We have a Valor Model 466 Black Beauty OXYSAFE Fire, when you turn the sparker on the fire lights and you hold it down for a short time but as soon as you release the ignition the flame cuts out. We have held the button down for over a minute and it still goes out.
  • 828 Answers
It sounds as though you have a bad thermocouple. Replacing the thermocouple which senses the heat from the flame should correct your problem. The thermocouple is a safety device which when working properly sends an electrical signal to the main gas valve that your pilot lite is on and holds the valve in the operational mode.
Posted on Nov 06, 2008
  • James Helmer
    James Helmer Nov 16, 2008
    Thank You for the rating.
The pilot light is out on my valor gas fire place. When I go to light it the flame comes on but if you let the button up to turn on the burners it goes out.
Keep the pilot gas control pressed down for 30 seconds to a minute after it lights to allow the thermopile in the pilot light to heat up. If you are already doing this the thermopile needs replacing
Dec 22, 2012 | Kitchen Ranges
Can I get Manufacturers instructions for valor dream gas fire G.C. 32-310-91
You can view the fire opening requirements and product information on valor gas fires
Alternatively you can download a PDF of the complete manufacturers instructions here
Feb 08, 2011 | Valor Toys
Attempting to light valor homeflame fire the pilot jets ignite but when i attempt to put fire on to full flame, jets go out.
Sounds like it could be your thermo-couple.
or the microswitch you will find the number for valor here
Valor Gas Fires
Jan 14, 2011 | Valor Toys
Put together starter system need a diagram on a valor tropic 121 wall gas fire
You should be able to download the installer instructions on
Valors website, the information can be found here
under Trade then installer guides
www.valor.co.uk
alternatively new Valor Gas Fires
Jan 02, 2011 | Valor Toys
The flame effect on my valor 846 electric fire is not coming on, i think it is an led that is not lighting up. how do you change the led and where can i get one. thanks Gerald
The LED is on a circuit board located inside the fire. The board itself needs to be replaced.
The part would be available from valor spares under your warranty.
The number for valor spares can be found at Valor fires
Dec 26, 2010 | Stoves Heating & Cooling
Just moved in and cant light af16n gas fire any ideas ?
I have an AF16N. You just turn the knob and light with a match.
Do you have a user manual? I'm desperate for one - willing to pay!!! Have had to disconnect the fire until I find a manual.
PLEASE contact me on obrienkathleen@hotmail.co.uk
Aug 21, 2010 | Valor Toys
Oven won't turn on but burners still will, the other day there was a small fire inside of the oven. The oven has not worked since that fire occurred, removed the sparker couldn't get fire started with a...
if you removed the Ignitor the oven will not light it has a safety valve that operates at this same time the ignitor is trying to get hot once it reaches a certain amount of power it will open the valve for the gas.
you may need to replace your ignitor,and or your electronic control board.
Feb 23, 2010 | Frigidaire FGF326AS Gas Kitchen Range
I have a valor hone flame gas fire. It is quite old now and I believe the ignition switch is faulty. Does this fire have a self generating ingier or ir there a battery ?
I believe the valor is self generating. Ours is also not working and we need to replace it. Any ideas where to purchase one?
Feb 10, 2010 | Valor Toys
Instalation manual for valor flamenco unigas 111 balanced flue wall mount gas fire
hi there, did you mange to find a copy of the instructions for the valor flamenco unigas ii at all?? i need to replace the ignitor so would like to see a copy..
cheers
sharron
Mar 08, 2009 | Heating & Cooling
Heating & Cooling Logo
250 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
