Question about Compaq Presario 700 470024-192 Notebook
Headphone jack not working
I reinstalled windows xp but couldn't get all the drivers. I installed conexant audio drivers. The internal speakers on my laptop works fine. When i plug in the headphone, i don't hear anything on it and still the internal speakers work. Can anyone help me to fix this problem?
I got it fixed from the hp customer support. I was chatting with the expert and he provided the same solution and it worked. I removed all sound drivers and installed the latest updates and it worked. I only have one more thing to be solved. That is, the internal speakers doesn't get muted when i plug-in the headphone. I am trying to fix it. I will post here if it is fixed.
Posted on Nov 05, 2008
  • 33 Answers
I just had it solved once for my frend. . wat to do is uninstall everything realted to yur sound hardware .. and get the latest updates ... from ..their site ... and install it .. it will work .. before .. doin this just try ....
1 conect the headphone
2 open the mixer .. in that there will selection of device. .. from that select headphone if it is available. ..
thnx
HI I HAVE A DELL VOSTRO A860 AND I JUST INSTALLED WINDOWS 7 EVERYTHING IS WORKING FINE EXCEPT THE SOUND IVE DOWNLOADED VISTA DRIVERS REALTEK AND CONEXTEANT DRIVERS BUT I CANT SEEM TO GET THE SOUND TO WORK...
If you hear the sound on the headphones then the drivers installed correctly and the defect is either hardware - the jack for the headphones is stuck so the internal speakers are no longer activated when you unplug the headphones = the jack will have to be replaced by a shop - or software - you will have to go into the Realtek HD Control Panel and configure the audio outputs correctly = enable or unmute the internal speakers.
The Panel icon can be found in the notification area or in Start > Control Panel.
May 10, 2011 | Dell Vostro A860 Notebook
Headphone audio doesn't work when pluged into headphone jack but will work if pluged into speaker jack
since speaker works nothing should stop the headphone it is likely that the headphone is faulty.try another headphone
Mar 16, 2011 | HP Pavilion DV8225NR Notebook
I just installed windows 7 32 bit in my acer travelmate 4222, everything is fine except for sound. there is no sound in speakers but sound from headphone jack is coming. i checked acer's site but there...
Hello
If the sound is coming from headphone jack then its mean that the drivers and windows installed correctly, you may check the speakers and speakers connection of your laptop. the speaker jack may be loosen or speakers may gone faulty.
Hope this helps, if so do rate the solution
Jan 05, 2011 | Acer TravelMate 4222WLMi Notebook
I cannot get sound from my internal speakers on dell d600 latitude. Headphones work and sound comes out of internal speakers briefly when pulling jack plug out? So I know they work but just cannot get...
This sounds like a defective audio port. In normal operation, plugging in a headphone plug breaks the connection to the speakers. On your laptop, when you pull out the plug it makes a connection, but only briefly. Unfortunately the audio port is built into the system board. I don't think you will find a software fix for this problem. Your best bet is to get a USB sound device for external speakers.
Apr 27, 2010 | Dell Latitude D600 Notebook
Audio Driver issues
download here
http://welcome.hp.com/country/us/en/support.html
just click the autodetection to detec your unit, then select the operating system
Sep 07, 2009 | HP Compaq Presario F730US Notebook
Can't mute inbuilt speakers
That is not a software problem.
The headphones/external speakers jack socket has a switch to exclude from audio the internal speakers, when a jack plug is connected.
This is a very simple device and is not software controlled.
The fact that it has gone faulty at the same time you reinstalled the system is a coincidence.
If it does not mute when you insert headphones, all you can do is trying to play with the jack plug , inserting and pulling it out. If this does not unlock the switch, the alternative is having the jack socket replaced by a technician. This is generally an expensive repair, asthe socked is soldered on motherboard.
A cheap alternative to a proper repair is using an external USB to Audio Adapter and mute the internal audicard when using headphones.
Oct 19, 2008 | Computers & Internet
Sound Problem with Headphone
First try the headphones in a different machine, such as an mp3 player or cd player to make sure the headphones still work.
Try going to the start button, then settings and control panel. Then select "Sounds and Audio devices" Down at the bottom you should see "Speaker settings." Click the "Advanced" button and then select stereo headphones.
Then, place the headphones into the green audio jack (or the headphone jack up front if you have them), play some music, and then gently wiggle the jack to see if some of the sound makes it into the headphones. If not, try slowly pulling the headphones out of the jack while the music is plaaying. you might find that the jack has slipped a little and may play only if your connector is slightly pulled out or more firmly pushed in. If his helps, then your audio connector is loose and you should replce the sound card. If the card is on the motherboard, you can disabled it when you put a new card in.
Jul 09, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq Presario 700 470024-192 Notebook Logo
320 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
