Question about HP Office Equipment & Supplies
HAVE PUT TWO KNEW HP INK CARTRIDGES IN (MAGENTA)AND PRINTER SAYS (MISSING OR DAMAGED BUT THEY ARE NEW ONES. IT ALSO SAYS REFER TO PRINTER DOCUMENTATION ..I DONT KNOW HOW TO
  • tlday1 Nov 14, 2008
    Shortly after I purchased my L7580, I got a message saying that my magenta cartridge was either missing or damaged. I called tech support. They walked me through a dozen or so things to try. Nothing fixed the problem. I had only printed about thirt pages, maybe two using color. I bought a new Magenta 88XL cartridge and that fixed the problem. Soon after, the cyan cartridge did the same. I replaced it with a new Cyan 88XL. I replaced all four cartridges within two months of buying the printer. That was about two months ago. I turned the printer off for a bit this morning, when I turned it back on, two of my new cartridges are supposedly bad. I think the printer is a piece of junk.
  • 57 Answers
we need to know the printer Type & model
1\ if you talk about Ink Jet :
Try to use ink work even the old one's you want to replace it. if the old one's are OK but empty
the new ink are not OK. I faced by this problem I tel my customer that the ink not OK, he said It is Brand New, I went to my workshop to got old ink the work properly , I said to do your best.
2\ If you talk about toner :
the may faulty back sensor , also Bad or broken toner chip.
hope this helpfull,
thank,
Hamedo
Posted on Nov 06, 2008
    Problem Solver:
  • 20 Answers
Return them to where you bought them and get replacements for them. You should be able to exchange them easily with the receipt.
Posted on Nov 05, 2008
    Problem Solver:
  • 11 Answers
THE MOST COMMON PROBLEMS ARE A BAD CHIP ON THE TONER CARTRIDGE OR A BAD OR BROKEN SENSOR IN THE BACK OF THE PRINTER WHERE YOUR CARTRIDGE IS INSTALLED.
THE MOST COMMON ONES ARE THE YWLLOW AND THE MAGENTA FOR SOME REASON.
SCINCE IT IS REPORTING JUST ONE COLOR IT MOST LIKELY IS NOT THE CONTROLER BOARD.
CHECK TO MAKE SURE THE SENSOR LINES UP TO THE CHIP WHEN YOU INSTALL THE TONER!
  • CGALLAG2 Nov 05, 2008
    also also if it is an ink cartidge not a toner(some people say I have a bad ink cartridge when meaning toner)
    check where the cartridge goes in and make sure the connections are ok.
    and if this is a printer with print heads you might have to change them.
    if so replace just the magenta first and if that fixes it then replace the rest of them cause they will be going soon.
1) NEED TO KNOW WHAT MAKE AND (MODEL) OG LASER JET THIS IS BUT MOSTLY THIS KIND OF TROUBLE IS CAUSED BY A BAD CHIP ON THE TONER CARTRIDGE OR THE SENSOR IN THE BACK OF THE PRINTER IS BAD OR BROKEN.
THE MAGENTA AND THE YELLOW ARE THE MOST COMMON
    Novelist:
    Scholar:
  • 114 Answers
Did you remove the protective foil/film/cap from the cartridges before installing them and do they seem to be sitting at the same height as the other cartridges?
Refer to printer documentation means read the printer's manual, the documents supplied with the printer, specifically the section covering replacing cartridges.
Just so you know; typing ENTIRELY IN CAPITALS when communicating over the web represents and is taken as shouting.
Cartridge Error - Interference with magenta communication
check under the ink cartridge there is a seal it is probably missing look at the other ones you'll see the seal but on that one it will be missing
Oct 23, 2012 | Lexmark Interact S605 All-in-One Color...
Hp c6180 states cartridges missing or damaged
OK now this might seem bizarre, but did you go ahead and click the "Black Only" print option?
