Question about Olympus Camedia C-750 Ultra Zoom Digital Camera
How can my c750 detect external flash?
I happen to have this cam for about 5 years... apart from being bulky.. i don have anything against it. Recently i tried to fix in a flash to the hot shoe of the c750. can anybody tell me how can the camera detect external flash?is there some mode that i have to activate?
  • 25 Answers
Please read the manual about using manual mode. The external flash mounted on hot shoe fires only when the camera is in manual mode.
Please check and confirm if this solved yr problem.
Posted on Oct 17, 2009
T3 built in flash won't pop up. Says I have an external flash attached, but I don't.
There is a small flat leaf spring under the hot shoe rail where an eternal flash slides in. If an external flash is mounted the leaf spring is pressed against a small button telling the camera that there is an external flash mounted. Take a toothpick and rub under the hot shoe rail gently to more the leaf spring or unjam the leaf spring. You may even see the button depressed, poke at it a time or two with a toothpick, even a drop of rubbing alcohol may unstick this button if a sticky beverage sprayed on it.
Dec 25, 2012 | Canon EOS 1100D / Rebel T3 Digital Camera
Can the camera sp-800UZ take rapid shots pics with flash going off every pic taken
In short, no. As with all flashes, the capacitor takes a while to recharge (via power from the low voltage battery which is amplified to many thousands of volts in the capacitor) between each shot. How long exactly depends upon how far it's discharged each time, so for close-up objects which fill the frame and need little flash, the discharge will be relatively low and you may get a few shots off in a row, and for distant objects using a more powerful flash discharge it may totally discharge with each shot.
The bigger and more powerful the flash unit, the better it will perform in that respect which is why professional external flashguns are big, bulky and cost hundreds or even thousands of dollars. A built-in flash such as on your camera is a compromise solution and is not intended for heavy use. More advanced cameras may have their own built in pop up flashes to take close up snapshots, but for anything else have connectors to enable the use of more powerful external units.
Mar 04, 2011 | Olympus SP800UZ Digital Camera
No problem, I just need to know how much it weighs.
This thing weighs 250 pounds,had this big bulky DLP tv before for 5 years,gave it to good will,because it big and very bulky.Plasma and LCD tv same size weighs only 50 pounds.
Oct 27, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Webcam stopped working
Try to reinstall software for the webcam,If it still don´t working You can open your control panel and see in the hardware system if your webcam is showing here.If it is the electronic or cam eye is defect.Then try a extern USB webcam to see if it will be detected.
May 30, 2010 | ASUS Eee 4G Notebook
When I plug any USB stick into the port, it isn't recognised. In Device Manager, Other Devices shows yellow question mark against the stick name.
Try confirming your usb drivers..
Also run a scan against the folders that has your driver files..
That might work
Oct 01, 2009 | Dell Inspiron 1000 Notebook
The dvr99 3 dvd home theater receiver will not stay on
Protect kicks on commonly when it over heats or when the speaker wires are crossed and it detects a short on the output. Your symptom sounds as though it may be a speaker wire because it happens right after the power is turned on. Check the speaker wire carefully, it has a habit of breaking inside the connectors of both the receiver and the speakers, especially after 5 years of service.
Feb 27, 2009 | Audio Players & Recorders
LG Washer / WM2487H*MA...2 days old. Wash setting...."Bulky/Large QUESTION:::When attempting to select additional "wash options" from the Option Buttons panel, I keep getting a display...
My LG Tromm washing machine just stopped in the middle of the cycle, It started flashing the letters LE, what does that mean. I have had it for 4 years and this has never happened.
Jul 27, 2008 | Washing Machines
Web Cam
If you have a plug and play OS it should have detected the web cam then asked for drivers. try connecting the cam to other PC and lap top they detect the cam it may be a hardware problem if not the web cam maybe defective.
May 30, 2008 | Computers & Internet
PROBLEM: F828 & external flash
I think this is due to the TLL preflash of the 828 internal flash. Each time it actually fires 2 flashes. First one for metering and second one for actual exposure. First "fake" flash probably trigers your external flash which is too early. Slution... hmm i think there are afordable slave adapters out there which detect the TTL preflash, ignore it and fire the external flash on the right timing along with the main flash. cost.. about few tens $ i think. they can detect also infrared light so you can mount IR filter on your internal flash to prevent interfering with the exposure...
Sep 12, 2005 | Sony Cyber-Shot DSC-F828 Digital Camera
Olympus Camedia C-750 Ultra Zoom Digital Camera Logo
80 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
