Question about GPS
Intellinav I am not able to charge my gps. Elec or in the car. I wonder it the connection is loose. I plug it in and nothing happens can you give me a RMA number so I can send it in? Thank You. Jennifer
    Novelist:
    Scholar:
  • 114 Answers
If it won't charge from mains or car adapter that does suggest a physical problem, try removing and re-seating the battery if it's accessible and try blowing or vacuuming out the power socket on the device to clear any dust/fluff.
Absolutely no chance what so ever of giving you any service information or numbers as you have not mentioned where you are in the world or indeed what model Intellinav device you have, however you can find warranty servicing information on Intellinav's website: http://www.intellinav.com/
Posted on Nov 05, 2008
I hqve a 1995 toyota camry with intermitent start issue. i have had electrical system check and the battery,alternator and starter all check fine. this problem just recently started. when it happens the...
Sounds like the wiring plug (key/ignition) The toyota manual pictures the plug and its connections but gives no clue where it's located.
Your radio is a good clue to this glitch. It's losing it's constant (unswitched) elec. power. This means either your car is having a dead elec.system,, or a relay is loose or going bad. Check the security of all your relays under the hood.
Take it to a good shop, but not a Toyota shop.
Finally, try starting in neutral nextime it won't start. Hold the key in start and reach over with your left hand and slide the lever into neutral.. clumbsy but thats the way to do it.
Nov 20, 2009 | 1995 Toyota Camry
Fatal application error
methinks you are in firmware update territory...go to that site, and enter model number, and re download the firmware.
Mar 15, 2008 | Fine Digital FineDrive 400 GPS Receiver
Nothing Happens
This happens when the GPS unit is completely discharged. Try charging the GPS unit from an external source (USB from your PC or 5V USB power adopter). After a full charge, if the GPS unit powers on then something is wrong with the power cable or the 12V plug and you need to replace it.
Aug 07, 2009 | Garmin nuvi 200 Car GPS Receiver
I just unpacked my Garmin Nuvi 750. I plugged it in, played around a little, and left it to finish charging. Now, it won't turn on. At all. I connect it my car for power, and nothing. I plug it into...
Same thing happened to me. Just bought it off Ebay. Had a little charge on it then tried to charge via the car, nothing, then by USB for some hours. Has now turned itself off and can't turn it on. Obviously a dud battery. Ebay seller is yet to get back to me.
May 02, 2009 | Garmin nuvi 750 GPS Receiver
AUDIOVOX NVX226 NOT RUNNING APPLICATIONS
the file is missing contact the nanufacture
Apr 11, 2009 | Audiovox NVX226 GPS Receiver
My GPS won't turn on.
I had this issue also. When I got it out of the box, it had maybe 30 minutes of playtime without a charge before the battery went low. I used the USB it came with and found plugging it into my laptop AND desktop does absolutely nothing; even though the magellangps.com states the USB can be used as a charger on the PC.
It's been less than 8 hours since I've had it, and I have not gotten a chance to use the car adapter to charge it... I have a DC/AC unit inside my house which I am using to charge the unit and it works fine (incase you dont know what a DC/AC adapter is; its pretty much a lighter adapter that plugs into the wall).
MAKE A LONG STORY SHORT -
With my migraine starter experience with charging and powering on; I have read on 100's of Magellan 3250 reviews that cold tempratures cause these issues.
Other possible causes:
Battery is 100% dead = leave it in your car charging (HIDE UNDER THE SEAT!)
If the USB port plugged in charging in the car; if it is still not working, make sure that the FM part is also plugged in. I found that my GPS does not charge with just the USB end plugged... At least for me, it will only charge with BOTH ports plugged....
I hoped my novel helped... If it didn't; return your Magellan, and buy a GARMIN GPS. I have a Garmin that I bought for my hubby, and 2 years later, has never once experienced any issues.
May 09, 2008 | Magellan Maestro 3250 GPS
The GPS won't charge
I answered this on another thread, I removed the back cover, 6 screws, and pulled the battery connector from the board, waited a minute or two, then reconnected. another poster said also that the connector for the power may have gotten loose, you can tighten that also but be careful. I did not have to do this, only the battery. Do NOT do this with a power cord plugged in, to be safe.
May 03, 2008 | Magellan RoadMate 2200T GPS Receiver
Nuvi 250
Have you used the wall charger to fully charge the battery? If the battery is too low after lying around for a month it wil not start, giving it a couple of minutes of charging wo'nt help either, a good and full charge will!
Mar 29, 2008 | Garmin nuvi 350 GPS Receiver
Intellinav.exe application error
HELP!! I keep getting Fatal Application Error. Application entellinav.exe has performed an illegal operation and will be shut down. If this problem persists, contact the program vendor. Program: Intellinav.exe
Exception: OxC0000005
Address: 00125D64
Oct 11, 2007 | Nextar Q3 GPS Receiver
Initial GM-501
its a software issue....it turnes out initial is out of bussiness...they sold their technical support to a third party company real *** holes...its a manufacrurer error....they told me is i wanted to fix it they will have to charge me $150.00 to reset the software....thats rediculous i shoped around and the initial units are runing around $120.00....well good lood and never buy an Initial product
Oct 01, 2007 | Fine Digital FineDrive 400 GPS Receiver
GPS Logo
73 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
