Question about Samsung CLP-510 Laser Printer
Engine Fuser Low Heat Error
I searched the most common problems on your website, for some reason mine hasn't been listed yet. The error that came up on the printer screen read "Engine Fuser Low Heat Error." Obviously the printer hasn't been over used because it would say too hot, what is the problem? "Engine Fuser Low Heat Error" printer show to me this message. help me plz
    Novelist:
  • 188 Answers
What this means is that the fuser is not reaching operating temperature. The most common reason for this failure is the xenon lamp inside the heat roller of the fuser has burned out. You can verify this by checking for continuity between the two contacts that connect to the lamp with an Ohm meter or digital multi meter.
If the continuity is good, the second most common reason for failure would be the LVPS, or low voltage power supply.
And last, although by far the least common reason for this error is the main logic board.
Have you checked to see if the unit is under warranty? If so, this would be a covered repair.
The part number for the fuser is listed below. Depending on your location and electrical system ( 110 or 220 )
ELA UNIT-FUSER 230V part number :JC96-03239A for use with 230V
ELA UNIT-FUSER 110V part number :JC96-03239B for use with 110V
Other then samsung, you can try a google search, and also an ebay search for the part number and find the best price for the item.
Good luck,
Cory
Posted on Nov 05, 2008
  • rcull Dec 09, 2013
    Sure wish the location of the wires on the xenon lamp were described. I am not even sure where it is!
So far the cost new for the JC96-03239B has run from $84.69 up to $145. I found a couple of sites that offer a refurbished unit, but you had to submit a quote request. I did find one site that showed the refurb unit for $71, but they didn't have any in stock. There has only been one offered on eBay and it was for $105.95 plus $25 for shipping. OUCH! before I purchase a replacement fuser, I'm going to try your suggestions. Once I find the best price, I'll post it here.
Posted on Jan 12, 2010
  • 106 Answers
Check out the fuser unit and replaceit if needed.
3 Suggested Answers
  • 624 Answers
SOURCE: Engine Fuser Low Heat Error
Basically the error message is telling you the printer cannot keep the fuser temperature at the proper temperature (too low). It could be a lot of things but typically it is due to a fuser assembly gone bad.
Posted on Feb 21, 2007
where can i pay it
Posted on Aug 17, 2008
We have an HP 3550 color printer that has a 50.1 Fuser Error. Will replacement of the fuser correct the problem?
The most common reason that causes a fuser error is its failure to reach operating temperature. If the fuser area can be accessed, check to see if there is noticeable heat present. If not, the fuser may not be getting the required voltage to bring it to temperature and you may need technical help to determine the exact cause of the error.
Aug 24, 2010 | HP Color Laserjet 3550 Printer
Dell 1600n low heat error
Remove the fuser lamp and put it back in place, it is not heating properly.
Apr 02, 2008 | Dell 1600n All-In-One Laser Printer
On screen,write "engine fuser low heat error"
When there is a fuser problem, usually try to replace the fuser. But, if the same error occurs, the printer may have another problem.
Aug 17, 2010 | Office Equipment & Supplies
You need to replace the fuser in the printer, the part number is JC96-03406A You can do a google search for the best price.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 30, 2009 | Samsung ML-3561N Laser Printer
ther is a prob in your fusing unit, chances are the thermistor is not working, if you can still feel some heat in this area, either the lamps are working fine but the sensing device fails to read the actual temp.
you need a tech to correct this prob
Jul 27, 2008 | Samsung CLP-510 Laser Printer
"Low Heat Error"
Thats probably the best way to solve the solution. Sometimes if there is a thermistor that is causing the problem that can be serviceable in the fuser unit, that can be replaced instead of purchasing a whole new fuser assembly. It's less expensive replacing the thermistor.
Jul 16, 2008 | Samsung CLP-600N Laser Printer
How do I fix an Engine Fuser Low heat error on printer:
UNPLUG AND REMOVE 5 SCREWS ON THE FUSER HOUSEING . CK WITH METER TO THERMOFUSE
Nov 05, 2007 | Samsung CLP-550N Laser Printer
THERMO FUSE OR THERMISTOR DIRTY OR BAD
there is a 2 wire device (thermistor) that rests against the fuser roller to measure the temperauture. if the fuser is getting quite hot, suspect the thermistor to be either dirty (remove and clean it with alcohol) or defective. if fuser not getting hot, then suspect burned out fuser heater (look inside fuser roller for a long light bulb).
Aug 28, 2007 | Samsung CLP-510 Laser Printer
Feb 20, 2007 | Samsung ML-2551N Laser Printer
Samsung CLP-510 Laser Printer Logo
940 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
