvista desktop
The IBM Netvista should have options to change the language settings built in if you read the manual but generally, if you follow these instructions it usually works.
Go to the BIOS utility and change the language:
To run the Setup Utility program, use the following procedure.
1. Shut down the computer and wait for all lights go off.
2. Start the computer.
3. When the Setup Utility prompt appears on the screen during start-up, press F1. A Setup Utility menu will appear.
4. Follow the instructions on the screen.
5. When finished, select System Summary to verify that any configuration changes have been accepted.
Feb 06, 2013 | IBM NetVista PC Desktop
Bios nonva 5600 aspire
The BIOS Setup Utility is a hardware configuration program built into your computer's BIOS (Basic Input/Output System).
Your computer is already properly configured and optimized, and you do not need to run this utility.
However,if you encounter configuration problems, you may need to run Setup.
To activate the BIOS Utility, press
m
during POST (when "Press <F2> to enter Setup" message is promptedon the bottom of screen).
The setup screen displays BIOS as follows:Navigating the BIOS UtilityDuring setup,all Fn function keys and power saving functions are disabled.
There are five menu options:
Main, Advanced, Security, Boot and Exit.Follow these instructions:
To choose a menu, use the cursor left/right keys (zx).
To choose a parameter, use the cursor up/down keys (wy).
To change the value of a parameter, press p or q
Press
while you are in any of the menu options to go to the Exit menu.
In any menu, you can load default settings by pressing t
You can also press u
to save any changes made and exit the BIOS Setup Utility.
hope this helps
Aug 02, 2012 | Acer Aspire 5600 Series 5630-6951 Laptop
Can't access bios utility setup
You have different keys to click on different PC. Since you have not specified the kind of laptop you have, here are few keys you have to strike: Turn off computer first then before it opens, you have to click DELETE key randomly to enter to bios utility setup. If it does not work, turn off again and try F12, if it doesn't turn off then try these: F1, F11 and ESC.
Congratulations.
Nov 27, 2011 | Computers & Internet
What is the boot up sequence please
You need to go inside BIOS to find out whats the boot sequence. To activate the BIOS Utility, press F2 during POST (when “Press <F2> to enter Setup” message is prompted on the bottom of screen).
Press F2 to enter setup. The default parameter of F12 Boot Menu is set to “disabled”. If you want to change boot device without entering BIOS Setup Utility, please set the parameter to “enabled”.
Press <F12> during POST to enter multi-boot menu. In this menu, user can change boot device without entering BIOS SETUP Utility. Navigate to BOOT page on top.
Hope this helps!
Aug 22, 2010 | Acer Aspire 5535-5050 Notebook
Acer travelmate 2410 phoenix bios setup utility
u got to replace ur BIOS. but der r ways to recover the BIOS password using default passwords, i need to get to know ur MOTHERBOARD build.
Mar 31, 2010 | Acer TravelMate 2300 Notebook
Entering bios setup
Occasionally, most computer owners will need to access BIOS on their computers in order to change or update the computer's most basic operations; such as memory and boot order.
Different computer manufacturers will have you press different buttons to access BIOS depending on the model you have. For example, on my laptop, I press F12 to enter the BIOS setup utility.
Here's how to figure out how to enter your computers BIOS setup utility. 1
Turn your computer on or shut it down and restart it if it is already on.
  • Step 2 As soon as the computer starts up, watch for a message that informs you about which button you will need to push in order to enter setup, aka BIOS.
  • Step 3 The opportunity to press the correct key to enter BIOS passes by quickly, so you need to find that key and press it before the computer moves on to the next stage of booting. If you miss your chance, just restart the computer and try again.
    You can always access BIOS, even on computers that dont have an operating system installed. This is because BIOS is part of your computer's motherboard hardware and has nothing to do with Windows, Linux or whatever operating system you may be using.
  • Dec 02, 2009 | Alienware PC Systems M7700 Notebook
    Bios Set
    hai, Harish
    your problem seems not BIOS related.
    The problem is that some of your installation is not completed.
    If you have the XP CD, insert it and complete the installation.
    For changing the BIOS setup, just after switching on the computer, press DEL or F2 (refer motherboard manual for the correct key) to start the BIOS utility program to start.
    Be careful before changing anithing in the BIOS.
    Rabby
    Jun 15, 2008 | Intel P4 System Configurator (P4SDRAM1) PC...
    Language Problem
    i have ibm netvista pc desktop im I want to install windows xp HDD so i went up to the BIOS, but the BIOS Language is Different, Not English, Japaneses Language, arching for BIOS Update, but i couldn't find, my machine model number . i was trying to boot the system by windows start up disk but it ddn't work also. Plz Help me,
    me,
    Feb 22, 2007 | IBM NetVista PC Desktop
    Computers & Internet Logo
    207 people viewed this question
    David Payne
    David Payne