I have a C6180. Just installed all new cartridges. Tried to print and got the message that Cyan is empty. Tried all sorts of things. Then out of frustration clicked the Black Onl option. Document came out printed in color! Double checked with a picture that has lots of cyan colors. It all printed too! Go figure.
Apr 25, 2012 | HP Photosmart C6180 All-In-One InkJet...
Catridge error refer to device documentation to troubleshoot
You can go to HP's site and find that you have a problem with one or more of your ink cartridges see:
http://h10032.www1.hp.com/ctg/Manual/c00737535.pdf
It states: " Ink cartridge problem
Cause The indicated ink cartridge(s) are missing or are damaged.
Solution Replace the indicated ink cartridge(s) immediately so that you can resume printing.
If there are no ink cartridges missing from the HP All-in-One, the ink cartridge contacts might
need to be cleaned.
If there are no ink cartridges missing from the HP All-in-One, and you still receive this message
after cleaning the ink cartridge contacts, you might have a damaged ink cartridge. Contact HP
customer support." Go to:
www.hp.com/support
Basics Guide 29
Troubleshooting and support
Apr 01, 2011 | HP Photosmart C5180 All-In-One InkJet...
Screen says "the following ink
I am having the SAME problem!! The cyan color for some reason!!! All of these are BRAND new HP ink cartridges!! Have you figured out how to fix this??
Feb 21, 2011 | HP Photosmart D7560 InkJet Printer
Ink cartridge cannot be used after initialization
The following are common issues.
The following ink cartridges cannot be used after device initialization and must be replaced
Cause The wrong ink cartridge(s) are installed.
Solution The indicated ink cartridge(s) cannot be used after the device has undergone first time setup. Replace the ink cartridge(s) with the appropriate ink cartridges for the HP All-in-One. To find out the reorder number for all the ink cartridges that the HP All-in-One supports, see the printed documentation that came with the HP All-in-One.
If you are using compatible cartridges make sure they are reset for use.
Solution Replace the indicated ink cartridge(s) immediately so that you can resume printing. If there are no ink cartridges missing from the HP All-in-One, the ink cartridge contacts might need to be cleaned. If there are no ink cartridges missing from the HP All-in-One, and you still receive this message after cleaning the ink cartridge contacts, you might have a damaged ink cartridge.
Sep 21, 2009 | HP Photosmart C5180 All-In-One InkJet...
Says cartridge cannot be used after initialization but brand new HP 363 cartridge sent directly by HP to me. This happens ever time I put a new cartridge in when prompted by printer to do so. Do I put new...
Sep 21, 2009 | HP Photosmart 3310 Printer
"incompatible cartridges"
Usually if you leave the printer off for sometime the ink get dry on the heads or some ink may leake to the sensores so take the cartrage out clean it and clean the heads with cotton swaps...see if the help and let me know
Sep 13, 2009 | Office Equipment & Supplies
Ink cartridges are not recognized
some generic cartridges do not work check the numbers and make sure they are the right ones for your model number
Aug 28, 2009 | HP PhotoSmart 1215 InkJet Printer
I just purchased an HP Photosmart C7200 All-in-one printer, loaded the ink cartridges and the screen says the magenta cartridge appears to be missing or damaged. I put in a new cartridge- same message...
Hi
If the printer is out of the Box, don not try any other ink cartridges, becoz you must use the HOST ink cartridges that is shipped with the printer for the first time.It seems that it is problem with Host ink cartridge.
You can check the cartridge whether its a Host ink cartridge or normal one by looking at the serial number.If Serial number starts with C9, it Host; if it starts with C8 its normal one.
Only HP can replace it , none of the store sells Host ink cartridges, they sell the replacement ones.
You can either call HP tech support or, return the printer to staples.
Thank You
Rizwan
rizwan84tx@gmail.com
Dec 07, 2008 | HP Office Equipment & Supplies
228 people viewed this question
Ben Johnson
