Question about One For All URC4110 Remote Control
5 digit Remote Code for Centrex TV
Cant find 5 digit (using only numbers 1 - 4) to programme my very basic remote control. have tried searching for code with remote but with no success.
You should only need a 4 digit code. Try 0056 for a Centrex TV.
Cheers
Posted on Dec 27, 2008
Centrex remote control code
028,011,043. Check these codes. If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Apr 16, 2013 | Universal Remote Control Televison & Video
How to program tv using this jensen universal controller
Hello
Proceedings to programme Jensen remote with TV follows.
[1] Manualy turn on the device you want to programme.
[2] Find three digit code for that device which you want to programme.
[3] Hold the device key down until the green indicator linght come ON.
[4] Release the device key. Within 30 seconds enter the three digit code number of your device.The light will flash when the right code has been entered.
[5] Press the Power Key. If the component turns off, you have entered the right code.
OK.
Apr 17, 2011 | Jensen 143307 Remote Control
Hi need code for ancient centrex tv for universal remote help aaaaaaaaaah
Hello
Centrex is not listed with URC04110 universal remote coldes. But you can search and find the code for your device with this remote control. I'm not sure will it work with your old Centrex TV. Anyway try. Wish you the best.
SEARCHING FOR YOUR CODE
If your device does not respond to the remote control after trying all
codes listed for your brand, or if your brand is not listed at all, try
searching for your code. For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED blinks twice, then release
SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns
off.
NOTE: In the search mode, the remote control will send IR codes
from its library to the selected device, starting with the most popular
code first.
5. To lock in the code, press and hold SET until the LED blinks
twice, then release SET.
6. To search for the codes of your other devices, repeat steps 1 through
5, but substitute the appropriate device key for the device you are
searching for.
CHECKING THE CODES
If you have set up the remote control using the Searching For Your Code
procedure, youmay need to find out which four-digit code is operating
your equipment:
For example, to find out which code is operating your TV:
SET.
3. Enter 9 - 9 - 0.The LED will blink twice.
4. To view the code for the first digit, press 1 once.Wait 3 seconds,
count the LED blinks (e.g., 3 blinks = 3) and write down the number.
NOTE: If a code digit is "0", the LED will not blink.
5. Repeat step 4 threemore times for remaining digits.Use 2 for the
second digit, 3 for the third digit, and 4 for the fourth digit.
6. To check for codes of other devices, repeat steps 1 through 5, but
substitute the appropriate device key for each device you are checking.
OK.
Mar 08, 2011 | One For All URC4110 Remote Control
Could RCA remotes be programmed for Precision Tv?
Try the below website.If you can fine your tv from list you can programme it.Try using the auto programme.
HI,
Direct Code Entry:
Find the code your device.
1. Press and hold "CODE SEARCH".
2. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
3. Enter the 3-digit code number.
4. Release "CODE SEARCH".
5. With the device on, press another button to test (volume control/power button).If it does not work, repeat steps 1 to 5 with other codes which you have.
follow the below steps to set remote without codes
Code Search:
1. Turn on the device you wish to control.
2. Press and hold "CODE SEARCH".
3. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
5. Press ON/OFF repeatedly until the device turns off.
6. When the device shuts off press and release ENTER.
7. Try using the remote. If it does not function repeat steps 1 through 6
To Get The Code Please Go To Below Website:
http://www.rcaaccessories.com/remotefinder/
You need to select the following information from the drop down list
1.Model of the remote
2.Type of device to which you want to program(TV/DVD/VCR)
Thank you
Sep 13, 2010 | RCA RCU300WBL Remote Control
Bought a rca universal remote. want to use with my emerson tv.model #ewt1921 cant seem to program a code that will work. br
HI,
Direct Code Entry:
Code Search:
Thank you
Sep 13, 2010 | RCA 257003 Remote Control
I have and old floor modal tv in good condition I have a Rca universal remote that I dont have the program codes and cant seem to fine them online
As we dont know the TV make you can use code search method.
It basically searchs the codes automatically.
Code Search:
If you can find the codes for your /tv please follow the below steps
Direct Code Entry:
Thank you
Aug 07, 2010 | RCA 6-Device Universal Remote
How d oi program this remote?
Please follow the below steps to set up your programme
Direct Code Entry:
  1. Find the code your device.
  4. Enter the 3-digit code number.
  5. Release "CODE SEARCH".
  6. With the device on, press another button to test. If it does not work, repeat steps 1 thorugh 5.
Code Search:
  5. Press ON/OFF repeatedly until the device turns off. You may have to do this up to 100 times.
  7. Try using the remote. If it does not function repeat steps 1 through 6.
To get the code please go to below website
Please
Provide model of your remote
device to be programmed(VCR,TV)
Make name(toshiba,sony)
Thanx
Jul 25, 2010 | RCA RCR460 Remote Control
How do i program my remote to my tv, i've tried many methods and i've done it before. i am ready to scream, help!
Direct Code Entry:
Code Search:
Please
Thanx
Jul 24, 2010 | RCA Universal Remote Control
URC-3605B1 need code for insignia tv
remote control after trying all codes
not listed at all, try searching for your
for your TV:
2. Press and hold SETUP until the LED
blinks twice, then release SETUP.
blink twice.
4. Aim the remote control at the the
TV and slowly alternate between
the TV turns off.
control will send IR codes from its library
most popular code first.
SETUP until the LED blinks twice,
then release SETUP.
for the device you are searching for
procedure, you may need to find out
which four-digit code is operating your
equipment:
operating your TV:
blink twice.
press 1 once.Wait 3 seconds, count
NOTE: If a code digit is “0”, the LED will
not blink.
5. Repeat step 4 three more times for
repeat steps 1 through 5, but substitute
As before,write down each fourdigit
code.
http://www.rockabilly.net/files/manuals/URC-3605.pdf is my source for the info
http://www.rockabilly.net/files/manuals/URC-3605-codes.pdf these are the codes, I didn't see insinia in the TV section, so you may have to use the search feature
May 11, 2009 | One For All URC-3605 Remote Control
One For All URC4110 Remote Control Logo
735 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
