Question about Canon PIXMA MP160 All-In-One InkJet Printer
E3 on LED paperwill not feed
No jam visible. paper will not feed
  • Anonymous Nov 04, 2008
    this is my second printer with this problem. Error message wont allow the paper even to move through. First printer started to load paper at an angle more and more just like this one and then it said it it was jamed. ill try your solution then let you know
    Guru:
  • 859 Answers
What you want to do is remove all paper, the prepare to run a print test page or print a blank sheet from some program, any program. Just be ready to do this.
Now, find a magazine cover or index card stock, something firm. Cut this magazine cover to the same width as regular paper 8 1/2 in the US or A4 in Eurpoe.
Now, when you start the print job, push the magazine cover or index stock through while its printing. Apply pressure it the key, to getting the thicker paper through.
This will clear the sensors in the printer and remove the error message.
Why did this happen? In the printer, there are numerous sensors to identify jammed paper. This can happen for the strangest reasons. By pushing thicker paper through while feeding paper by running a print job, the thicker paper forces the sensors back to their original position.
Regards,
Worldvet
Posted on Nov 04, 2008
Error 3 indicated - what is it and how do I fix it
E3 means that there is a paper jam. If you are getting the E3 error and there is not an actual paper jam you may need to do is simulate a paper jam. Try inserting paper crooked to cause a jam so that when it starts trying to feed the paper through it gets jammed. Then lift the cover up and take the paper out. You'll then get a bunch of the lights flashing. Turn the printer off and then back on and you should be good to go.
Mar 04, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Paper jam (e3) BUT no paper jam
make sure you open all check points, if yours has a rear feed through, look in there also. it only takes a tiny piece of paper to cause it to say that. use a flash light, have had to use one to find several that way.
Feb 03, 2010 | Canon PIXMA MP150 All-In-One InkJet...
My all in one has an error message
E3 is a paper jam they may be small bit paper jam in side
Jan 17, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Error code E3 with no paper jam
it is problem your printer can not feed paper properly or problem paper feed sensor please try to resum button press when occard this E3 signal or clean sensor or claugth
Nov 21, 2009 | Computers & Internet
Paper jam problem in pixma mp145. E3 error.
hi
just recently had these problems
symptoms:
LED flashing E3 code and alarm light was solid. But dissapeared when opened the coved and came back on when closed the cover.
Also the when the cover was open the inks did not slide out to the left and stayed to the right side.
There was no paper jam, but error said paper jam.
Solution:
1. I took a thick piece of paper, from like a paper folder ones, thick enough to go in the printer and not curl up when pushed..
2. turned off the printer and turned it back on.
3, while printer was turning on,and makings sound as it does normally when turning on, I pushed through the piece of paper and the rotors stoped for a millisecond.
4.the rotors started again and pushed out the paper by it self with out my force.
5. I let the printer get started. and then turned it off and then on.
6. this solved all of my problems.
this was the first problem ever with this printer in 3 years.,preety good printer.
May 18, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Paper Jam, yet no paper in printer. The last sheet came out whole.
I have a canon mp210 and it's saying paper jam..there is no jam. Paper is going towards the right when trying to feed but does not feed.
May 17, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
E3 error on display.
Try cleaning the paper feed rolles with nail polish remover. If problem presist replace the feed rollers.
Feb 02, 2009 | Canon PIXMA MP160 All-In-One InkJet...
E3 error code
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jan 30, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
CANON PIXMA MP160 E3 error
I work in a shop repairing these printers and have had a large number with the same fault - displaying E-3 with no jam in the paper path. This is caused by a broken part in the paper feed mechanism that pevents the printer from taking the paper. The part located right at the bottom of the printer looks like two white gears connected together with a central spring. At present I am trying to find a supplier of the spare parts - will check back.
May 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
157 people viewed this question
old marine
old marine
