Question about Quantaray QSX-DigiPro 8500 Tripod
Dead Legs on Tripod
All three legs of the tripod are suddenly floppy. They were fine before the transatlantic flight. Now they flop all over the place. Can't seem to pinpoint the problem. Seems to be a tightening issue of some kind, but don't know how any screws would loosen up while stowed in a bag. Ideas? Thanks, -M
  • phoephot Jan 07, 2008
    I have the same problem, although no flight was involved, two of the three legs are loose and no matter how much I rotate the knob on top of the leg, there is no difference, did you ever resolve your problem?
  • grant
    grant May 11, 2010
    I realize this is an old post, but if it is still a concern, where is the "Flop"- in the joints where one leg slides into the other, or at the top of the leg where it joins the metal casting that also holds the column?
Here  we go.  It sounds like you might have a problem with a strip thread or oil on the legs.  If the thread is stripped you'll have to replace it.  If it is not grabbing, wipe the legs down with alcohol or some type of solvant.  If the wipe down does not work try a fine sand paper so that it grabs better.  Let me know how you make out. Kennardsr@yahoo.com
Posted on Feb 23, 2008
  • 3 Answers
I have no ideas, but if you buy another tripod, I owuld like to buy your old handles from your 8500.
Thanx
Rick
817.846.8464
Posted on Dec 24, 2007
SOURCE:
Manfrotto 785pl
It may be possible. Unscrew this bit from the legs and see if you can reattach it to the rest of the head. Otherwise you will need to purchase a new head, but the legs will be fine.
Diane
NYC Photo Safari
Apr 02, 2014 | Photography
I need instruction manual for manfrotto 058b tripod
There is a red slider under the main casting that will release the legs all together.
Apr 13, 2013 | Manfrotto 058b Triatt Camera Tripod Black
I Need a replacement clamp/holder for one of the tripod legs for my Tasco telescope. The tripod legs are 5/8" dia & each leg fits into its own holder. one of the leg holders are broken and needs t
Looking at your other posts, you don't seem to have a lot of luck with technology - perhaps change the focus of your interests, hmm ? For your scope / tripod problem, take it to a service centre.
Nov 16, 2017 | Optics
How do you install the batteys in the stanley tripod legs?
To replace the batteries in each side of the 3-in-1 tripod light, you'll need to slide each light out of the central frame. Once each individual light is out on its own, you should be able to easily unscrew its bottom, giving you access to the battery compartment. Unlike the original Stanley tripod light, the actual tripod legs no longer hold the batteries.
On the original Stanley tripod LED light design, the black tripod leg tips simply unscrewed after you popped them out into the "stand" position. Much simpler to figure out.
Jun 25, 2011 | Stanley 3in1 Tripod LED Flashlight 95155
Tripod legs aren't snapping into place
Hi all the professional tripod are moving in varying degrees. I also believe that, you made some mistake. I like to know about your tripod. Please send me the tripod brand name & model no also. Thanks.
Feb 18, 2010 | Photography
Plastic locks Vivitar V900 tripod are breaking.
the plastic locks on our vivitor 980 tripod legs are broken now can i replace them. jan
Mar 17, 2009 | Photography
Want specifications for titan ii ii-950
Call Ritz Camera at 877-999-RITZ (7489). They "might" be able to assist you. Ritz's generic lenses are Quantaray made by Sigma. I don't know who makes the tripod. They are able to provide documentation for you, but I don't know if they will. Ritz has an online help form that you can fill out on their web site also
The little 'hooks' on the bottom of the legs 'snap' into each other to secure the legs together. Each leg has a 'hook snap' which clicks into place with the other legs. It is merely a way to secure the legs from flopping open. I bought the same tripod, a good solid piece of equipment. No instructions but its easy enough to figure out. Hope this helps.
Feb 26, 2009 | Quantaray QSX-DigiPro 8500 Tripod
I dont know how to extend the legs of my VCT MTK Sony tripod
That appears to be a mini tripod.. it is unable to extend the legs any further..
Feb 18, 2009 | Sony VCT-MTK Tripod
With what can I lubricate the legs onmy aluminum Mafrotto tripod?
Dear Winnieg,
I would avoid using a lubricant on your tripod legs, because you run the risk of the legs not tightening down anymore. I would try cleaning the tripod thoroughly first, because most of the time this is caused by dirt. If that dosen't work I would try rubbing on a small amount of candle wax onto the legs, and then wipe the legs down with a clothe.
Sincerely,
Allan
Go Ahead. Use Us.
Mar 14, 2008 | Photography
One Leg has loss it's grip.
take it apart, there is a rubber ring like a belt or rubber band, either broken or missing. you will have to find a relacement for that, may have to take apart another leg to have one to compare, course I don't honestly know where you will find that piece. too take it apart just keep spinning the lock counterclockwise until it comes off. good luck.
May 26, 2007 | Velbon Ultra MAXi Tripod
Quantaray QSX-DigiPro 8500 Tripod Logo
165 people viewed this question
Top Quantaray Photography Experts
Solo4665
Solo4665
Mark
R.A. Ellis
R.A. Ellis
Are you a Quantaray Photography Expert? Answer questions, earn points and help others
