Question about Belkin 802.11g Wireless Desktop Network Card [ F5D7000 Wireless ] (109061)
Reply the lights just keep going on and off the adsl is on not sure what you mean by the router page
  • 113 Answers
Start-run-type cmd- in black screen type  ipconfig- get the default fate way number -type tat nos in the browser address bar and thats the router page- check in tat page wts the status of the adsl connectivity status if u r connected to the ur isp. and i need little more specific answer such as the name of the lights and color of the lights
Posted on Nov 04, 2008
What happen when a adsl line work with a phone but not with a router
The phone line does two jobs. Voice phone which is what it was originally used for and ADSL modem which works at a high audio frequency.
Somewhere between the phone socket and the modem should be a filter splitter. One part goes to the phone and the other to the router. Make sure you have that.
The modem will have a power light and several additional lights. Assuming the power light is on we are interested in two of them; The ADSL light and the Internet light. When you switch the modem on you should first see the power light flash then go solid. Then the ADSL light will flash and then this should go solid. If this light does not come on then you have not plugged the phone wire in properly. If this light just keeps flashing slowly then the modem can't see an ADSL signal on the phone line. If you have a spare router you could try it and see if the ADSL light goes solid on that.
If the ADSL light is fine then the modem has locked onto the signal on the phone line, sync'ed. If not then this is the problem you must solve. Ask your ISP if service is set on your line.
The next light is the Internet light, this maybe a symbol like an i or a world. This light will begin flashing then go solid. It will flash with Internet traffic. This means you have Internet, as far as the modem is concerned. If this light does not stay on then your ADSL account name and password maybe wrong. You can correct this but that's a different question you need to ask.
Feb 18, 2015 | D-Link Dsl-2750b Adsl2 Verizon N Wireless...
Internet connot display web page all the time , and slow download speeds,modem adsl light coming on constantly.
Dealt with a lot of these. It is either :
1. Wrong password and ISP information - double check that everything your ISP has asked you to put in is correct
2. Bad phone connection - even if the ADSL light comes on (which means the router can see an ADSL connection from your phone provider) does not mean the line is clean. Pull out all the connections to your home phone, and just plug in the router to get it all up and running. Once happy reconnect one at a time all phones, digi boxes etc.
3. Adding to 2. - have you got a splitter? If so, change your splitter or reconnect, splitters can fail quite easily and get old fast - a bad splitter creates a lot of noise on the line, making the internet time out
It could be a router fault, they last about 4 years before they start doing silly things. But likely one of the above.
Try two sites once you are happy :
www.speedtest.net - to check your connection speed
www.pingtest.net - to check line quality
Dec 19, 2010 | Computers & Internet
Modem and Router connected but cannot access internet.
ADSL Modem's LAN -> connect to your Router's Brodband port through ethernet cable.
or
connected through bridging or POP
Apr 02, 2010 | Computers & Internet
Connect two adsl router use static ip
you first have to do subnetting of the ip which you are using if you use VLSM much better because you will not waste any of the IP it uses /30 net mask which means only two host allows to conenct in that subnet range. then connect both routers via serial link give the ip address on serial link of both routers make sure you give clock rate on DCE cable both the the router's serial port ip on the same subnet. try this and it will solve your problem. let me know hpw did you go. thanks.
Apr 15, 2009 | Computers & Internet
ADSL wireless router setup..
I am not sure if its the same config instruction with linksys modems...but usually you can configure it using the setup wizard or manually.
The setup wizard can be found in the installation CD when you bought the modem/router. just insert the CD and follow the instructions given at the screen.
For manual configuration...open your internet browser (IE or firefox) then type http://192.168.1.1 (or check the manual for the correct local ip of your modem) you will see the configuration page in the browser in were you will put the username, password, PPPOA, VPI...etc.
reply back if you need further info. hope this helps.
Feb 04, 2009 | D-Link DI 514 Wireless Router (DI-514)
No internet connection
I received this solution from Belkin. It worked for me & I hope it does for you. Good luck!
Belkin solution:
Please follow the details given below:
1. Please contact your internet service provider to know the connection type details (Is it PPPOA,PPPOE, Dynamic or static)
2. Belkin router F5D8633 ADSL router works only with ADSL broadband connection and does not support Cable broadband connection.
3. Do not use the Setup CD Assistant; reset the unit and configure it manually. Make sure to set the correct VPI/VCI values in the process as the default settings may not be correct.
