Tv will not turn on completly, it powers up then just before ths screen comes on it turns itself off. it then continues to switch itself on and off.i have a samsung 42" lcd digital tv.
    Novelist:
    Champion:
  • 203 Answers
Seen that problem several times. In most cases it was the main pcb part number BN94-00850A. But that is only a good number for a certain model. I have to agree, on this one if you want more than a guess, take it to a Samsung servicer, or throw it away. Most non-factory shops don't have access to spare parts for testing purposes, until someone tries a self-repair job. Good luck, Russmann.
Posted on Nov 05, 2008
Bad capcitors in th switched power supply
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 105 Answers
I think the problem is not easy to solve,otherwise i suggest bring it to a qualified TV technician,the regulator from your power supply wer'e damage,pls check it...
Monitor goes off and on by itself
Hello bjaykaye,
The problems you are having are an indication of a Power Supply problem. The issue could be in the switching power supply or the High Voltage Power Supply. The shutdown circuit is activating which is allowing the TV to play until it detects an over-current event. When an over-current event happens the shutdown circuit will turn the TV off. I would suggest that you check the Horizontal Output Transistor, the HV Transformer, the Horizontal damper diode, and the capacitors that are in parallel to the damper diode. The important thing is to find the component that is causing the problem. If you do not have a background in electronics I would suggest that you get a qualified electronics technician to look at the set.
Thank you,
Shuttle83
Oct 29, 2007 | InFocus ScreenPlay 61" Rear Projection...
Black Screen
It sounds as if the lamp has failed possibly due to a failed cooling fan (the fan should be the first thing to come on). here are the links to the user manual if you need it; http://merchant.satisfusion.com/sf/library/manuals/owners/50_55_60VG825.pdf and http://merchant.satisfusion.com/sf/library/manuals/owners/50_55_60VG825_Part2.pdf It may be worth trying to uninstall and reinstall the lamp, but usually these fail internally rather than having bad connections etc. It is often obvious when the lamp has gone from a visual inspection. If the lamp has failed, when you replace it, make sure the fan comes on - if not then turn off instantly and investigate further. One other possibility before buying a new lamp, is that the lamp compartment cover may not be properly fitted. This will interrupt the power, so I am assuming there is a microswitch or similar that the cover or the screws that hold it should contact. Possibility is that the cover is badly fitted, or a small piece of the cover has broken, which would normally contact the switch, or the switch is faulty - if you can see the switch then a continuity meter will easily test the switch. Also check that the lamp unit securing screws are properly tightened, they also may stop the TV powering on. Please ask again if you need more help with this, if you are unsure then a photo of the inside of the lamp compartment and the lamp itself may help :)
Jun 26, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
When turning on the tv by either remote or switch on side screen will flash blue then turn off. Have unplugged tv still won't turn on.
Search Results
    Samsung TV Keeps Shutting Down - Forums - CNET
    www.cnet.com > Forums > Samsung
    CNETWhen I turn the TV on for the first time each day it shuts itself off within 30 ... There is ablue kill switch there, but you don't want to fool with that. .... The tv will not turn offwith the remote or the side buttons on the tv. .... I replaced the lamp but the tv screen will have a momentary flash of light on the screen then it will turn on and ...
    Philips/Magnavox Tv Problems ? - Home Forums
    ths.gardenweb.com > Home Forums > Electronics
    Mar 26, 2005 - I turned the tv on then off a few tims then eventually the piture would come on. .... time, the LED will flash continuously along with the volume going up to max. ...... You can use the remote to turn the tv off and on but nothing else. ... If you press the power button over and over it stays on a blue screen but as ...
    Top 208 Complaints and Reviews about Akai ' Page 3
    www.consumeraffairs.com > Electronics > Televisions
    Rating: 1.9 - ‎37 votes
    The screen will not turn on with the remote, side switch or rocker arm. .... It will flash for a second and the blue Akai screen will display very briefly, but then .... Akai LCT3201AD TV does not turn on using either remote or power button. ... I turned itoff one night and the next time I turned it on, the green light came on, but it did ...
    Get help with audio, video, or power on Apple TV - Apple ...
    https://support.apple.com/en-us/HT200197
    Apple
Jan 28, 2016 | Televison & Video
My tv, when plugged in just keeps turning itself on and off in intervals of about 3 seconds. It doesn't give time for anything to come up on the screen at all.
Problem is in standby power supply or microprocessor area---not the do it yourself repair and likely not economical to repair due to age and brand of set.
Sep 01, 2012 | Philips 60PP9352 60" Rear Projection...
Over tv its getting aoutmatically off
Hello
Put your hand on the back of your TV to check for overheating, if your set keeps switching itself off without warning.
Many TV sets come equipped with a safety feature that switches the power off if the set gets too warm.
Check the cooling vents located at the rear of your unit. Vents can collect dust and dirt, resulting in the fans becoming blocked and failing to work properly.
Remove dirt from the vents with a damp, clean cloth. Ensure the air conditioning is kept at adequate levels in the room where your TV is located. Keep the drapes shut on hot, sunny days to keep the room cooler.
Check the sleep-timer function on your TV if it keeps turning off. A sleep-timer is used to turn a television set off after a certain period of time has elapsed. If the sleep-timer is not turned off, your television will continue to turn itself off after a certain period of time.
If the problem persists,then a heat sink has gone bad.
The on/off button simply toggles a low voltage circuit that powers your tv. If it is dusty, it may complete the electrical circuit and send a false signal.
Take a can of compressed air, open the back and clean the dust off the circuit boards.
NOTE;opening the TV VOIDS warranty!!
Dec 22, 2010 | Televison & Video
My Tv, Olevia LCD HD TV 242 FHD T11, will not turn on
Same thing Just happened to me ths AM. Acting Wierd then this morning fuzzy screen and poof won't come back on.
Comcast box was resetting at the exact same time and I found this online....
http://www.my3cents.com/showReview.cgi?id=18330&s=1188
Mar 06, 2010 | Televison & Video
SONY GRAND WEGA KF-50WE610 can't turn on TV screen.
Ths 5 blinks usually indicate an AKB problem. There is a break in the video path. I'll look up your specific model and post the results here. Please update this if you wish to attempt the repair yourself.
Thanks,
Dan
Mar 19, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Tv/Monitor shuts off and on by itself
I have a complete set working all panels with a duff pdp panel - i will happliy sell you the boards please call me on 07940 025730 for details cheers.
Oct 31, 2007 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Proscan 27" tv
it is due to power supply failure. 1 check for loose contact in power supply. 2 it might be due to plug or socket loose. 3 switching circuit failure in power supply. good luck.
Oct 07, 2007 | Proscan PS27500 27" TV
Televison & Video Logo
122 people viewed this question
Top Televison & Video Experts
