Question about JVC AV-48WP74 48" Rear Projection HDTV-Ready Television
Seemed to Fix Convergence problem; Now TV power doesnt work.
I only had a convergence problem , now I have more!. I removed the Convergence PWB, and Replaced BOTH IC804 and IC805 with two STK392-150's. Now, when I plugged the TV in, the "power" button would go on "blue light" but, no picture, no sound. The "blue" power button is not workable; the only way to turn the TV off is to unplug. Thanks for the help.
    Sergeant:
  • 337 Answers
You need to check first for solder splashes or bridges created when the new Ic's were installed,the next thing to check is a disconected conector or might not in place fully and then check for loose conections in the main board,all that movement might have loosen something more than before,check the horizontal driver transformer,the horizontal output transistor.Be careful
Posted on Oct 03, 2006
Need help with Convergence board.
Sounds like the convergence has failed which is a common problem with rear projection TV sets. This video has more details on this and info on how to fix it,
Dec 28, 2011 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi Plasma Flat Screen T.V. Mod #42EDT41 Has 1" vertical line, 10 inch from left side, top to bottom. another vertical line 14 inches from 1st vertical line.could you please let me know what...
This buffer board normally will just bypass the video to the screen from the main digital board.
There could be other problems with the main digital control board but it could also have a problem with the flex cables that connect from 6871QRH037A to the plasma panel.
Aug 13, 2008 | Televison & Video
The blue convergence is off at the bottom and doesnt readjust using the option.. can it be fixed?
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 09, 2011 | Toshiba 50A61 50" Rear Projection...
First the red hue seemed off now picture is overlapping, but when i go to a static screen the middle looked concaved. picture tube going out?
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
Aug 13, 2010 | Philips 60PP9363 60" Rear Projection...
Color seperation
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Feb 25, 2010 | Hitachi 43FWX20B 43" Rear Projection...
Need schematic for Convergence PWB of Hitachi
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos aroundimages.
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Mar 09, 2009 | Hitachi Televison & Video
TN50X81 - one convergence IC runs hot...TV powers off after 5min
What was the STKs that was in set ? If 110s always upgrade to STK392-180s. If they were 392-560s go back with the same. they worked differently then the 110s 150s 180s
Nov 27, 2008 | Toshiba TN50X81 50" Rear Projection...
Convergence problem then no power up after replacement
Check to ne absolutely certain that all the wires are plugged back in correctly, also if the wires are correct check the resistors near the convergence ICs one or two of them are likely open as well.
Mar 11, 2008 | Samsung PCL6215R 62" Rear Projection...
Three screens at once!
This is a convergence problem. Go into menu, select setup, select convergence, and run auth converge. If there is no failure in the tv then this will correct the problem. This model does have chronic convergence failures and most times either the convergence power supply must be replaced. Occasionally the problem is the convergence amp pcb and rarely the deflection bd can cause the problem.
Feb 05, 2008 | RCA HD52W56 52" Rear Projection HDTV
Black pop-up screen when pressing any menu features on remote
check for closed captioning. make sure it's set to off.
C-Dog
Feb 03, 2008 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP74 48" Rear Projection HDTV-Ready Television Logo
59 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