4. When using PPPoA, always use VcMux encapsulation, when using PPPoE, always use LLC encapsulation. Keep the VPI and VCI as 0/38.
5. Please follow the instructions given below to configure the router manually:
- Connect the phone line direct to the router, or through the filter.
- Connect the computer to one of the LAN ports on the router.
- Switch off the router and power it back after 5 seconds.
- Restore the router to factory defaults by holding down the reset button on the back of the router.
- The power light will flash and then come back ON solid, indicating that the router is being restored to factory defaults.
- The corresponding lights on the router should be lit-up.
- Check if the computer has an IP address in the range of 192.168.2.x
- Click on `start` & click `Run`.
- Type in `cmd` & click `ok`.
- Type `ipconfig` and Enter. Check for IP address, subnet mask & Default Gateway.
- If not, specify a static IP address, gateway and DNS by following the steps at http://web.belkin.com/support/kb/kb.asp?a=2824
Then follow the below instructions to reset IE.
-Open Internet Explorer
-Click on Tools -> Internet Options
-In the General tab, click on Delete Files under Temporary Internet Files
-Click on Clear History
-In the Connections tab, select Never Dial A Connection and click on LAN settings
-Uncheck all the options and click on OK
-In the Advanced tab, click on Restore Defaults
-Click on Apply and then OK.
- Open a new Internet Explorer window and on the address bar please type in http://192.168.2.1 and click on go.
- You should be able to access the routers set up page.
- By default the password is blank.
- Click on Connection Type and Reconfigure the connection on the router (using your ISP details).
- Save the Changes.
Note: Please obtain the correct values regarding the Internet connection from your Internet Service Provider.
Internet Status should show Connected on the top right hand corner of the web page.
If the problem persists, please get back to us with the following information given below:
1. Type of connection provided by the ISP (Is it PPPOA,PPPOE, Dynamic or static)
2. The ADSL light status on the router. Please let us know if the ADSL light status on the router is solid or flashing.
3. ADSL broadband connection or Cable broadband connection.
4. Operating system on the computer and the version number for the internet explorer like IE 6 or IE 7.
5. Internet Status shows as Connected or Disconnected on the top right hand corner of the router web page.
Log on to the router web interface at http://192.168.2.1
- By default, the password is blank.
- Click on Security log under "Firewall" option (let us know the message you see under the security log or send us the screen short of the message you see under the security log)
6. Then, check the IP address of the computer. For checking the IP address:
- Click on start & click `Run`.
- Type in cmd & click `ok`.
- Type IPCONFIG and Enter. Check for IP address, subnet mask & Default gateway.
- The IP address should be in the range of 192.168.2.x (x=2 to 254)
- In the command prompt type PING 192.168.2.1 & Enter. Check if you are getting replies.
- Type, PING 4.2.2.2 & press Enter. Check if you are getting replies.
- Try pinging yahoo by typing PING yahoo.com and Enter. Check if you are getting replies.
Dec 28, 2008 | Belkin N Wireless Modem-Router F5D8633au4A
Reply to advice
wts the light status of the router and are able to open the router page and wts the Adsl connection status is it connected.
Nov 03, 2008 | Belkin 802.11g Wireless Desktop Network...
My Belkin is blinking.
IT means that the router has gone defective.
May 20, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Thanks for replying to my problem
1.Ok check that you've light for ADSL or not?
If you do have light for ADSL that mean your ADSL is working fine.
2.If ADSL light is ok bu internet light is not working that mean some wrong setup in the router
what can it be ???
only 2 possible case
1.your username,password and all require setup is not correct
2.you have to setup Domain Name Server.This is a 4 group of number like 202.183.255.21(just sample).You should ask the provider that you need to put in your router or not?? If the answer is Yes then you should ask them for this number. If the answer is NO then you've to set in your Router that you use AUTO DNS
After doing this setup..again monitor that your internet signal is up...IF yes...then its running..
Goodluck...takecare.
Apr 20, 2008 | HP Pavilion dv6000z Notebook
Reset Router!
Hi LianM,
You can download your manual here,
http://www.dynamode.co.uk/support/adsl_r-adsl-c4wg.html
It is in .pdf format, so make sure you have Adobe.
Your reset button is found between the Power pluging hole and the RJ45 port. Found on page 6
Good Luck.
Jan 11, 2008 | Dynamode RADSLC4WG Wireless Router...
Belkin 802.11g Wireless Desktop Network Card [ F5D7000 Wireless ] (109061) Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
