Question about Canon imageRUNNER 5020 Copier
Error E00001-0000 I was setting up univsersal send kit numbers, the error abovr appeared when some one send a print in the process, what could have gone wrong?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
Problem w/fuser check:
lamp
thermistor
thermofuse
Posted on Nov 04, 2008
I'm getting error 94,7000.00:114.36 on my Xerox 8570 Printer. It sounds like a lot of spinning on the maintenance kit when I boot it. Any suggestions?
The error is a Process Drive Fault. This may be a problem with the Process Drive's Gears.
You probably need to go through the replacement procedure again.
Xerox says to check if they are in their home positions. NOTE: Usually, manually tilting the head back and forth using Drum Maintenance Shaft should leave the Process Drive aligned.
Sep 12, 2014 | Xerox Corporation Xerox ColorQube 8570DT...
Xerox 8560 error code 07,007.40
That error signifies a problem with the printhead tilt, you need to replace the Process motor camshaft pivot kit, part number 8560-Z2.
http://www.iteminconline.com/8560-z2_8560-z2-xerox-8560-process-motor-camshaft-kit.htm
Feb 07, 2014 | Xerox Phaser 8500/DN Printer
My HP Laserjet 3050 used to print automatically after each fax sent a call report showing that the page(s) had sent. For some reason, after a service call, now it doesn't do that any more and I have...
Hi Dear
HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  1. Press the right arrow until Reports appears in the display, press the checkmark.
  2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
  3. Press the right arrow until Print Report appears in the display, press the checkmark.
  4. Right arrow to the option of choice, press the checkmark to save the change.
FAX call report options
  • Send Fax Only - a confirmation sheet will only print when a fax is sent
  • Never - no fax confirmation sheets
  • Every Error - default setting
  • Send Error - a fax confirmation prints when the fax transmission encounters an error
  • Every Fax - a fax confirmation sheet will print for incoming
Jun 01, 2011 | HP LaserJet 3050 All-In-One Printer
How to stop to print the journal after send fax everytime?
Sending Confirmation
This report shows the fax number, the number of pages, elapsed time of
the operation, the communication mode, and the communication results.
You can set up your machine to print the message confirmation report in
one of the following ways (see page 5.3):
• Automatically after each transmission (ON)
• Automatically only if an error occurs during transmission (ERR)
• No report printed at all (OFF). You can print this report manually at
any time you want.
SENDING CONFIRM - A confirmation report shows whether the
transmission was successful or not, how many pages were sent, etc.
Select ON to print a confirmation report automatically each time you
send a fax.
Select OFF to turn this feature off.
Select ERROR to print only when an error occurs and the transmission
was not successful.
Nov 27, 2010 | Samsung SF-5100 Plain Paper Laser Fax
Head tilt error
You will most likely have to either clean the stainless steel print head block, or get to the print head area and get the print head wiper unstuck from the print head.
Those 2 are the most common reasons for the print head tilting error.
The wiper blade clutch may be failing, but thats not as frequent on the 8560.
Feb 24, 2010 | Xerox Phaser 8560DN Laser Printer
What is error code E000025 0002 for a Canon Color Image Runner C3380i and how do you fix it?
Product : imageRUNNER C2880 / C3380 Title : E025 sub code 0002
Problem :
The machine is giving an error code of E025 with a sub code of 0002 indicating an error with the cyan toner motor.
Solution :
Replace the Process Kit Relay PCB. Item 58 of the Hopper Assembly circled below, part number FM2-8266-000. NOTE: the service manual refers to this part as the Process Kit Relay PCB while the parts catalog calls it the Connecting PCB Unit.
getfile.asp?rid=24817
Apr 27, 2009 | Office Equipment & Supplies
Xerox 8560 printer error message
That is a fault in the process drive motor area.
It is the assembly that operates the maintenance kit movement.
You may simply have to reseat the maintenance kit.
The motor drive train may also be mistimed. If you have purchased that machine in the last year, there is a one year onsite warranty on that product. If so have your serial number ready and call 1-800-835-6100.
Aug 11, 2008 | Xerox Phaser 8560DN Laser Printer
My canon mx310 wont allow me to send a fax, it says 'waiting for report' when i press send.
I have the solution for this problem. You need to go into your fax settings, and adjust the RX Settings. There is an option there to "print if no ink" and you set that to YES, and it will spit out the pending report that is preventing you from sending faxes.
May 25, 2008 | Office Equipment & Supplies
Fax confirmation set up
document.tlSearch.tx.value=unescape("") s.gif s.gif HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  • Every Fax - a fax confirmation sheet will print for incoming and outgoing faxes
Mar 31, 2008 | HP LaserJet 3050 All-In-One Printer
Fax Confirmation Sheet
Jan 22, 2008 | HP LaserJet 3050 All-In-One Printer
Canon imageRUNNER 5020 Copier Logo
1,264 people viewed this question
old marine
old marine
