Question about Canon imageCLASS 1100 Laser Printer
Canon printer error 073
What can i do my canon printer error E073
  • 57 Answers
Hi there
Error code E 073 [
with the front door closed, the transfer drawer connector or the transfer frame
drawer connector is not connected
Posted on Nov 08, 2008
    Problem Solver:
  • 18 Answers
The transfer drawer connector or the transfer frame drawer connector is not connected as the front door is closed.
Posted on Nov 06, 2008
  • 106 Answers
It seems that there is a Paper Jam problem. Please check it.
Posted on Nov 05, 2008
E073 0003
hello have a look in side the unit to see if you have any paper no mater how small stuck at the back of the transfer unit,and the transfer drum,if not try cleaning the connections on the back of the transfer unit.also check for a broken switch.
maybe just a good clean may do the trick.
hope this helps
Nov 14, 2012 | Canon CLC 1180 Copier
What does e073 0003 error mean on canon 1180
this is an error for the transfer unit or its cleaning section not in proper place slide out the unit as far as it will go.. look inside to the lower left rear frame. there are 2 halfmoon gears sticking out reach in and turn both of those clockwise till they stop . slide unit back in close doors see if it resets good luck.
Courtesy of
andzulisv.
-David.
Nov 03, 2010 | Canon CLC 1180 Copier
073 fatal error in OKI c3530
Oki ERROR 073 is a H/W Overrun detect. this occurs when the video circuit has set the overrun bit. Restart the printer and check the first print out. Try printing a different job and then reprint the same job that the error occurred. If you get the same error again, try using a different driver, ie swap from PS or PCL whichever you were using to see if that clears the error.
Dec 28, 2009 | OKI C3530N Color MFP Printer
Canon clc 1180 error code 073-0003
Dec 28, 2008 | Canon CLC 1150 Color Copier
Cannon clc700 error E073
there is a problem with the transfer drawer
Dec 27, 2008 | Canon CLC-700 Copier
What does error code E073-0001 mean.
0001 The connect signal CONNECT of the transfer assembly frame goes
‘0’ when the front cover is closed.
• Transfer drawer connector (fault)
• DC controller PCB (fault)
• Transfer belt edge sensor (fault)
Dec 06, 2008 | Canon CLC 4000 Copier
CLC 700
remove the lamp and check the continuity, the lamp may be burnt out, also check the lamp thermal fuse. Failing that, check the continuity of the lamp cable, it may be broken inside the sheathing. And failing that, replace the lamp regulator.
May 15, 2008 | Canon CLC-700 Copier
CANON CLC 1100
Transfer frame connector try pulling out the transfer drum and look to th rear of the machine and see if there is any paper stuck in the female connector at the rear of the machine.If the problem persists change thr connector.If you need more help get back to me 00447764303923 i am in the uk
Feb 16, 2008 | Canon CLC 1120 Color Copier
Error E073-0004
You need to call a copier technician, first and foremost.
This error code indicates that there is a problem with the transfer drawer connector inside of your copier. You've probably blown a fuse, like the FU903 on the DC fuse board.
There is nothing you can do if you aren't a copier technician. Call one right away; the technician can probably fix this in about ten minutes.
Dec 05, 2007 | Canon CLC 1000 Color Copier
E073-0004
Answered elsewhere, but answering here too:
Canon imageCLASS 1100 Laser Printer Logo
170 people viewed this question
old marine
old marine
